Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 11-16-2011, 11:08   #16 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
Thanks Meter: 6,036
Originally Posted by zipzap_kill View Post
root explorer also says error....
read only file
you can SEE on top, r/o, tap MOUNT R/W
then you can remove now the file.
br
[ DropBox ] [ iPad1_3G-5.0 / SGS-i9000-2.3.5 / GT-P1000-2.3.5 / iPhone3G-4.2.1 / iPod Touch 4 -5.0.1 ]
Old 11-20-2011, 10:16   #17 (permalink)
Member: 1692494
br
hey my friend. need your help. I'm using Galaxy s2. last night i lost my network and when i checked, saw that my imei was missing. i have a few EFS backups from siyah kernel and Foxhound. i tried to restore them using a tool called efs pro. it says successfully flashed my backup but i see that half of the files in the backup folder are missing in the restored efs folder. my imei number has also changed to a new one and still no network.
is it possible to restore the efs backup( .tar.gz, made by siyah). tried to odin it but odin doesn't recognize the backup.
i am unable to mount adb as it says ",,not an internal command,,," every time
Old 11-20-2011, 22:34   #18 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
IF it was from OTHER phone, then you'll get OTHER IMEI but after resetting the phone your IMEI will be 000000000000000, that's why their is NO NETWORK.
after REPLACING/RESTORE NVDATA.BIN , delete nv_data.bin.md5 [ see this #17 to #19 ]
note:
if NVDATA from other phone, you'll get MEI 004999010640000
but if NVDATA from phone original BACKUP, you'll get the ORIGINAL IMEI
OTHER INFO
[ Samsung Android ] IMEI 00000000000000 TO 004999010640000
br
Old 11-28-2011, 14:47   #19 (permalink)
Member: 1697088
Hi, I tried to click the MOUNT R/W button but it is still in r/o mode. In other folders I can freely set it to r/w.
Old 12-13-2011, 14:48   #20 (permalink)
Member: 667941
Sonork: 100.1611812
Thanks Meter: 61
Nice post brother. but can you tell me its working on samsung i9100 also .there is no imei even 0000 or any fake imei its null(blank.) i but all box to repair that but all is same .....i have z3x ,,spt,,,octopus..etc..
can you help me that how can i repair imei.i9100 no nv data file inside or no .nv_bak.bin ....
Old 12-13-2011, 22:13   #21 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
http://forum.gsmhosting.com/vbb/f606...000-a-1372464/
br
[ DropBox ] [ iPad1_3G-5.0.1 / SGS-i9000-JVZ-2.3.6 / iPhone3G-4.2.1 / iPod Touch 4 -5.0.1 ]
The Following User Says Thank You to RNC_EBM For This Useful Post:
Old 01-05-2012, 17:55   #22 (permalink)
Member: 1709322
Thumbs up Fix IMEI 00000000000000 to 004999010640000
I've tried everything so far and could not get anywhere.
However at one stage I thought I'd try something unusual and it did work
Samsung Galaxy i9000 Model Number GT-I9000
Firmware Version: 2.3.6
Basisband Version: I9000XXJVT
Kernel Version: 2.6.35.7-I9000XWJVZ-CL762604 root@DELL145 #2
Buildnumber: GINGERBREAD XWJW1
My old IMEI 00000000000000 changed to 004999010640000 with this "trick"
- root the phone
- install rootexplorer.apk
- mount / directory R/W (root directory)
- go to /efs directory and long tap on it
- tap delete
Pull battery and re-insert to make sure that directory is created newly and NOT copied from cache.
- reboot in recovery mode (press VOL-UP - OK - ON at the same time)
- wipe cache data
- reboot phone
After reboot your IMEI should be 004999010640000
Good luck
The Following User Says Thank You to promotec For This Useful Post:
Old 02-14-2012, 19:00   #23 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
how to install arabic lang into sumsong andriod metropcs sch-r910 please
Old 02-19-2012, 18:33   #24 (permalink)
Member: 376268
Fix corrupt IMEI on galaxy s
I have the IMEI corrupted ( 004999010640000). As a result I can't register t network in India. I don't have the original EFS backed as well. Is there any way to restore the IMEI to original one or flash a IMEI of a defective phone (which I own and is dead now)?
Pls help guys.
Old 02-22-2012, 09:31   #25 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
br
[IMG]http://i72.photobucket.com/albums/i182/*******/*******_LINK.jpg[/IMG]
bro links not working fat one
Old 02-27-2012, 15:31   #26 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
samsung m250s working efs need
Old 04-21-2012, 14:13   #27 (permalink)
Member: 1750403
help
i made a silly mistake of overwriting my efs on my sgs2 with a sgs efs and now i have a empty efs and no backup. can someone be a gem and send me a working copy of their efs folder please
Old 04-30-2012, 16:15   #28 (permalink)
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
Wink
if you CAN'T Remove,
remove thru ROOT EXPLORER
br
[ DropBox ] [ iPad1_3G-5.0 / SGS-i9000-2.3.5 / GT-P1000-2.3.5 / iPhone3G-4.2.1 ]
hi sir i need you help i have p 6200 ime 004999010640000 how to repair that i root the phone now what i do pls help me
Old 04-30-2012, 16:23   #29 (permalink)
Crazy Poster
Member: 534840
Thanks Meter: 3
password................
Old 05-01-2012, 15:48   #30 (permalink)
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
no replay no one can ? how to repair that problem ?
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-01-2015 11:49
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.23645 seconds with 10 queries
