Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-08-2013, 12:01 | #16 (permalink) |
No Life Poster Join Date: Nov 2006 Location: maldives
Member: 389862 Status: Offline Sonork: guy_askali Thanks Meter: 54 | any way can i update with octopus box? |
05-20-2013, 14:35 | #20 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: Sudan
Member: 219803 Status: Offline Sonork: 1582317 Thanks Meter: 38 | Quote:
. . Hello dear, is there any one tried to flash the GT-N7100_Recovery_bootloader.tar with PIT file successfully?????????? (BTW the fail in my case coming from first step). When trying to flash it getting fail always. As I know I have to success first to flash it to the working phone then flash it to also to the (working phone + SD card + checking T Flash) (Am I right???) Why I asked because I am afraid to kill the working phone PIT and bootloader with checking Repartition. Does it case any problem? Working phone have 4.1.2 firmware. Please Please Please feed me back urgently. Thanks in advance. | |
05-21-2013, 21:53 | #21 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Turkey
Member: 1058593 Status: Offline Sonork: 100.1625725 Thanks Meter: 433 | hi for repair boot u need create repair card and for repair card need 1 sd card and 1 good phone 1.put sd card too good phone and put phone download mode 2.select repair file from boot area like on repair manual and flash 3.select again repair file and select t-flash and again flash ur phone with this repair file now u have 1 repair card and if u cant create repair card try find 1 phone and inside low version I test this with many phone and file %1000 worked if ur phone too same u can repair and this repair file not inside latest version like s3 i9300 .... |
05-22-2013, 06:34 | #22 (permalink) | |
Thanks man for explaining. My problem is I tried to use it with firmware 4.1.2 and 4.1.1 but no luck all the same fail in flash boot file to working phone. I am afraid to flash boot file with PIT file as mentioned above. Is it okay? | |
The Following User Says Thank You to zozo2 For This Useful Post: |
06-06-2013, 09:40 | #25 (permalink) | |
Insane Poster Join Date: Oct 2010 Location: cote d'ivoire
Member: 1410502 Status: Offline Sonork: 100.1645892 Thanks Meter: 27 | Quote:
It worked fine for me. i9300 repair step is same like I9500 and N7100 if don't have 11 pin cable,try rj45 C3300K UART auto ignition See this thread http://forum.gsmhosting.com/vbb/f777...6/#post9309300 hoping it can help you | |
06-11-2013, 04:45 | #30 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | If you find someone to readout for you image from prepared "bootrepair" microSD card, then is possible to clone another card at you. It's easy, and everyone can make it if have in hand N7100 and 10 minutes to do it. |
The Following User Says Thank You to debeliamark For This Useful Post: |
