[Guide] G532F IMEI REPAIR SOLUTION ONLY HERE SM-G532F IMEI REPAIR TUTORIAL NO NEED FOR ANY BACKUPS THIS GUIDE IS FOR RESTORE ORIGINAL IMEI ONLY FIRST DOWNLOAD ALL REQUIRED FILES 1 – G532F-G_IMEI_REPAIR-Tool-BY-ALNAJAT_TEAM.zip 2 – SM-G532F-ROOT_KERNEL FIRMWARE_FOR-ROOT 3 – COMBINATION_OXE_FA60_G532FXXU1AQK1_OXEFA60 FIRMWARE Uploading Credit titanicphone 4- SM-G532F 4 FILES FIRMWARE (SKIP THIS STEP IF U HAVE FIRMWARE) RAR PASS : gsmhosting STEP BY STEP : 1 – FLASH FIRMWARE FOR ROOT 2- FLASH ROOT KERNEL 3- BOOT TO RECOVERY MODE AND WIPE DATA AND CACHE 4 – RUN THE IMEI REPAIR TOOL WAIT FOR PHONE TO BOOT INTO DOWNLOAD MODE 5- FLASH COMBINATION FIRMWARE PHONE WILL BOOT AND SHOW ANDROID LOGO WITH ERROR JUST SKIP IT AND BOOT PHONE TO DOWNLOAD MODE AGAIN 6- FLASH 4 FILES FIRMWARE AND YOU DONE ORIGINAL IMEI HAS BEEN RESTORED ''SEE VIDEO TUTORIAL HERE '' PRESS THANKS IF THAT'S HELP |
Big thanks mr_basel_99 Good job |
this is what we called hard working |
if i want to write my on imei can i write ? |
this tool it's just for SM-G532F ?? |
all done imie back orginal but show emergency calls only |
if imei restored but no network then write cert from another working phone there after repeat operations . change imei =imei cert fail. it does not mean cert is not compatible with the phone but imei check has failed to validate cert with phone cpid. I tested this on s7 I wrote another cert theen ntwk lost until I restore imei then ntwk was there without patch cert. try and post |
. Quote:
u tried till hwid lost ?? WHAT IS THE HAKE !! |
Finally Got my Phone Working Again..... Very Thankful to you. |
re-do steps carefully |
I will make another post for g532g and m soon |
