Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Android based phones
Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 06-09-2012, 11:20   #1 (permalink)
R3İS's Avatar
Member: 1058593
[Guide] Samsung GT-I9100G - usb boot repair
download link
phone mustbe off
connect phone without battery and use usb_drv_windows this driver
than run this bat file
omap4430hs_espresso_1200MHZ
and wait 20 30 sec phone will aliwe again
Last edited by moulnisky; 02-24-2013 at 00:14. Reason: replaced link with direct one without password
Old 06-09-2012, 11:28   #2 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1581941
i think this same way to repaired samsung i9250 phone
anyway good job
Old 06-09-2012, 11:35   #3 (permalink)
Member: 1756895
samsung I9100G cpu change from samsung i9100?
Old 06-09-2012, 11:38   #4 (permalink)
..::Thanh_gsm::..'s Avatar
Member: 207400
Sonork: 100.1582556
Seems that now end user can rescue their phone by them self now. we prepare to sell our jtag box
Old 06-09-2012, 11:43   #5 (permalink)
...:::JamalMustafa:::...'s Avatar
Member: 354557
i9100g
https://rapidshare.com/files/3960209...9_2ndlastt.rar
and
i9250
https://rapidshare.com/files/1168981...Flash_tuna.zip
hear is without password
enjoy
thanks legija
The Following 3 Users Say Thank You to ...:::JamalMustafa:::... For This Useful Post:
Old 06-09-2012, 12:02   #6 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Now I tested At I9100G Dead Booted AND Finally Not Work
BR,
BEHBOODI
Old 06-09-2012, 12:03   #7 (permalink)
Ta@of!k's Avatar
Member: 1754434
Sonork: 100.1603928
Driver configuration: rpapi_base = 0x00028400
          MMC sid                = 0x01
          MMC mmc_volt           = 0x01
          MMC data_width         = 0x04
          MMC card_rca           = 0x04
          MMC card_type          = 0x03
          MMC data_width_support = 0x08
          MMC transfer_clk_max   = 0xBB80
          MMC card_size          = 0x1D5A000
          eMMC CID MID                      = 0x15       // Manufacturer ID
          eMMC CID CBX                      = 0x01       // Card/BGA
          eMMC CID OID                      = 0x00       // OEM/Application ID
          eMMC CID PNM                      = 0x70280000BE01 // Product name
          eMMC CID PRV                      = 0x19       // Product revision
          eMMC CID PSN                      = 0x0000BE01 // Product serial number
          eMMC CID MDT                      = 0xBE       // Manufacturing date
          eMMC CID CRC                      = 0x00       // CRC7 checksum
          eMMC CSD CSD_STRUCTURE            = 0x03       // CSD structure
          eMMC CSD SPEC_VERS                = 0x04       // System specification version
          eMMC CSD TAAC                     = 0x27       // Data read access-time 1
          eMMC CSD NSAC                     = 0x01       // Data read access-time 2 in CLK cycles (NSAC*100)
          eMMC CSD TRAN_SPEED               = 0x32       // Max. bus clock frequency
          eMMC CSD CCC                      = 0x00F5     // Card command classes
          eMMC CSD READ_BL_LEN              = 0x09       // Max. read data block length
          eMMC CSD READ_BL_PARTIAL          = 0x00       // Partial blocks for read allowed
          eMMC CSD WRITE_BLK_MISALIGN       = 0x00       // Write block misalignment
          eMMC CSD READ_BLK_MISALIGN        = 0x00       // Read block misalignment
          eMMC CSD DSR_IMP                  = 0x00       // DSR implemented
          eMMC CSD C_SIZE                   = 0x00FF     // Device size
          eMMC CSD VDD_R_CURR_MIN           = 0x06       // Max. read current @ VDD min
          eMMC CSD VDD_R_CURR_MAX           = 0x06       // Max. read current @ VDD max
          eMMC CSD VDD_W_CURR_MIN           = 0x06       // Max. write current @ VDD min
          eMMC CSD VDD_W_CURR_MAX           = 0x06       // Max. write current @ VDD max
          eMMC CSD C_SIZE_MULT              = 0x01       // Device size multiplier
          eMMC CSD ERASE_GRP_SIZE           = 0x1F       // Erase group size
          eMMC CSD ERASE_GRP_MULT           = 0x1F       // Erase group size multiplier
          eMMC CSD WP_GRP_SIZE              = 0x0F       // Write protect group size
          eMMC CSD WP_GRP_ENABLE            = 0x01       // Write protect group enable
          eMMC CSD DEFAULT_ECC              = 0x00       // Manufacturer default ECC
          eMMC CSD R2W_FACTOR               = 0x02       // Write speed factor
          eMMC CSD WRITE_BL_LEN             = 0x09       // Max. write data block length
          eMMC CSD WRITE_BL_PARTIAL         = 0x00       // Partial blocks for write allowed
          eMMC CSD CONTENT_PROT_APP         = 0x00       // Content protection application
          eMMC CSD FILE_FORMAT_GRP          = 0x00       // File format group
          eMMC CSD COPY                     = 0x01       // Copy flag (OTP)
          eMMC CSD PERM_WRITE_PROTECT       = 0x00       // Permanent write protection
          eMMC CSD TMP_WRITE_PROTECT        = 0x00       // Temporary write protection
          eMMC CSD FILE_FORMAT              = 0x00       // File format
          eMMC CSD ECC                      = 0x00       // ECC code
          eMMC CSD CRC                      = 0x33       // CRC
          eMMC EXT_CSD S_CMD_SET            = 0x00       // Supported Command Sets
          eMMC EXT_CSD BOOT_INFO            = 0x15       // Boot information
          eMMC EXT_CSD BOOT_SIZE_MULTI      = 0x0A       // Boot partition size
          eMMC EXT_CSD ACC_SIZE             = 0x07       // Access size
          eMMC EXT_CSD HC_ERASE_GRP_SIZE    = 0x00       // High-capacity erase unit size
          eMMC EXT_CSD ERASE_TIMEOUT_MULT   = 0x04       // High-capacity erase timeout
          eMMC EXT_CSD REL_WR_SEC_C         = 0x07       // Reliable write sector count
          eMMC EXT_CSD HC_WP_GRP_SIZE       = 0x01       // High-capacity write protect group size
          eMMC EXT_CSD S_C_VCC              = 0x01       // Sleep current (VCC)
          eMMC EXT_CSD S_C_VCCQ             = 0x01       // Sleep current (VCCQ)
          eMMC EXT_CSD S_A_TIMEOUT          = 0x07       // Sleep/awake timeout
          eMMC EXT_CSD SEC_COUNT            = 0x01D5A000 // Sector Count
          eMMC EXT_CSD MIN_PERF_W_8_52      = 0xA0       // Minimum Write Performance for 8bit at 52MHz
          eMMC EXT_CSD MIN_PERF_R_8_52      = 0x00       // Minimum Read Performance for 8bit at 52MHz
          eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00       // Minimum Write Performance for 8bit at 26MHz, for 4bit at 52MHz
          eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00       // Minimum Read Performance for 8bit at 26MHz, for 4bit at 52MHz
          eMMC EXT_CSD MIN_PERF_W_4_26      = 0x00       // Minimum Write Performance for 4bit at 26MHz
          eMMC EXT_CSD MIN_PERF_R_4_26      = 0x00       // Minimum Read Performance for 4bit at 26MHz
          eMMC EXT_CSD PWR_CL_26_360        = 0x00       // Power class for 26MHz at 3.6V
          eMMC EXT_CSD PWR_CL_52_360        = 0x00       // Power class for 52MHz at 3.6V
          eMMC EXT_CSD PWR_CL_26_195        = 0x00       // Power class for 26MHz at 1.95V
          eMMC EXT_CSD PWR_CL_52_195        = 0x00       // Power class for 52MHz at 1.95V
          eMMC EXT_CSD CARD_TYPE            = 0x01       // Card type
          eMMC EXT_CSD CSD_STRUCTURE        = 0x00       // CSD structure version
          eMMC EXT_CSD EXT_CSD_REV          = 0x00       // Extended CSD revision
          eMMC EXT_CSD CMD_SET              = 0x02       // Command set
          eMMC EXT_CSD CMD_SET_REV          = 0x05       // Command set revision
          eMMC EXT_CSD POWER_CLASS          = 0x00       // Power class
          eMMC EXT_CSD HS_TIMING            = 0x00       // High-speed interface timing
          eMMC EXT_CSD BUS_WIDTH            = 0x00       // Bus width mode
          eMMC EXT_CSD ERASED_MEM_CONT      = 0x00       // Erased memory content
          eMMC EXT_CSD BOOT_CONFIG          = 0x00       // Boot configuration
          eMMC EXT_CSD BOOT_BUS_WIDTH       = 0x00       // Boot bus width1
          eMMC EXT_CSD ERASE_GROUP_DEF      = 0x00       // High-density erase group definition
