-   Samsung Android based phones (http://forum.gsmhosting.com/vbb/f777/)
-   -   [Guide] G532F IMEI REPAIR SOLUTION ONLY HERE (http://forum.gsmhosting.com/vbb/f777/guide-g532f-imei-repair-solution-only-here-2233699/)
mastana_dk 10-11-2017 09:17
10000%
thank you my phone work agen
mahi20015 10-11-2017 12:09
-----{ ALNAJAT -- SOFT -- TEAM }------
((\/\))-- BY BASEL ALZOUBI --((/\/))
__________________________________________________ ______________________________
CONNECT A SM-G532F WITH ROOT ACCESS FOR IMEI REPAIR
PRESS ANY KEY WHEN YOU READY
Press any key to continue . . .
Android Debug Bridge version 1.0.31
-d - directs command to the only connected USB devic
e
returns an error if more than one USB device is
present.
-e - directs command to the only running emulator.
returns an error if more than one emulator is r
unning.
-s <specific device> - directs command to the device or emulator with
the given
serial number or qualifier. Overrides ANDROID_S
ERIAL
environment variable.
-p <product name or path> - simple product name like 'sooner', or
a relative/absolute path to a product
out directory like 'out/target/product/sooner'.
If -p is not specified, the ANDROID_PRODUCT_OUT
environment variable is used, which must
be an absolute path.
devices [-l] - list all connected devices
('-l' will also list device qualifiers)
connect <host>[:<port>] - connect to a device via TCP/IP
Port 5555 is used by default if no port number
is specified.
disconnect [<host>[:<port>]] - disconnect from a TCP/IP device.
is specified.
Using this command with no additional arguments
will disconnect from all connected TCP/IP devic
es.
device commands:
adb push <local> <remote> - copy file/dir to device
adb pull <remote> [<local>] - copy file/dir from device
adb sync [ <directory> ] - copy host->device only if changed
(-l means list but don't copy)
(see 'adb help all')
adb shell - run remote shell interactively
adb shell <command> - run remote shell command
adb emu <command> - run emulator console command
adb logcat [ <filter-spec> ] - View device log
adb forward <local> <remote> - forward socket connections
forward specs are one of:
tcp:<port>
localabstract:<unix domain socket name>
localreserved:<unix domain socket name>
localfilesystem:<unix domain socket name>
dev:<character device name>
jdwp:<process pid> (remote only)
adb jdwp - list PIDs of processes hosting a JDWP transport
adb install [-l] [-r] [-s] [--algo <algorithm name> --key <hex-encoded key> --
iv <hex-encoded iv>] <file>
- push this package file to the device and instal
l it
('-l' means forward-lock the app)
('-r' means reinstall the app, keeping its data
('-s' means install on SD card instead of inter
nal storage)
('--algo', '--key', and '--iv' mean the file is
encrypted already)
adb uninstall [-k] <package> - remove this app package from the device
('-k' means keep the data and cache directories
adb bugreport - return all information from the device
that should be included in a bug report.
adb backup [-f <file>] [-apk|-noapk] [-shared|-noshared] [-all] [-system|-nosy
stem] [<packages...>]
- write an archive of the device's data to <file>
If no -f option is supplied then the data is wr
itten
to "backup.ab" in the current directory.
(-apk|-noapk enable/disable backup of the .apks
themselves
in the archive; the default is noapk.)
(-shared|-noshared enable/disable backup of the
device's
shared storage / SD card contents; the defau
lt is noshared.)
