Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 12-05-2017, 08:51   #76 (permalink)
Member: 2785808
Sonork: 1678634:hardtrow
thanx sir i have this unit same issue now hoping it will work
Old 12-10-2017, 08:56   #77 (permalink)
Yakub Alli's Avatar
Member: 1022144
Sonork: Love in Bangladesh
Thanks Meter: 126
2 – SM-G532F-ROOT_KERNEL FIRMWARE_FOR-ROOT
please this file upload 4share or mega
Old 12-11-2017, 12:51   #78 (permalink)
Member: 2508938
Big thanks mr_basel_99
Old 12-12-2017, 06:19   #79 (permalink)
Member: 1825242
Thanks Meter: 14
plz sir g532g emargency call only fix solution post fast
Old 12-18-2017, 04:14   #80 (permalink)
Member: 220595
Thanks Meter: 258
any solution for g532M
have one with IMEI CERTI FAIL error. so, no network registration at all.
Old 01-03-2018, 18:24   #81 (permalink)
Member: 2795875
the combination is for g532g not for g532f
is it safetly to use in g532f ????
Old 01-03-2018, 20:10   #82 (permalink)
Member: 220595
Thanks Meter: 258
First
try to find combination for g532f
example this:
https://androidfilehost.com/?fid=889964283620760396
Or this:
https://androidfilehost.com/?fid=817906626617941020
Old 01-05-2018, 05:00   #83 (permalink)
Member: 900988
Thanks Meter: 3
hi error flashing in combination
Operation: Flash
Selected model: SM-G532F
Software version: 30.4
File analysis... OK
Total file size: 0x43731A24 (1079 Mb)
Searching USB Flash interface... COM10 detected
Setup connection... OK
Reading PIT from phone... OK
Sending preloader.img... OK
Sending lk.bin... error timeout
Done with Samsung Tool PRO v.30.4
Old 01-05-2018, 06:04   #84 (permalink)
Member: 220595
Thanks Meter: 258
Operation: Flash
File analysis... OK
Which combination are you using and what compilation is running on phone?
Enviado desde mi SM-G930F mediante Tapatalk
Old 01-11-2018, 14:24   #85 (permalink)
Member: 2673061
Thanks Meter: 70
can you dm-verity verification failed g532f model any solution
Old 01-12-2018, 15:27   #86 (permalink)
Member: 2492451
i can't restore imei G532F now does not start phone only samsung logotip
Old 01-13-2018, 08:11   #87 (permalink)
Member: 2784617
thank you
Great solution .. thank you
Old 01-13-2018, 20:39   #88 (permalink)
Member: 2702587
Sonork: 1680225
Thanks Meter: 25
Sir Your Tool Only For This Model Or Another Model Support Have ?Excellent Working Your tool Good Job
Old 01-13-2018, 21:07   #89 (permalink)
Member: 220595
Thanks Meter: 258
I tested this on g532m, with g532m combination, it worked, it restored the original IMEI, but phone is not registering on any network.
and IMEI is NOT BARRED
Still cant find any solution to fix this.
So, the answer is yes, I think it works with other models if you have the right combination
Old 01-27-2018, 10:29   #90 (permalink)
Member: 1703671
Sonork: 100.1627623
Thanks Meter: 17
great work thnx
tested on G532F all is ok
Last edited by ...:::::NP™:::::...; 01-30-2018 at 08:44. Reason: quote has been removed
Page generated in 0.43057 seconds with 7 queries
