Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Android based phones
Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 06-15-2012, 21:31   #31 (permalink)
orangade's Avatar
Member: 521955
Link of root explorer is dead, re-up please, thanks.
Old 07-11-2012, 09:29   #32 (permalink)
Crazy Poster
Member: 1448439
thank you very much.
Old 07-30-2012, 08:46   #33 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
u need this one?
rootexplorer.zip
Old 08-06-2012, 03:22   #34 (permalink)
Member: 1260512
Sonork: 100.1605447
all user pls upload this file for me
ADB_2.0.0.0.rar i can't download it
thanks
Old 08-06-2012, 04:46   #35 (permalink)
Member: 1276228
tanks dude
ΨāH gōōÐ m£τHōÐ Fō® S9100 ®£©ōV£® ím£í becose í HāV£ ÐōÑ£ íτ.. ßúτ úSíÑg
£S £×PLō®£® Ñōτ ®ōōτ £× PLō®£®..
woh to mount your fhone sd card there is no option to mount in root explorerfirst you have to done mount your sd ©ā®Ð τH£Ñ Ψōú ®£Ñām£
ÑV Ðāτā τō āÑōτH£®. Hōw τō mōúÑτ gō S£ττíÑg íÑ £S £×PLō®£® τH£®£ íS ōPτíōÑ mōúÑτ ō® úÑmōúÑτ SÐ ©ā®Ð
Old 08-06-2012, 06:00   #36 (permalink)
Member: 1276228
how to recover imei in android device.......
first root your device then you get super user and terminal emulator app
open terminal emulator than type su get super user athority then press enter enter
for example your imei like 123456789012345 will be write this code
echo 'AT+EGMR=1,7,"123456789012345"' >/dev/pttycmd1 and enter
12345----------- thisis a example you use your orignel imei have good luck
Old 08-06-2012, 06:04   #37 (permalink)
Member: 1276228
how to recover imei in your android device
thanks
Old 09-03-2012, 06:46   #38 (permalink)
Member: 1713296
Sonork: 100.1583845
HiHi after using this toturial , My phone cannot connect as Diagnostic port and my imei became null and baseband became unkown Any solution to came back diagnositic although in setting usb debug mode is active. I also do a fresh firmware update but failed. plsssss help me
Old 09-10-2012, 11:58   #39 (permalink)
Member: 1806369
ADB_2.0.0.0.rar any chance of a working download please, need to get this phone imei back in
Old 11-09-2012, 07:47   #40 (permalink)
..::CHAIN::..'s Avatar
Member: 1753928
Sonork: 100.1615906
Talking
Originally Posted by ******* View Post
PROBLEM:
let's try to solve, but NOT 100% working, i've based only on my GT-P1000.
00 = first root the phone, download ROOT EXPLORER + ADB
01 = extract "ADB_2.0.0.0.rar" to a FOLDER [ c:\adbtools ]
02 = at the command prompt, c:\adbtools\
03 = type "adb install rootexplorer.apk" and enter, after install
04 = open root explorer, open efs folder
05 = if you can find ".nv_data.bak" then it's possible to RESTORE [ if NONE THEN LEAVE THIS PROCEDURE ]
06 = now, you still need to backup nv_data.bin & .nv_data.bak or folder EFS BEFORE DO ANYTHING
[ IF YOU HAVE PREVIOUS BACKUP OF NV_DATA.BIN THEN PROCEED TO 14 ]
07 = at command prompt [ C:\adbtools\ ], type adb shell
08 = type su
09 = type cp /efs/nv_data.bin /sdcard/
10 = type cp /efs/.nv_data.bak /sdcard/
11 = type exit & exit
12 = at root explorer, tap sdcard, long tap nv_data.bin, tap rename [ add .BAK ]
13 = long tap .nv_data.bak, tap rename, type nv_data.bin
14 = at command prompt [ C:\adbtools\ ], type adb shell
15 = type su
16 = type cp /sdcard/nv_data.bin
17 = type rm -rf /efs/nv_data.bin.md5
18 = type exit & exit
19 = REBOOT YOUR PHONE
WARNING ! ! !
I take no responsibility to any damage caused by the methods written here,
DO AT YOUR OWN RISK ! ! !
REMINDER ! ! !
ALWAYS BACKUP YOUR EFS FOLDER
BEFORE DO ANYTHING ELSE
br
[IMG]http://i72.photobucket.com/albums/i182/*******/*******_LINK.jpg[/IMG]
1275836697d9d39d5b1e3dc16f1b2cf28829f1197d
[ DropBox ] [ iPad / GT-P1000 / x10 Mini / x8 ]
Hi,
This file does not exist, the access to the following file is limited or it has been removed due to infringement of copyright.
Old 11-25-2012, 02:02   #41 (permalink)
boce's Avatar
Member: 77923
thanks good jobe >>>....
Old 01-11-2013, 21:26   #42 (permalink)
Member: 1027187
This can repair serial number from 00000000000?
I will try now on SG S2...
Old 03-14-2013, 11:12   #43 (permalink)
Member: 985484
Originally Posted by romelod7 View Post
i want to find out whether there is a box to repair "too many pattern attempts" which one can buy
thnx
use spt box from gsm solution
Old 03-17-2013, 15:18   #44 (permalink)
myu
Member: 830735
How repair ESN or MEID korean phone S2 M250L?
Old 03-17-2013, 16:17   #45 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
How to solve Emergency Mode (boot damage) to Download mode in Galaxy without a Jtag or JIG/JACK+Resistense
I can read only a Diagnostic Serial port in the hardware profile. Is posible change this mode via software..?
Tnks for all
Polaco
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 11-21-2011 00:44
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-08-1999 14:22
Imei Arnis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-15-1999 02:38
Page generated in 0.38225 seconds with 12 queries
