Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
12-23-2012, 19:28 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | [Guide] All Android Samsung Hard reset codes & combinations As we all know the new galaxy s mini stock recovery cannot be accessed by any key combination except a few modification is done. which means out of the the normal volume up + home + power to access recovery and wipedata/factory reset will not work. I assume you have too many pattern attempt of forget your passcode and need to reset. simply download this i8190wipe.zip open odin and slect it in pda enter download mode as usual with volume down +home and power connect to pc and make start. all should be done. Note: all data will be lost. thanks to xda. http://www.gsmcoder.net/downloads/WIPE_I8190.tar.rar Uploaded with ImageShack.us Last edited by moulnisky; 03-28-2013 at 00:22. |
03-09-2013, 12:23 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | [Guide] All Android Samsung Hard reset codes & combinations All Android Samsung Hard reset codes & combinations: =========================================== Galaxy S i9000 hardware reset manual: Note: Please back up all of your personal data before you proceed. All data will be deleted on your Samsung I9000 Galaxy S by doing this procedure. However, this process will NOT delete data stored on the microSD memory card. To Hard Reset Samsung I9000 Galaxy S 1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it 2. Hold the Volume Down button 3. Press and release the Power button 4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock 5. Select Clear Storage by pressing the Volume Down button 6. Press and release the Power button 7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO If YES is selected, all data including third-party applications will be deleted from your Samsung I9000 Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state. =========================================== Galaxy S2 i9100 hardware reset manual: If you want to hard reset your Samsung I9100 please follow this: 1. Press and hold Volume UP + Home + Power button together. 2. Release all buttons once Samsung Logo comes one. 3. After a bit it shall ask you to enter a password. 4. Enter wrong password about 5 or 6 times. 5. Before entering the password, a warning sign will come that you will lose all your data on SD card. 6. After enter the wrong password last time, phone will enter into boot menu. 7. Select 'wipe data' option, it will tell you to confirm again. 8. After wipe off, boot menu will give you option to reboot phone. 9. Hard reset is done!! Piece of cake. Right! =========================================== Galaxy S3 i9300 hardware reset manual: Hard Reset by button combination. Sometimes the code may not always useful specially when your Samsung Galaxy S3 is frozen and become unresponsive or in other sever unresponsive problem like it just stuck on welcome screen logo. To fix it, just then again 1. Remove the battery out, then put it back again. 2. Don't power it ON yet, 3. Just press and hold the Volume Up, Center button and Power button at the same time. A menu will then appear that let choose with an option. Just use the volume button to toggle and select the wipe data/factory reset, that will then reset your Galaxy S III to it's factory default settings. =========================================== more comings soon.... BR Alex Last edited by moulnisky; 03-10-2013 at 01:10. |
The Following 6 Users Say Thank You to moulnisky For This Useful Post: |
03-09-2013, 21:59 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | hard reset Samsung Galaxy Note 2 hard reset Samsung Galaxy Note 2
If that doesn't work, try this:
The Following 3 Users Say Thank You to Mohsin-* For This Useful Post: |
03-09-2013, 22:02 | #5 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | hard reset the Samsung Galaxy Note hard reset the Samsung Galaxy Note
The Following User Says Thank You to Mohsin-* For This Useful Post: |
03-09-2013, 22:15 | #6 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Samsung Galaxy TAB GT-P1000 Hard Reset Samsung Galaxy TAB GT-P1000 Hard Reset and Factory reset To Reset the Phone:
To Hard Reset:
04-06-2013, 09:11 | #7 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Samsung i607 & i617 Windows mobile Hard reset Trick Samsung i607 & i617 Windows mobile Hard reset done by keys for samsung i617 do as shown in picture for i607 press same keys After Format menu press 1 for format then press y to confirm . |
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
04-06-2013, 09:36 | #8 (permalink) |
Freak Poster Join Date: Apr 2012 Location: MX-KEY is the BEST NOKIA TOOL
Member: 1752987 Status: Offline Thanks Meter: 17 | GT-S6500 Hard Reset : [/img]http://img838.imageshack.us/img838/4544/s6500hardreset.jpg[/img] vol up + vol down + home + power BR Last edited by moulnisky; 05-05-2013 at 20:13. Reason: Fixed Image |
05-04-2013, 14:13 | #9 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Planet Earth Age: 48
Member: 57577 Status: Offline Thanks Meter: 98 | Samsung Galaxy S4 I9505 hard reset It's very easy...in case you forgot your security code or did you block your pattern code follow these steps: 1.power off your phone 2.press together volume up+home button+power button 3.When you see Samsung logo leave your fingers of the phone 4.Select "wipe data/factory reset" with volume buttons 5.Press power to activate 6.Select "yes" with volume button 7.Press power button to activate 8..Wait untill format is complete 9.Select "reboot" Last edited by moulnisky; 05-04-2013 at 20:29. |
05-18-2013, 16:20 | #10 (permalink) |
Member: 57577 Status: Offline Thanks Meter: 98 | How To Remove The Pattern Code or Password From Samsung Galaxy Ace S5839i Before you start you should know that all data will be lost If you forgot the combination to unlock the screen follow these steps: 1.Press together volume up + home key + power button 2.Choose with volume buttons "wipe data/factory reset" and select it with home button 3.Choose "yes" with volume buttons and select it with home button 4.Wait untill format ends 5.Choose "reboot" That's all Here is video how to do:Factory-reset |
05-18-2013, 22:05 | #11 (permalink) |
Member: 57577 Status: Offline Thanks Meter: 98 | How To Remove The Pattern Code or Password From Samsung Galaxy Mini S5570 If you forgot your screen lock combination or follow these steps. Warning !All data will be lost! 1.Press together home button + power button 2.Release your fingers of the phone when Samsung logo appear 3.Choose with volume buutons "wipe data/factory reset" and select it with home button 5.Choose "yes" with volume buttons and select it with home button 6.Wait untiil format is complete 7.Select "reboot" Here is video how to do:Factory-reset |
The Following User Says Thank You to mikiidan For This Useful Post: |
05-18-2013, 22:07 | #12 (permalink) |
Member: 57577 Status: Offline Thanks Meter: 98 | How To Remove The Pattern Code or Password From Samsung Galaxy Mini 2 S6500 If you forgot your screen lock combination follow these steps. Warning!All data will be lost! 1.Press together volume up + volume down +home button + power button 2.Release your fingers of the phone when Samsung logo appear 3.Choose with volume buutons "wipe data/factory reset" and select it with home button 5.Choose "yes" with volume buttons and select it with home button 6.Wait untiil format is complete 7.Select "reboot" Here is video how to do:Factory-reset |
06-09-2013, 16:52 | #13 (permalink) |
Freak Poster Join Date: May 2008 Location: beawar (rajsthan)
Member: 764695 Status: Offline Sonork: 100.1627861 Thanks Meter: 45 | Any one have s 5282 hard reset solution key combination Any one have s 5282 hard reset solution key combination i try all type of known combination but not get success if anyone have perfect solution please tell me Note:- Do not give any fake solution or combination Here is the phone Last edited by raj_shanu; 06-09-2013 at 17:00. |
The Following User Says Thank You to raj_shanu For This Useful Post: |
06-11-2013, 17:45 | #14 (permalink) | |
Junior Member Join Date: May 2013
Member: 1943221 Status: Offline Thanks Meter: 0 | Galaxy S GT 19000 Tried this but does not work. Any further ideas. Thanks for your help Graham Quote:
06-20-2013, 05:58 | #15 (permalink) | |
Freak Poster Join Date: Aug 2011 Location: Tamilnadu
Member: 1637410 Status: Offline Sonork: 100.1606885 QQ 2480697349 Thanks Meter: 127 | Quote:
