Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
06-05-2013, 00:36 | #16 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 319138 Status: Offline Thanks Meter: 29 | 1) how do I insert battery if phone is disassembled 2) when it says Turn on the PBA , do I press the power switch on the board ? 3) where do I get tweezers that small to short R313 Thank you. |
06-05-2013, 01:14 | #17 (permalink) |
No Life Poster Join Date: Sep 2002 Location: mauritius
Member: 15162 Status: Offline Thanks Meter: 61 | Yes you need to short it with tweezers while shorting it insert usb cable in the pc usb port and remove tweezers after 3-6 second no need battery .if all ok you will see on lcd. Cheers Djyash |
The Following User Says Thank You to djyash For This Useful Post: |
06-05-2013, 08:03 | #19 (permalink) | |
Insane Poster Join Date: Oct 2010 Location: cote d'ivoire
Member: 1410502 Status: Offline Sonork: 100.1645892 Thanks Meter: 27 | Quote:
*if you have ns pro rj45 c3300K (C3303K UART Auto Ignition! it's use to repair I9300 imei) ;you can used NS pro box or USF hwk box :same pinout *if you have z3x rj45 c3300K (C3303K UART Auto Ignition! it's use to repair I9300 imei) ,you can used any other box same pinout like z3x (infinity; polar;universal box ...) You can tested ! I have z3x rj45 cable c3300K and tested with Riff box ;it worked fine Why RJ45 c3300K (C3303K UART Auto Ignition) and connected the box? I used to supply power to the PBA. | |
The Following User Says Thank You to sakoou For This Useful Post: |
06-05-2013, 11:37 | #21 (permalink) |
Member: 319138 Status: Offline Thanks Meter: 29 | I have just got this board under usb microscope and where 313 resistor is, it has two other resistors beside it, on this board the middle resistor is not there,(beside 313) is this the problem with this board as phone was dropped by owner a few times. What number is this resistor (middle one of three) 314 or 312 ?? doe's anyone know ? Thank you |
06-05-2013, 17:46 | #23 (permalink) | |
The middle resistor number is 312... Thank. | |
06-05-2013, 21:47 | #24 (permalink) | |
http://forum.gsmhosting.com/vbb/f777...0/#post9355967 | |
06-06-2013, 15:34 | #25 (permalink) |
Freak Poster Join Date: Jun 2005 Location: kl Age: 40
Member: 151678 Status: Offline Thanks Meter: 22 | i have success repair boot.. now phone can go into recovery mode but always stuck at nand write ...if flash with pit and pda what firmware version (pda, csc, modem) and pit used? now my phone only stuck at samsung logo |
06-06-2013, 19:44 | #26 (permalink) | |
Try this version:I9300XXEMB5_MGFEMC1_QVZEMC1_SVZEMC1 unzip and it Contain (pit, bootloader,pda,csc and modem) This version work for me, i choice -PIT: mx.pit -BOOTLOADER:BOOTLOADER_I9300XXEMB5_996085_REV00_use r_low_ship.tar.md5 -PDA:CODE_I9300XXEMB5_996085_REV00_user_low_ship.ta r.md5 -PHONE:MODEM_I9300XXEMB5_REV02_REV04_CL1214143.tar. md5 -CSC:CSC_MGF_I9300MGFEMC1_CL1026299_REV00_user_low_ ship.tar.md5 hoping it can help you | |
