Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 09-17-2011, 03:51   #1 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
Thanks Meter: 6,036
[Guide] Samsung Android - Repair EFS / IMEI WITHOUT BOX
PROBLEM:
•Fake IMEI (usually 004999010640000)
•Unable to download apps from the market
•Unable to unlock your SIM card using your PIN
•Weird apps are downloading automatically from the market
•Blinking SIM card icon on the top tray… ETC
let's try to solve, but NOT 100% working, i've based only on my GT-P1000.
00 = first root the phone, download ROOT EXPLORER + ADB
01 = extract "ADB_2.0.0.0.rar" to a FOLDER [ c:\adbtools ]
02 = at the command prompt, c:\adbtools\
03 = type "adb install rootexplorer.apk" and enter, after install
04 = open root explorer, open efs folder
05 = if you can find ".nv_data.bak" then it's possible to RESTORE [ if NONE THEN LEAVE THIS PROCEDURE ]
06 = now, you still need to backup nv_data.bin & .nv_data.bak or folder EFS BEFORE DO ANYTHING
[ IF YOU HAVE PREVIOUS BACKUP OF NV_DATA.BIN THEN PROCEED TO 14 ]
07 = at command prompt [ C:\adbtools\ ], type adb shell
08 = type su
09 = type cp /efs/nv_data.bin /sdcard/
10 = type cp /efs/.nv_data.bak /sdcard/
11 = type exit & exit
12 = at root explorer, tap sdcard, long tap nv_data.bin, tap rename [ add .BAK ]
13 = long tap .nv_data.bak, tap rename, type nv_data.bin
14 = at command prompt [ C:\adbtools\ ], type adb shell
15 = type su
16 = type cp /sdcard/nv_data.bin
17 = type rm -rf /efs/nv_data.bin.md5
18 = type exit & exit
19 = REBOOT YOUR PHONE
**The md5 hash/signature (nv_data.bin.md5) is removed (rm) as the system will generate a new one.
**Most likely your SIM code won’t work after this and you won’t be able to log into the phone**
Pop off your SIM card, boot your phone and execute the following commands to change ownership of the file under ADB
= type su
= type chown 1001:1001 /efs/nv_data.bin
WARNING ! ! !
I take no responsibility to any damage caused by the methods written here,
DO AT YOUR OWN RISK ! ! !
REMINDER ! ! !
ALWAYS BACKUP YOUR EFS FOLDER
BEFORE DO ANYTHING ELSE
br
1275836697d9d39d5b1e3dc16f1b2cf28829f1197d
[ DropBox ] [ iPad / GT-P1000 / x10 Mini / x8 ]
The Following 15 Users Say Thank You to RNC_EBM For This Useful Post:
Old 09-19-2011, 03:09   #2 (permalink)
Member: 322618
Thanks Meter: 5
ADB_2.0.0.0.rar password
The Following User Says Thank You to why_no For This Useful Post:
Old 09-19-2011, 03:43   #3 (permalink)
Temporary banned !!
Member: 1151970
Sonork: 100.1597000
Thanks Meter: 378
password................
The Following User Says Thank You to KIKO_GSM For This Useful Post:
Old 09-19-2011, 04:42   #4 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
BELOW MY LOGO
br
The Following User Says Thank You to RNC_EBM For This Useful Post:
Old 10-31-2011, 17:37   #5 (permalink)
SFR-_-MAN's Avatar
Member: 1633151
Sonork: SFR-_-MAN
Thanks Meter: 72
E:\Documents and Settings\Administrateur> e:\adbtools\adb.exe
Android Debug Bridge version 1.0.26
 -d                            - directs command to the only connected USB device
                                 returns an error if more than one USB device is present.
 -e                            - directs command to the only running emulator.
                                 returns an error if more than one emulator is running.
 -s <serial number>            - directs command to the USB device or emulator with
                                 the given serial number. Overrides ANDROID_SERIAL
                                 environment variable.
 -p <product name or path>     - simple product name like 'sooner', or
                                 a relative/absolute path to a product
                                 out directory like 'out/target/product/sooner'.
                                 If -p is not specified, the ANDROID_PRODUCT_OUT
                                 environment variable is used, which must
                                 be an absolute path.
 devices                       - list all connected devices
 connect <host>[:<port>]       - connect to a device via TCP/IP
                                 Port 5555 is used by default if no port number is specified.
 disconnect [<host>[:<port>]]  - disconnect from a TCP/IP device.
                                 Using this ocmmand with no additional arguments
                                 will disconnect from all connected TCP/IP devices.
device commands:
  adb push <local> <remote>    - copy file/dir to device
  adb pull <remote> [<local>]  - copy file/dir from device
  adb sync [ <directory> ]     - copy host->device only if changed
                                 (-l means list but don't copy)
                                 (see 'adb help all')
  adb shell                    - run remote shell interactively
  adb shell <command>          - run remote shell command
  adb emu <command>            - run emulator console command
  adb logcat [ <filter-spec> ] - View device log
  adb forward <local> <remote> - forward socket connections
                                 forward specs are one of:
                                   tcp:<port>
                                   localabstract:<unix domain socket name>
                                   localreserved:<unix domain socket name>
                                   localfilesystem:<unix domain socket name>
                                   dev:<character device name>
                                   jdwp:<process pid> (remote only)
  adb jdwp                     - list PIDs of processes hosting a JDWP transport
  adb install [-l] [-r] [-s] <file> - push this package file to the device and install it
                                 ('-l' means forward-lock the app)
                                 ('-r' means reinstall the app, keeping its data)
                                 ('-s' means install on SD card instead of internal storage)
  adb uninstall [-k] <package> - remove this app package from the device
                                 ('-k' means keep the data and cache directories)
  adb bugreport                - return all information from the device
                                 that should be included in a bug report.
