Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-11-2017, 11:09 | #47 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | ===================================== -----{ ALNAJAT -- SOFT -- TEAM }------ ===================================== ((\/\))-- BY BASEL ALZOUBI --((/\/)) __________________________________________________ ______________________________ CONNECT A SM-G532F WITH ROOT ACCESS FOR IMEI REPAIR PRESS ANY KEY WHEN YOU READY Press any key to continue . . . Android Debug Bridge version 1.0.31 -d - directs command to the only connected USB devic e returns an error if more than one USB device is present. -e - directs command to the only running emulator. returns an error if more than one emulator is r unning. -s <specific device> - directs command to the device or emulator with the given serial number or qualifier. Overrides ANDROID_S ERIAL environment variable. -p <product name or path> - simple product name like 'sooner', or a relative/absolute path to a product out directory like 'out/target/product/sooner'. If -p is not specified, the ANDROID_PRODUCT_OUT environment variable is used, which must be an absolute path. devices [-l] - list all connected devices ('-l' will also list device qualifiers) connect <host>[:<port>] - connect to a device via TCP/IP Port 5555 is used by default if no port number is specified. disconnect [<host>[:<port>]] - disconnect from a TCP/IP device. Port 5555 is used by default if no port number is specified. Using this command with no additional arguments will disconnect from all connected TCP/IP devic es. device commands: adb push <local> <remote> - copy file/dir to device adb pull <remote> [<local>] - copy file/dir from device adb sync [ <directory> ] - copy host->device only if changed (-l means list but don't copy) (see 'adb help all') adb shell - run remote shell interactively adb shell <command> - run remote shell command adb emu <command> - run emulator console command adb logcat [ <filter-spec> ] - View device log adb forward <local> <remote> - forward socket connections forward specs are one of: tcp:<port> localabstract:<unix domain socket name> localreserved:<unix domain socket name> localfilesystem:<unix domain socket name> dev:<character device name> jdwp:<process pid> (remote only) adb jdwp - list PIDs of processes hosting a JDWP transport adb install [-l] [-r] [-s] [--algo <algorithm name> --key <hex-encoded key> -- iv <hex-encoded iv>] <file> - push this package file to the device and instal l it ('-l' means forward-lock the app) ('-r' means reinstall the app, keeping its data ) ('-s' means install on SD card instead of inter nal storage) ('--algo', '--key', and '--iv' mean the file is encrypted already) adb uninstall [-k] <package> - remove this app package from the device ('-k' means keep the data and cache directories ) adb bugreport - return all information from the device that should be included in a bug report. adb backup [-f <file>] [-apk|-noapk] [-shared|-noshared] [-all] [-system|-nosy stem] [<packages...>] - write an archive of the device's data to <file> . If no -f option is supplied then the data is wr itten to "backup.ab" in the current directory. (-apk|-noapk enable/disable backup of the .apks themselves in the archive; the default is noapk.) (-shared|-noshared enable/disable backup of the device's shared storage / SD card contents; the defau lt is noshared.) (-all means to back up all installed applicatio ns) (-system|-nosystem toggles whether -all automat ically includes system applications; the default is to inclu de system apps) (<packages...> is the list of applications to b e backed up. If the -all or -shared flags are passed, then t he package list is optional. Applications explicitly g iven on the command line will be included even if -nosys tem would ordinarily cause them to be omitted.) adb restore <file> - restore device contents from the <file> backup archive adb help - show this help message adb version - show version num scripting: adb wait-for-device - block until device is online adb start-server - ensure that there is a server running adb kill-server - kill the server if it is running adb get-state - prints: offline | bootloader | device adb get-serialno - prints: <serial-number> adb get-devpath - prints: <device-path> adb status-window - continuously print device status for a specifie d device adb remount - remounts the /system partition on the device re ad-write adb reboot [bootloader|recovery] - reboots the device, optionally into the boo tloader or recovery program adb reboot-bootloader - reboots the device into the bootloader adb root - restarts the adbd daemon with root permissions adb usb - restarts the adbd daemon listening on USB adb tcpip <port> - restarts the adbd daemon listening on TCP on th e specified port networking: adb ppp <tty> [parameters] - Run PPP over USB. Note: you should not automatically start a PPP connection. <tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1 [parameters] - Eg. defaultroute debug dump local notty usepeerdns adb sync notes: adb sync [ <directory> ] <localdir> can be interpreted in several ways: - If <directory> is not specified, both /system and /data partitions will be u pdated. - If it is "system" or "data", only the corresponding partition is updated. environmental variables: ADB_TRACE - Print debug information. A comma separated list of the following values 1 or all, adb, sockets, packets, rwx, usb, sync , sysdeps, transport, jdwp ANDROID_SERIAL - The serial number to connect to. -s takes prior ity over this if given. ANDROID_LOG_TAGS - When used with the logcat option, only these de bug tags are printed. - - - - - - - PHONE FOUND .... CHECKING MAGIC .... - - - - - - - - - - - - - - - - OK ! MAGIC PART 1 START .... - - - - - - - mount: Permission denied mount: Permission denied mount: Permission denied |
10-13-2017, 08:24 | #48 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | all file deleted plz upload here without pasword thankss FISRT DOWNLOAD ALL REQUIRED FILES 1 – IMEI REPAIR TOOL CLICK HERE 2 – ROOT KERNEL + FIRMWARE FOR ROOT CLICK HERE 3 – COMBINATION FIRMWARE CLICK HERE 4- 4 FILES FIRMWARE CLICK HERE (SKIP THIS STEP IF U HAVE FIRMWARE) PASSWORD : alnajat.co |
10-13-2017, 09:41 | #49 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | All download link has been correction, soon will be uploaded firmware to another free file hosting server.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
10-15-2017, 18:56 | #52 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | @ mr_basel_99, I can see that the link posted to you is free, but no one can download it 3Gb, but it can be possible downloaded with for any browser downloader. IDM can't access to allow for your server multi link . Tested by me & most of users try to download with the Internet Download Manager for the reason more user are fail for downloading. so for that i'll post your tools & firmware from IDM supported link.
10-16-2017, 12:01 | #54 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | @ mahi20015 I think you did not check the first post, and all the link where are changed.