(-all means to back up all installed applicatio
ns)
(-system|-nosystem toggles whether -all automat
ically includes
system applications; the default is to inclu
de system apps)
(<packages...> is the list of applications to b
e backed up. If
the -all or -shared flags are passed, then t
he package
list is optional. Applications explicitly g
iven on the
command line will be included even if -nosys
tem would
ordinarily cause them to be omitted.)
adb restore <file> - restore device contents from the <file> backup
archive
adb help - show this help message
adb version - show version num
scripting:
adb wait-for-device - block until device is online
adb start-server - ensure that there is a server running
adb kill-server - kill the server if it is running
adb get-state - prints: offline | bootloader | device
adb get-serialno - prints: <serial-number>
adb get-devpath - prints: <device-path>
adb status-window - continuously print device status for a specifie
d device
adb remount - remounts the /system partition on the device re
ad-write
adb reboot [bootloader|recovery] - reboots the device, optionally into the boo
tloader or recovery program
adb reboot-bootloader - reboots the device into the bootloader
adb root - restarts the adbd daemon with root permissions
adb usb - restarts the adbd daemon listening on USB
adb tcpip <port> - restarts the adbd daemon listening on TCP on th
e specified port
networking:
adb ppp <tty> [parameters] - Run PPP over USB.
Note: you should not automatically start a PPP connection.
<tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1
[parameters] - Eg. defaultroute debug dump local notty usepeerdns
adb sync notes: adb sync [ <directory> ]
<localdir> can be interpreted in several ways:
- If <directory> is not specified, both /system and /data partitions will be u
pdated.
- If it is "system" or "data", only the corresponding partition
is updated.
environmental variables:
ADB_TRACE - Print debug information. A comma separated list
of the following values
1 or all, adb, sockets, packets, rwx, usb, sync
, sysdeps, transport, jdwp
ANDROID_SERIAL - The serial number to connect to. -s takes prior
ity over this if given.
ANDROID_LOG_TAGS - When used with the logcat option, only these de
bug tags are printed.
- - - - - - - PHONE FOUND .... CHECKING MAGIC .... - - - - - - - -
- - - - - - - - OK ! MAGIC PART 1 START .... - - - - - - -
mount: Permission denied
mahi20015 10-13-2017 09:24
all file deleted
plz upload here without pasword thankss
FISRT DOWNLOAD ALL REQUIRED FILES
1 – IMEI REPAIR TOOL CLICK HERE
2 – ROOT KERNEL + FIRMWARE FOR ROOT CLICK HERE
3 – COMBINATION FIRMWARE CLICK HERE
4- 4 FILES FIRMWARE CLICK HERE (SKIP THIS STEP IF U HAVE FIRMWARE)
PASSWORD : alnajat.co
...:::::NP™:::::... 10-13-2017 10:41
All download link has been correction, soon will be uploaded firmware to another free file hosting server.
Md Ruhul 10-14-2017 13:01
how to imei repair Samsung S8 please help
mr_basel_99 10-15-2017 15:21
No solution for now
if your imei is 0000000000 pm me i have something to try
or you can use online service but its costly
...:::::NP™:::::... 10-15-2017 19:56
@ mr_basel_99,
I can see that the link posted to you is free, but no one can download it 3Gb, but it can be possible downloaded with for any browser downloader.
IDM can't access to allow for your server multi link . Tested by me & most of users try to download with the Internet Download Manager for the reason more user are fail for downloading. so for that i'll post your tools & firmware from IDM supported link.
mahi20015 10-16-2017 06:47
All Download links are here and all are free
G532F | Alnajat Soft
Do not ask anymore for links
pasword error why?
...:::::NP™:::::... 10-16-2017 13:01
@ mahi20015
I think you did not check the first post, and all the link where are changed.
mahi20015 10-18-2017 21:25
g532f
after flash
2- FLASH ROOT KERNEL
now security error
factory boot img signature check fail
mahi20015 10-18-2017 22:16
imei is now original imei is restore
but
now emergency call why??
mdshuvo 10-22-2017 01:58
Thank You Sir. Thank You So Much My Phone SM-G532G/DS ,J2 Prime 100% OK
meziani 10-24-2017 00:02
Root, Flash and Unlock SAMSUNG J2 PRIME G532F, G532M, G532G ANDROID 6.0.1 :
http://www.youtube.com/watch?v=LAOFwpdXHjo&t=1s
satya888 10-26-2017 06:42
This is not working bro pls another solution
naseer_mansehra 11-08-2017 07:39
help
plz g570 solution :confused::confused:
Page generated in 0.31961 seconds with 5 queries
