Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 05-29-2015, 10:42   #31 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
@madcom5,
for to be precise this is the result of my hard work and test and i haven't used CYNOGED Rom becouse was very bad CRom...if you will have seen all my I9205 repaired with ROM in first post you can see one Very BIG difference in all, Graphic, function itc.... but you are thanked only at words (w/o any Thanks Button), all forum members.....
Remember you that this is FREE procedure elaborate and posted for ALL FORUM Members but is my hard work...not forgot this...and if you have solved at the end...i'm happy that have solved with one my Procedure, (you have want apply any variant), so if also you are Happy start using Thanks button...IT's FREE!!!!!
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 06-15-2015, 22:44   #32 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
new solution without articulate procedures ...
search this Tmobile rom I9205XXUDNJ1
Total wipe and flash
Old 07-17-2015, 12:49   #33 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Question
where can I find this flash file?....found it on z3x support but I can't download it
Old 07-17-2015, 19:45   #34 (permalink)
allumts's Avatar
Member: 1564612
Ask to Mr "orx" that want modific my FREE procedure posted with all DETAILS, flash files itc....
the problem is that many peoples are good to bla bla bla... only later that others have done one Full guide with each thinghs....
why not had answered first when many peoples was posting for this problem?????.....
I not look good who want to be of to know all and at the end not Help or not know nothing... IT'S MY HONEST OPINION About peoples how @orx
allumts
Old 07-18-2015, 06:43   #35 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Wink
allumts
Man, why are you mad? Let me tell you my story:
A client camed to my shop with a fully working i9205 Samsung for a android update 4.2.2 -> 4.4.2 after flash: boot loop. Now i am disperate to repair this phone after following you procedure still the same (After writeing recovery file still bootloop...now I wanted to try that flash file since your repair method didn't helped me.
Old 07-18-2015, 08:33   #36 (permalink)
allumts's Avatar
Member: 1564612
Hi, can be not have explained good for my bad English, but in poor words....i cannot help you with Other Fw and procedure writed from others, this is my Thread with my Procedure Step by Step, tested 100% by Me and full working.
I can help you only with my procedure becouse with only this, after 15/20 days of Hard work i had Success 100% and have shared...so non write that i are Mad ...it's isn' right...my help is in first page Tested on more of 15 of this phone, 100% full working..
allumts
Old 07-18-2015, 09:11   #37 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Thumbs down
didn't helped me,phone still in bootloop:
<ID:0/078> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> BL_I9205XXUDNJ1_CL3056297_QB2707709_REV01_user_low _ship.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<OSM> Please wait..
<OSM> AP_I9205XXUDNJ1_CL3056297_QB2707709_REV01_user_low _ship.tar.md5 is valid.
<OSM> Leave CS..
<OSM> Please wait..
<OSM> CP_I9205XXUDNJ1_CL3056297_QB2707709_REV01_user_low _ship.tar.md5 is valid.
<OSM> Leave CS..
<OSM> Please wait..
<OSM> CSC_DTM_I9205DTMDNJ1_CL3056297_QB2720167_REV01_use r_low_ship.tar.md5 is valid.
<OSM> Leave CS..
<ID:0/078> Odin v.3 engine (ID:78)..
<ID:0/078> File analysis..
<ID:0/078> SetupConnection..
<ID:0/078> Initialzation..
<ID:0/078> Set PIT file..
<ID:0/078> DO NOT TURN OFF TARGET!!
<ID:0/078> Get PIT for mapping..
<ID:0/078> Firmware update start..
<ID:0/078> SingleDownload.
<ID:0/078> aboot.mbn
<ID:0/078> NAND Write Start!!
<ID:0/078> sbl1.mbn
<ID:0/078> sbl2.mbn
<ID:0/078> sbl3.mbn
<ID:0/078> rpm.mbn
<ID:0/078> tz.mbn
<ID:0/078> boot.img
<ID:0/078> recovery.img
<ID:0/078> system.img.ext4
<ID:0/078> persist.img.ext4
<ID:0/078> NON-HLOS.bin
<ID:0/078> Transmission Complete..
