Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
07-07-2015, 13:28 | #4 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | try flashing this modem via Odin: androidfilehost.com - I545VRUFNK1_MODEM_w_HLOS_ODIN.tar also please post what firmware you are on atm |
07-07-2015, 14:20 | #5 (permalink) | |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | help Quote:
i flashed not work firmware version i545VRUEMJ7 Android 4.3 | |
07-07-2015, 15:30 | #6 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | flash this file via Odin: 4shared.com - backup.tar.md5 lemme know if flashing fails, i will upload a zip file flashable via custom recovery... |
07-07-2015, 16:03 | #7 (permalink) | |
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | mr.worldlinkmobil Quote:
not flash write failed | |
07-07-2015, 16:32 | #8 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | flash this Custom Recovery via Odin: twrp.me - twrp-2.8.7.0-d2vzw.img.tar Enter Recovery Mode, Install Zip: androidfilehost.com - Debrick-i545-MJ7.zip |
07-07-2015, 17:08 | #9 (permalink) | |
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | Quote:
07-07-2015, 18:50 | #10 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | my bad.. since verizon bootloaders are locked and after 4.3 loki method dont work, only way is safestrap but thats a long story... so easiest way to flash custom recovery your device, install Goo Manager from Play Store.. hit install openrecoveryscript.. select the file below (put into sdcard)... select reboot recovery... file to flash: dl.twrp.me - twrp-2.8.7.0-jfltevzw.img |
07-07-2015, 20:26 | #11 (permalink) | |
Member: 861795 Status: Offline Thanks Meter: 1,275 | Quote:
07-07-2015, 23:09 | #13 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | For rooting read this tutorial, there is also a video: [ROOT] Saferoot: Root for VRUEMJ7, MK2, and Android 4.3 after you root your phone: 1.Download these files and put into sd-card: -dl.twrp.me - twrp-2.8.7.0-jfltevzw.img -androidfilehost.com - Debrick-i545-MJ7.zip 2.install Goo Manager from Play Store.. 3.Run Goo Manager hit install Openrecoveryscript.. select the file "twrp-2.8.7.0-jfltevzw.img" from sdcard 4.Hit Reboot Recovery 5.In Recovery select update zip from sd card select "Debrick-i545-MJ7.zip" |
07-08-2015, 12:43 | #14 (permalink) | |
send me thx | |
