Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-23-2017, 12:57 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: Italia Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | [Guide] Samsung Galaxy Series Phone Camera Failed / Error problems Solution Most of Camera failed message come because of this case. So, you have to refresh it. To refresh, Fix Camera Failed on Samsung galaxy Code: Go into Settings Go into Applications Manager Swipe left for All Apps. Scroll down and find Camera app and tap on it. Clear Cache, then Clear Data after that Tap on Force Stop. Reboot your phone. (restart the phone) In above steps will not delete any photo or Video in your phone but it will delete camera settings. It will get camera to default. and you will have to set it up again. Turn off the phone for 5 min. This method can help for all small errors of androids. Please Turn Off your Samsung galaxy Phone. after Turn OFF, remove the phone battery and wait 5 min. And Insert the battery again and Turn ON the phone by pressing Power Button. See whether camera is Work or Not. IF not, then Go to below step.Go SAFE MOOD and Check You can check your Camera through the SAFE MOOD If you enabled SAFE MOOD, then your apps are disabled. So you can Identity whether that Camera error come from other App. IF your phone camera works in SAFE MOOD, then Go to Normal mood and uninstall one by one and after, Uninstall permanently cause app.If not, perform Wipe cache. How To go Safe Mood Code: 1.Turn Off the phone by pressing power. 2.Turn On the phone by pressing power 3.When the Samsung logo displays, press Volume down key until the Lock Screen. 4.Now You are on SAFE MOOD We have dedicated Wiping Cache posts. camera Failed on Samsung galaxy Code: Wipe cache on Samsung galaxy phone Most of camera problems happen because phone’s Cache. So you have to delete that Cache from your phone. Don’t worry. There is no big deal or any DATA Lose. We only Delete phone Caches. Now please Follow me step by step. After Restarting, Check whether camera is Works or NOT. Please Don’t Turn OFF the phone while Wiping. 1.Turn off the phone. 2.Press and hold the Volume up key, Home key and Power key till appear Android LOGO. 3.Now, you are on Recovery Menu. Choose the “wipe your phone” from that menu. 4. Confirm It. 5.Reboot the phone. Update Software Code: Update is more important thing when using a smartphone. If this is a error Of android OS then Next Update come with Fixed that. So, when you face this king of problem Update your phone’s Software. When you update your phone’s OS. it helps to Increase Battery Life and It speed up your phone too. To update. Go into Setting >> About Device>>Software updates >> Update Now. please don’t off the phone while updating. Factory Reset Samsung galaxy Phone Code: Above methods didn’t help? Then Reset your phone. that means, Restore your phone to Factory Setting. and This cause to Lose all DATA on phone.So, We recommend to get Backup (get all data to computer by one Click – contacts, MSGS, Whatspp viber History, Photos, Videos, MP3 etc – Click here) before perform Factory Reset to your phone. Reset Sound is BIG? Don’t worry we have dedicated Reset post. Reset my phone or Hard reset Code: 1.Turn off the phone. 2.Press and hold the Volume up key, Home key and Power key till appear Android LOGO. 3.Now, you are on Recovery Menu. Choose the “factory reset” from that menu. 4. Choose “Yes — Delete All User Data option” by pressing power button 5.After performed Reset, Reboot the phone. Flash a Stock ROM on Samsung galaxy Phone Code: All above methods didn’t help? then This is the last one..When you face this kind of problem in computer, like virus affection badly or system error, then your last method is Installing Windows again. Stock Rom is like a Windows..There are 2 type of Rom. One is Stock Rom and second one is Custom Rom. If you install Custom Rom it break your Warranty. Stock Rom is Official Rom. We have dedicated post about flashing Stock Rom to Samsung galaxy phone. I Flashed a Stock Rom, now Camera failed. Code: That means your current Rom is Corrupted or damaged. Now you have to Install Stock Rom to ON your phone. Use this post to Flash new Stock Rom.we have dedicated post about flashing Stock Rom to Samsung galaxy phone. Why does my camera say, “Warning: Camera Failure” Go into Settings Go into Applications Manager swipe left for All Apps. Scroll down and find Camera app and tap on it. Clear Cache, then Clear Data after that Tap on Force Stop. Camera needs restart Code: Most of time this is a error of hardware. you had better install stock rom. After that problem persist then give it to repair. If you have an any doubt or any problem, don’t hesitate feel, We always here to reply you. After then we are able to help you as well as be sure to gsmhosting our site on your browser.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 5 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
03-28-2017, 20:28 | #3 (permalink) |
Junior Member Join Date: Apr 2010 Location: Vancouver, BC Canada Age: 36
Member: 1284449 Status: Offline Thanks Meter: 0 | hi and how are you bosss. i have a customer phone samsung s7 and the camera focus doesnt work. i tried all the steps you mentioned above. none of them doesnt make the camera auto focus. finally, i decided to replace rear camera and now it gives me message ( camera fail) front and rear. new rear camera installed, i factory reset, wiped cache and all of the steps agian and it doesnt work. any solution please |
03-29-2017, 01:18 | #4 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | Please check your camera, your old camera h/w & new one everything is same? If you already checked that's part of camera related everything. Post result
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
04-03-2017, 09:40 | #5 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | Samsung j210f camera error 100% solved I keep this thread with camera problem related thread. http://forum.gsmhosting.com/vbb/f777...olved-2210935/
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 04-03-2017 at 09:47. |
04-19-2017, 15:29 | #6 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | samsung j200G front camra not workin after reset 100% solution http://forum.gsmhosting.com/vbb/f200...ution-2183982/ or http://forum.gsmhosting.com/vbb/f777...olved-2203793/
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 05-24-2017 at 15:12. Reason: Added new link |
