Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-17-2011, 03:51 | #1 (permalink) | ||
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | [Guide] Samsung Android - Repair EFS / IMEI WITHOUT BOX Quote:
let's try to solve, but NOT 100% working, i've based only on my GT-P1000. 00 = first root the phone, download ROOT EXPLORER + ADB 01 = extract "ADB_2.0.0.0.rar" to a FOLDER [ c:\adbtools ] 02 = at the command prompt, c:\adbtools\ 03 = type "adb install rootexplorer.apk" and enter, after install 04 = open root explorer, open efs folder 05 = if you can find ".nv_data.bak" then it's possible to RESTORE [ if NONE THEN LEAVE THIS PROCEDURE ] 06 = now, you still need to backup nv_data.bin & .nv_data.bak or folder EFS BEFORE DO ANYTHING [ IF YOU HAVE PREVIOUS BACKUP OF NV_DATA.BIN THEN PROCEED TO 14 ] 07 = at command prompt [ C:\adbtools\ ], type adb shell 08 = type su 09 = type cp /efs/nv_data.bin /sdcard/ 10 = type cp /efs/.nv_data.bak /sdcard/ 11 = type exit & exit 12 = at root explorer, tap sdcard, long tap nv_data.bin, tap rename [ add .BAK ] 13 = long tap .nv_data.bak, tap rename, type nv_data.bin 14 = at command prompt [ C:\adbtools\ ], type adb shell 15 = type su 16 = type cp /sdcard/nv_data.bin 17 = type rm -rf /efs/nv_data.bin.md5 18 = type exit & exit 19 = REBOOT YOUR PHONE Quote:
WARNING ! ! ! I take no responsibility to any damage caused by the methods written here, DO AT YOUR OWN RISK ! ! ! REMINDER ! ! ! ALWAYS BACKUP YOUR EFS FOLDER BEFORE DO ANYTHING ELSE br 1275836697d9d39d5b1e3dc16f1b2cf28829f1197d [ DropBox ] [ iPad / GT-P1000 / x10 Mini / x8 ] Last edited by wgmmmx1; 04-22-2022 at 10:29. | ||
The Following 15 Users Say Thank You to RNC_EBM For This Useful Post: |
09-19-2011, 04:42 | #4 (permalink) |
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | BELOW MY LOGO br 1275836697d9d39d5b1e3dc16f1b2cf28829f1197d [ DropBox ] [ iPad / GT-P1000 / x10 Mini / x8 ] |
The Following User Says Thank You to RNC_EBM For This Useful Post: |
10-31-2011, 17:37 | #5 (permalink) |
Freak Poster Join Date: Aug 2011 Location: SFR
Member: 1633151 Status: Offline Sonork: SFR-_-MAN Thanks Meter: 72 | Code: E:\Documents and Settings\Administrateur> e:\adbtools\adb.exe Android Debug Bridge version 1.0.26 -d - directs command to the only connected USB device returns an error if more than one USB device is present. -e - directs command to the only running emulator. returns an error if more than one emulator is running. -s <serial number> - directs command to the USB device or emulator with the given serial number. Overrides ANDROID_SERIAL environment variable. -p <product name or path> - simple product name like 'sooner', or a relative/absolute path to a product out directory like 'out/target/product/sooner'. If -p is not specified, the ANDROID_PRODUCT_OUT environment variable is used, which must be an absolute path. devices - list all connected devices connect <host>[:<port>] - connect to a device via TCP/IP Port 5555 is used by default if no port number is specified. disconnect [<host>[:<port>]] - disconnect from a TCP/IP device. Port 5555 is used by default if no port number is specified. Using this ocmmand with no additional arguments will disconnect from all connected TCP/IP devices. device commands: adb push <local> <remote> - copy file/dir to device adb pull <remote> [<local>] - copy file/dir from device adb sync [ <directory> ] - copy host->device only if changed (-l means list but don't copy) (see 'adb help all') adb shell - run remote shell interactively adb shell <command> - run remote shell command adb emu <command> - run emulator console command adb logcat [ <filter-spec> ] - View device log adb forward <local> <remote> - forward socket connections forward specs are one of: tcp:<port> localabstract:<unix domain socket name> localreserved:<unix domain socket name> localfilesystem:<unix domain socket name> dev:<character device name> jdwp:<process pid> (remote only) adb jdwp - list PIDs of processes hosting a JDWP transport adb install [-l] [-r] [-s] <file> - push this package file to the device and install it ('-l' means forward-lock the app) ('-r' means reinstall the app, keeping its data) ('-s' means install on SD card instead of internal storage) adb uninstall [-k] <package> - remove this app package from the device ('-k' means keep the data and cache directories) adb bugreport - return all information from the device that should be included in a bug report. adb help - show this help message adb version - show version num DATAOPTS: (no option) - don't touch the data partition -w - wipe the data partition -d - flash the data partition scripting: adb wait-for-device - block until device is online adb start-server - ensure that there is a server running adb kill-server - kill the server if it is running adb get-state - prints: offline | bootloader | device adb get-serialno - prints: <serial-number> adb status-window - continuously print device status for a specified device adb remount - remounts the /system partition on the device read-write adb reboot [bootloader|recovery] - reboots the device, optionally into the bootloader or recovery program adb reboot-bootloader - reboots the device into the bootloader adb root - restarts the adbd daemon with root permissions adb usb - restarts the adbd daemon listening on USB adb tcpip <port> - restarts the adbd daemon listening on TCP on the specified port networking: adb ppp <tty> [parameters] - Run PPP over USB. Note: you should not automatically start a PPP connection. <tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1 [parameters] - Eg. defaultroute debug dump local notty usepeerdns adb sync notes: adb sync [ <directory> ] <localdir> can be interpreted in several ways: - If <directory> is not specified, both /system and /data partitions will be updated. - If it is "system" or "data", only the corresponding partition is updated. environmental variables: ADB_TRACE - Print debug information. A comma separated list of the following values 1 or all, adb, sockets, packets, rwx, usb, sync, sysdeps, transport, jdwp ANDROID_SERIAL - The serial number to connect to. -s takes priority over this if given. ANDROID_LOG_TAGS - When used with the logcat option, only these debug tags are printed. E:\Documents and Settings\Administrateur>adb install rootexplorer.apk can't find 'rootexplorer.apk' to install E:\Documents and Settings\Administrateur>e:\adbtools\adb.exe Android Debug Bridge version 1.0.26 -d - directs command to the only connected USB device returns an error if more than one USB device is present. -e - directs command to the only running emulator. returns an error if more than one emulator is running. -s <serial number> - directs command to the USB device or emulator with the given serial number. Overrides ANDROID_SERIAL environment variable. -p <product name or path> - simple product name like 'sooner', or a relative/absolute path to a product out directory like 'out/target/product/sooner'. If -p is not specified, the ANDROID_PRODUCT_OUT environment variable is used, which must be an absolute path. devices - list all connected devices connect <host>[:<port>] - connect to a device via TCP/IP Port 5555 is used by default if no port number is specified. disconnect [<host>[:<port>]] - disconnect from a TCP/IP device. Port 5555 is used by default if no port number is specified. Using this ocmmand with no additional arguments will disconnect from all connected TCP/IP devices. device commands: adb push <local> <remote> - copy file/dir to device adb pull <remote> [<local>] - copy file/dir from device adb sync [ <directory> ] - copy host->device only if changed (-l means list but don't copy) (see 'adb help all') adb shell - run remote shell interactively adb shell <command> - run remote shell command adb emu <command> - run emulator console command adb logcat [ <filter-spec> ] - View device log adb forward <local> <remote> - forward socket connections forward specs are one of: tcp:<port> localabstract:<unix domain socket name> localreserved:<unix domain socket name> localfilesystem:<unix domain socket name> dev:<character device name> jdwp:<process pid> (remote only) adb jdwp - list PIDs of processes hosting a JDWP transport adb install [-l] [-r] [-s] <file> - push this package file to the device and install it ('-l' means forward-lock the app) ('-r' means reinstall the app, keeping its data) ('-s' means install on SD card instead of internal storage) adb uninstall [-k] <package> - remove this app package