  adb help                     - show this help message
  adb version                  - show version num
DATAOPTS:
 (no option)                   - don't touch the data partition
  -w                           - wipe the data partition
  -d                           - flash the data partition
scripting:
  adb wait-for-device          - block until device is online
  adb start-server             - ensure that there is a server running
  adb kill-server              - kill the server if it is running
  adb get-state                - prints: offline | bootloader | device
  adb get-serialno             - prints: <serial-number>
  adb status-window            - continuously print device status for a specified device
  adb remount                  - remounts the /system partition on the device read-write
  adb reboot [bootloader|recovery] - reboots the device, optionally into the bootloader or recovery program
  adb reboot-bootloader        - reboots the device into the bootloader
  adb root                     - restarts the adbd daemon with root permissions
  adb usb                      - restarts the adbd daemon listening on USB
  adb tcpip <port>             - restarts the adbd daemon listening on TCP on the specified port
networking:
  adb ppp <tty> [parameters]   - Run PPP over USB.
 Note: you should not automatically start a PPP connection.
 <tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1
 [parameters] - Eg. defaultroute debug dump local notty usepeerdns
adb sync notes: adb sync [ <directory> ]
  <localdir> can be interpreted in several ways:
  - If <directory> is not specified, both /system and /data partitions will be updated.
  - If it is "system" or "data", only the corresponding partition
    is updated.
environmental variables:
  ADB_TRACE                    - Print debug information. A comma separated list of the following values
                                 1 or all, adb, sockets, packets, rwx, usb, sync, sysdeps, transport, jdwp
  ANDROID_SERIAL               - The serial number to connect to. -s takes priority over this if given.
  ANDROID_LOG_TAGS             - When used with the logcat option, only these debug tags are printed.
E:\Documents and Settings\Administrateur>adb install rootexplorer.apk
can't find 'rootexplorer.apk' to install
E:\Documents and Settings\Administrateur>e:\adbtools\adb.exe
device commands:
                                   tcp:<port>
DATAOPTS:
scripting:
networking:
    is updated.
03 = type "adb install rootexplorer.apk" and enter, after install not work for me
E:\Documents and Settings\Administrateur> adb install rootexplorer.apk
Old 10-31-2011, 19:48   #6 (permalink)
Crazy Poster
Member: 20626
Thanks Meter: 5
samsung android phones
i want to find out whether there is a box to repair "too many pattern attempts" which one can buy
thnx
The Following User Says Thank You to romelod7 For This Useful Post:
Old 10-31-2011, 23:26   #7 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
device commands:
                                   tcp:<port>
DATAOPTS:
scripting:
networking:
    is updated.
device commands:
                                   tcp:<port>
DATAOPTS:
scripting:
networking:
    is updated.
must be the same folder where adb & rootexplorer located
thnx
goto RECOVERY MODE then "wipe data"
or
flash it using ODIN
br
[ DropBox ] [ iPad / SGS-i9000 / GT-P1000 / iPhone ]
Old 11-01-2011, 01:21   #8 (permalink)
SFR-_-MAN's Avatar
Member: 1633151
Sonork: SFR-_-MAN
Thanks Meter: 72
or
flash it using ODIN
br
yes is same folder adb & rootexplorer
Old 11-01-2011, 01:33   #9 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
check filename of apk
br
Root explore.apk
Last edited by ...:::::NP™:::::...; 06-22-2017 at 17:20. Reason: Download link added
Old 11-01-2011, 02:06   #10 (permalink)
SFR-_-MAN's Avatar
Member: 1633151
Sonork: SFR-_-MAN
Thanks Meter: 72
thank you for help but is same folder
The Following User Says Thank You to SFR-_-MAN For This Useful Post:
Old 11-01-2011, 04:08   #11 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
at command [ CMD ] prompt
go exactly to directory where you extracted
[ according to your screenshot ]
e:\cd\adbtools
e:\adbtools\adb install rootexplorer.apk then enter
br
Old 11-02-2011, 00:31   #12 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
BUT if you phone has IMEI: 000000000000000 and ALSO
don't have nv_data backup & want to have NETWORK [ SIGNAL ]
then follow this
[ Samsung Android ] IMEI 00000000000000 TO 004999010640000
br
The Following 2 Users Say Thank You to RNC_EBM For This Useful Post:
Old 11-12-2011, 11:18   #13 (permalink)
Member: 1687876
Sonork: Rajey Ambito
when im doing step 17 = type rm -rf /efs/nv_data.bin.md5
it says:
rm failed for -rf, Read-only file system
what should I do?
Old 11-12-2011, 11:51   #14 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
it says:
what should I do?
if you CAN'T Remove,
remove thru ROOT EXPLORER
br
[ DropBox ] [ iPad1_3G-5.0 / SGS-i9000-2.3.5 / GT-P1000-2.3.5 / iPhone3G-4.2.1 ]
Old 11-16-2011, 05:00   #15 (permalink)
zipzap_kill's Avatar
Member: 136173
Sonork: 108426:ind
Thanks Meter: 97
br
root explorer also says error....
read only file
The Following User Says Thank You to zipzap_kill For This Useful Post:
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-01-2015 11:49
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.45749 seconds with 10 queries
