Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
07-30-2012, 08:46 | #33 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Motalib Plaza,Dhaka,Bangladesh Age: 39
Member: 485407 Status: Offline Sonork: 100.1580486 Thanks Meter: 183 | |
08-06-2012, 04:46 | #35 (permalink) |
Major Poster Join Date: Apr 2010
Member: 1276228 Status: Offline Thanks Meter: 2 | tanks dude ΨāH gōōÐ m£τHōÐ Fō® S9100 ®£©ōV£® ím£í becose í HāV£ ÐōÑ£ íτ.. ßúτ úSíÑg £S £×PLō®£® Ñōτ ®ōōτ £× PLō®£®.. woh to mount your fhone sd card there is no option to mount in root explorerfirst you have to done mount your sd ©ā®Ð τH£Ñ Ψōú ®£Ñām£ ÑV Ðāτā τō āÑōτH£®. Hōw τō mōúÑτ gō S£ττíÑg íÑ £S £×PLō®£® τH£®£ íS ōPτíōÑ mōúÑτ ō® úÑmōúÑτ SÐ ©ā®Ð |
08-06-2012, 06:00 | #36 (permalink) |
Member: 1276228 Status: Offline Thanks Meter: 2 | how to recover imei in android device....... first root your device then you get super user and terminal emulator app open terminal emulator than type su get super user athority then press enter enter for example your imei like 123456789012345 will be write this code echo 'AT+EGMR=1,7,"123456789012345"' >/dev/pttycmd1 and enter 12345----------- thisis a example you use your orignel imei have good luck |
08-06-2012, 06:04 | #37 (permalink) | |
Member: 1276228 Status: Offline Thanks Meter: 2 | how to recover imei in your android device Quote:
first root your device then you get super user and terminal emulator app open terminal emulator than type su get super user athority then press enter enter for example your imei like 123456789012345 will be write this code echo 'AT+EGMR=1,7,"123456789012345"' >/dev/pttycmd1 and enter 12345----------- thisis a example you use your orignel imei have good luck | |
09-03-2012, 06:46 | #38 (permalink) |
No Life Poster Join Date: Jan 2012
Member: 1713296 Status: Offline Thanks Meter: 67 | HiHi after using this toturial , My phone cannot connect as Diagnostic port and my imei became null and baseband became unkown Any solution to came back diagnositic although in setting usb debug mode is active. I also do a fresh firmware update but failed. plsssss help me |
11-09-2012, 08:47 | #40 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Quote:
Hi, This file does not exist, the access to the following file is limited or it has been removed due to infringement of copyright. | |
03-17-2013, 16:17 | #45 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | How to solve Emergency Mode (boot damage) to Download mode in Galaxy without a Jtag or JIG/JACK+Resistense I can read only a Diagnostic Serial port in the hardware profile. Is posible change this mode via software..? Tnks for all Polaco |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