from the device ('-k' means keep the data and cache directories) adb bugreport - return all information from the device that should be included in a bug report. adb help - show this help message adb version - show version num DATAOPTS: (no option) - don't touch the data partition -w - wipe the data partition -d - flash the data partition scripting: adb wait-for-device - block until device is online adb start-server - ensure that there is a server running adb kill-server - kill the server if it is running adb get-state - prints: offline | bootloader | device adb get-serialno - prints: <serial-number> adb status-window - continuously print device status for a specified device adb remount - remounts the /system partition on the device read-write adb reboot [bootloader|recovery] - reboots the device, optionally into the bootloader or recovery program adb reboot-bootloader - reboots the device into the bootloader adb root - restarts the adbd daemon with root permissions adb usb - restarts the adbd daemon listening on USB adb tcpip <port> - restarts the adbd daemon listening on TCP on the specified port networking: adb ppp <tty> [parameters] - Run PPP over USB. Note: you should not automatically start a PPP connection. <tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1 [parameters] - Eg. defaultroute debug dump local notty usepeerdns adb sync notes: adb sync [ <directory> ] <localdir> can be interpreted in several ways: - If <directory> is not specified, both /system and /data partitions will be updated. - If it is "system" or "data", only the corresponding partition is updated. environmental variables: ADB_TRACE - Print debug information. A comma separated list of the following values 1 or all, adb, sockets, packets, rwx, usb, sync, sysdeps, transport, jdwp ANDROID_SERIAL - The serial number to connect to. -s takes priority over this if given. ANDROID_LOG_TAGS - When used with the logcat option, only these debug tags are printed. E:\Documents and Settings\Administrateur> 03 = type "adb install rootexplorer.apk" and enter, after install not work for me E:\Documents and Settings\Administrateur> adb install rootexplorer.apk can't find 'rootexplorer.apk' to install E:\Documents and Settings\Administrateur> |
10-31-2011, 19:48 | #6 (permalink) |
Crazy Poster Join Date: Jan 2003 Location: Namibia Age: 45
Member: 20626 Status: Offline Thanks Meter: 5 | samsung android phones i want to find out whether there is a box to repair "too many pattern attempts" which one can buy thnx |
The Following User Says Thank You to romelod7 For This Useful Post: |
10-31-2011, 23:26 | #7 (permalink) | ||
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Quote:
or flash it using ODIN br [ DropBox ] [ iPad / SGS-i9000 / GT-P1000 / iPhone ] | ||
11-01-2011, 01:21 | #8 (permalink) | |
Member: 1633151 Status: Offline Sonork: SFR-_-MAN Thanks Meter: 72 | Quote:
yes is same folder adb & rootexplorer | |
11-01-2011, 01:33 | #9 (permalink) |
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Last edited by ...:::::NP™:::::...; 06-22-2017 at 17:20. Reason: Download link added |
11-01-2011, 04:08 | #11 (permalink) |
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | at command [ CMD ] prompt go exactly to directory where you extracted [ according to your screenshot ] e:\cd\adbtools e:\adbtools\adb install rootexplorer.apk then enter br [ DropBox ] [ iPad / SGS-i9000 / GT-P1000 / iPhone ] |
11-02-2011, 00:31 | #12 (permalink) | |
don't have nv_data backup & want to have NETWORK [ SIGNAL ] then follow this [ Samsung Android ] IMEI 00000000000000 TO 004999010640000 br [ DropBox ] [ iPad / SGS-i9000 / GT-P1000 / iPhone ] | |
The Following 2 Users Say Thank You to RNC_EBM For This Useful Post: |
11-12-2011, 11:51 | #14 (permalink) | |
remove thru ROOT EXPLORER br [ DropBox ] [ iPad1_3G-5.0 / SGS-i9000-2.3.5 / GT-P1000-2.3.5 / iPhone3G-4.2.1 ] | |
11-16-2011, 05:00 | #15 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Darwin Northern Teretory Age: 40
Member: 136173 Status: Offline Sonork: 108426:ind Thanks Meter: 97 | Quote:
root explorer also says error.... read only file | |
The Following User Says Thank You to zipzap_kill For This Useful Post: |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