<ID:0/078> Now Writing.. Please wait about 2 minutes
<ID:0/078> Receive Response from boot-loader
<ID:0/078> cache.img.ext4
<ID:0/078> hidden.img.ext4
<ID:0/078> RQT_CLOSE !!
<ID:0/078> RES OK !!
<ID:0/078> Removed!!
<ID:0/078> Remain Port .... 0
<OSM> All threads completed. (succeed 1 / failed 0)
Old 07-18-2015, 09:13   #38 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Unhappy
allumts
I don't know what's wrong but I can't repair this phone,and I am sure that's not hardware since after flash this problem appeared...
Old 07-18-2015, 09:40   #39 (permalink)
allumts's Avatar
Member: 1564612
Hi, IT'S SW ISSUE.
You think i not have done 1000 test first of find one Working Procedure?... i'm been crazzy for 20 days or more first of solve this issue...and Forum was full of user with same problem....so i understand that can "seem" one Long procedure...but at the end is 5 min.s of work with All File, ans All Steps, (not bypass only one), with procedure writed in first page.....
I not have more in my shop only one of these model but if enter i know how repair w/o problem and with my procedure...if there's other more speed good for you....
Old 07-24-2015, 11:25   #40 (permalink)
IWT
Member: 2433344
Ok so after a couple of test i can confirm that the allumts procedure may not works with some type of lcd/touch controllers.
The other solution that works is:
- Install official 4.4.2 rom of your country with ODIN
- CWM recovery
- Wipe data/cache
- Install CM11 UNOFFICIAL (cm-11-20140721-UNOFFICIAL-meliusltexx)
- Reboot
The startup screen may be black but after few sec. the CM logo appear and the phone are ready to go. Works all except s-flip cover function (on/off screen)
Old 07-24-2015, 12:10   #41 (permalink)
allumts's Avatar
Member: 1564612
All you are very Lazy i can see...for not download one Big size Rom, BUT SURE WORKING, this: "MegaFireMj2V20XGrandFinale.zip"...and why i do change the first recovery with the TWRP?...easy becouse you must need one FULL CLEAN SYSTEM first of install this above Rom...
If read good and not bypassing Steps...have tryed all you modific have done first of you...but result was always with one issue...or Imei and BB damaged, Wifi not working, "ON/OFF screen not working and many other issues...only after i've done all these steps in guide...have SOLVED all problem but for you one Pilz-Touch and TWRP is the same thingh....this BAD Cyanoged ROM is the same and all mistake for not to have only 15 min.s of pacience and apply all step one by one....
I have lost 20 days of my HARD work for to have this FULL result....but i can see that next time not write any guide becouse at the end my work isn't been valued....
So...please not ask more nothingh about this guide and each one do how want....who want have 100% result not bypass only one step of my guide....good luck
allumts
Old 07-24-2015, 14:44   #42 (permalink)
IWT
Member: 2433344
So there's something that your mind won't understand: there are some phones that works only with the other method, we aren't stupid people right? Your procedure probably doesn't work with all galaxy mega of the world, so please take a breath and return to the earth
In my phone CM11 works without any issue
Your procedure WORKS we are gratefull to you but please we can discuss other method for other people in trouble
Old 07-24-2015, 20:50   #43 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
- CWM recovery
- Wipe data/cache
- Reboot
Indeed the problem was with lcd. That lcd was working only on 4.2.2 with 4.4.2 I was faceing bootloop and downgrade was imposible.
Old 07-27-2015, 07:58   #44 (permalink)
IWT
Member: 2433344
If allumts solution doesn't work the other solution must work: i have a galaxy mega with black screen on boot, allumts solution won't work but CM11 solution works well. Try to install TWRP recovery:
- Enter CWM recovery and install TWRP recovery posted by allumts and reboot
- Enter TWRP recovery and wipe data/cache/system
- Reboot
Old 07-28-2015, 14:56   #45 (permalink)
Member: 2321119
Thanks Meter: 119
i said it before and i will say it again since am not always online just flash ur 9200 with 4.4.2 fw then reflash it with I9200ZNUAMI2 and ur phone will work like a charm with imei and baseband and wifi...ive tested this solution for all 9200 and it never failed me..ive knows this solution long time before allumts posted ur page here but as i told u bro am not always online to share
Page generated in 0.23001 seconds with 8 queries
