Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 06-07-2013, 11:42   #31 (permalink)
Member: 1750849
Thanks Meter: 3
Originally Posted by sakoou View Post
How to recover S3 I9300 dead boot
I tested and it work fine for me
The things you will need:
First , to make
GT-I9300 Unbrick SD Card cloned
i used the method of
iqballk ;
* download this tiny i9300.7z file.. (883kb).
* extract using 7zip...
* use HDDRAW Copy to burn i9300.img (3.72GB) to a 4gb SD card.
For me;i used 4GB SD card completely cleaned
After successful burn sd card clone ;
Disassemble the S3 I9300 Dead
Insert SD card cloned to PBA
Connect the PBA with rj45 c3300K (C3303K UART Auto Ignition! it's use to repair I9300 imei) and connect rj45 to the box (for me i connected to riff box rj45)
insert battery
Short R313 resistance.(HQ uses tweezers to short the resistance)
Turn on the PBA, and REMOVE THE SHORT between 3 to 6 seconds from turning on the PBA.
After approximately 5 seconds, you can see message on the LCD boot recovery was succeeded
Turn off the pba, and remove SD Card.
Assemble the phone, and enter download mode.Download Full S/W including PIT, PDA, CSC and PHONE with ODIN.
Here is how i repaired my S3 I9300 without normal I9300
well ... icant found dll for i9300 on riff box ........how are u doit .. please tell me know bro
Old 06-08-2013, 08:17   #32 (permalink)
Member: 1410502
Sonork: 100.1645892
Thanks Meter: 27
Any Box supports I9300 repair boot yet!
No need I9300.dll for this methode;only I9300 unbrick SD card cloned.
I used riff box with rj45 c3300K only to supply power to the PBA; becoz I did not 11pin cable.
the way it works for me and it's the same way I explained. Someone can simplify or tested other way.
thank
Old 06-09-2013, 16:00   #33 (permalink)
Member: 1610809
Sonork: 100.1616347
Thanks Meter: 23
thank
great solution bro thanks in advance
but any problem come when i do reflash this phone always fail now my phone is bootloop condition so where is the problem
Old 06-09-2013, 20:20   #34 (permalink)
Member: 1769339
Sonork: 100.1627057
Thanks Meter: 13
plz sir,is extenal power needed?
tnx
Old 06-19-2013, 19:05   #35 (permalink)
Member: 69514
Thanks Meter: 66
When I burn sd card image i9300.img around 3.9gb with HDDRawCopy1.02Portable.exe.The card remains empty.
Should I copy paste GT-I9300_Boot_Recovery.tar file in that sd card?
Please explain procedure clearly how to burn image file with HDDRawCopy1.02?
Thanks,
Old 06-19-2013, 22:28   #36 (permalink)
Member: 1772418
Thanks Meter: 7
The only thing missing is a N7100 Image. Hope some one gets one soon
Old 06-20-2013, 05:46   #37 (permalink)
iqballk's Avatar
Member: 13932
Sonork: 100.1609876
Thanks Meter: 410
Thanks,
there's no files inside sd.. check drive properties.. must like attached pic..
Old 06-20-2013, 05:52   #38 (permalink)
iqballk's Avatar
Member: 13932
Sonork: 100.1609876
Thanks Meter: 410
tnx
No.. but you have to use a micro usb cable or JIG to force update..
regards..
Old 06-20-2013, 05:57   #39 (permalink)
iqballk's Avatar
Member: 13932
Sonork: 100.1609876
Thanks Meter: 410
solution here..
regards..
Old 06-20-2013, 12:25   #40 (permalink)
Member: 69514
Thanks Meter: 66
I used uart cable & z3x box but doesn't work.
Mobile display is blank & dead.
Can z3x box with uart cable provide enough voltage for PBA?
Old 06-20-2013, 12:50   #41 (permalink)
iqballk's Avatar
Member: 13932
Sonork: 100.1609876
Thanks Meter: 410
did u put battery..? battery must be inserted..
Old 06-21-2013, 00:59   #42 (permalink)
Member: 1615735
Can any one upload the N7100 Clone image please?
Thanks
Old 06-21-2013, 04:54   #43 (permalink)
Member: 675059
Hello sir,I also need bootloader image for N7100
Old 06-26-2013, 16:13   #44 (permalink)
Member: 570252
Thanks Meter: 207
Wink
http://www.youtube.com/watch?v=JXvOcGJ6zXo
The Following 2 Users Say Thank You to temp_temp For This Useful Post:
Old 06-28-2013, 22:52   #45 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 83
plzz I need CLONED SD CARD for N7100
Page generated in 0.43827 seconds with 9 queries
