Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Android based phones
Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 12-23-2012, 18:28   #1 (permalink)
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
[Guide] Samsung Galaxy s3 mini i8190 hard reset
As we all know the new galaxy s mini stock recovery cannot be accessed by any key combination except a few modification is done.
which means out of the the normal volume up + home + power to access recovery and wipedata/factory reset will not work.
I assume you have too many pattern attempt of forget your passcode and need to reset.
simply download this i8190wipe.zip
open odin and slect it in pda
enter download mode as usual with volume down +home and power
connect to pc and make start.
all should be done.
Note: all data will be lost.
thanks to xda.
http://www.gsmcoder.net/downloads/WIPE_I8190.tar.rar
Uploaded with ImageShack.us
Old 02-02-2013, 09:52   #2 (permalink)
Member: 1061035
Sonork: raza
Hi guys
I want file for
Any 1 has Of Model samsung galaxy shw-m100 ,...
Old 02-15-2013, 11:09   #3 (permalink)
yonax's Avatar
Member: 1526706
Sonork: Redlou
100% tested is OK!
Thanks
Old 02-18-2013, 09:45   #4 (permalink)
renaldo2's Avatar
Member: 745550
I have a samsung galaxy mini s5570 was installed CyanogenMod as I started to install from the memory card was installed and then the phone is switched off.Now does not turn on.But does not exceed either in download mode.Does not make any kind of action.Can you help regulate or not.Thanks
Old 03-28-2013, 09:32   #5 (permalink)
Member: 1867059
thanks its work
do you have wipe pda 4 galaxy mini 2?
Old 04-07-2013, 06:18   #6 (permalink)
Member: 1315070
Sonork: jholok acharjee
Bro can u help me pl,z about my galaxy s3 mini i8190..when i try to root my phone..did not work properly my root file..root fail..now my phone did not run...just show galaxy mini..can u help me pl,z..how to solve this problem......
The Following User Says Thank You to JHOLOK For This Useful Post:
Old 05-17-2013, 12:17   #7 (permalink)
Binoy.c's Avatar
Member: 523496
Sonork: ammachis
I think you have bricked it for better solutions make new thread in samsung android related forums otherwise you will not get quixk replies..if you have riff box do jtaging...gd luck
Page generated in 0.56445 seconds with 10 queries