          EMMC eMMC DRIVER INIT COMPLETE
» Downloading complete
» Elapsed time: 0:02.203 (21430 bytes/s)
» End loading driver
» Downloading
» Downloading 'Targets\Projects\espresso\MLO.hs'
» Sending data (262144 bytes) :::::::::::::::::::: [262144]
» Elapsed time: 0:00.281 (932896 bytes/s)
» Looking for a driver for 'EMMC'
» chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 1 width 4 delay 9 rpapi_base 0x00028400
» Downloading driver
          EMMC eMMC DRIVER DEINIT COMPLETE
» Downloading 'Targets\Flash-Drivers\emmc_drv.bin'
» Sending data (47160 bytes) :::::::::::::::::::: [47160]
          Interface 'OMAPFLASH DRIVER v6'
          Driver 'eMMC JESD84-A43'
          Driver configuration: sid = 0x00000001
          Driver configuration: width = 0x00000004
          Driver configuration: delay = 0x00000009
          MMC sid                = 0x01
          MMC mmc_volt           = 0x01
          MMC card_rca           = 0x04
» Elapsed time: 0:01.843 (26200 bytes/s)
» Downloading
» Downloading 'Targets\Projects\espresso\Sbl.bin'
» Sending data (1310720 bytes) :::::::::::::::::::: [1310720]
» Elapsed time: 0:00.938 (1397356 bytes/s)
» cold_sw_reset
» Elapsed time: 0:11.812
Appuyez sur une touche pour continuer...
Asangsm team
Old 06-09-2012, 12:51   #8 (permalink)
Member: 1752435
I have a dead i9250m galaxy nexus
Below I will copy the result of the tool..when I use the tuna one the omap connects and disconnects quickly..when i use the one for i9000 the omap stays connected longer..I think i need different configurations some how..any hep would be appreciated..been trying to deal with this issue for some time:
I will copy the tuna log below where the one for i9000 no second found and i tried to use other seconds no luck:
» OMAPFlash v4.15 (Aug 12 2011)
» -v
» Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt at line
: 1
» -omap 4
» -t 36000
» -p OMAP4460_TUNA_8G_HS_PRO
» -2
» -rxtx_trace
» chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO
» chip_download EMMC Targets\Projects\tuna\sbl.img
» command cold_sw_reset
» Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt
» @Targets\Projects\tuna\omap4460_tuna_hs_pro.txt
» Looking for device (omap usb)
» Please turn on device
» Waiting for device (omap usb)
» Found device (omap usb)
» Requesting ASIC id
00130-000-TX 4 raw bytes: 03 00 03 F0 '????'
» AsicId items 05
» AsicId id 01 05 01 44 40 07 01
» AsicId secure_mode 13 02 01 00
» AsicId public_id 12 15 01 97 1E D2 40 84 FC E8 16 AA 20 26 62 0C 90 E0
83 26 88 80 7B
» AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2
25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC
» AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC
00130-001-TX 4 raw bytes: 02 00 03 F0 '????'
» Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS
» Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si
gned.2nd.hs_pro
» Entering parameter filemapflash2nd.txt at line: 46
» -pheriphalboot_reopen
» Reading board configuration file Targets\Configurations\configuration_omap4460
_tuna_8g.txt
» Reading definition file .\targets\definitions\definitions_omap4.txt
» -board_config Targets\Configurations\configuration_omap4460_tuna_8g.txt
» Leaving parameter filemapflash2nd.txt
» Sending size of second file (0x000071B0 bytes)
00130-002-TX 4 raw bytes: B0 71 00 00 '?q??'
» Transferring second file to target (0x71B0 bytes)
00130-003-TX 29104 raw bytes: B0 1C 00 00 00 4D 00 00 00 00 00 00 00 00 00 00
'?????M??????????' ...
» Closing boot connection
» Waiting for 2nd
00463-004-TX ACK
00571-005-RX: 4 raw bytes: 70 EC 8F 00 'p???'
» Unknown status message 'p???' during peripheral boot (waiting for 2nd)
Press any key to continue . . .
thanx for your support..I posted on the main post by ligejja and got no help there..
Old 06-09-2012, 12:57   #9 (permalink)
R3İS's Avatar
Member: 1058593
if not work for some phones copy this file
https://hotfile.com/dl/159242306/690bacc/Sbl.rar.html
OMAPFlash_1229_2ndlastt\Targets\Projects\tuna
change with sbl file
The Following 2 Users Say Thank You to R3İS For This Useful Post:
Old 06-09-2012, 13:18   #10 (permalink)
sarfraz's Avatar
Member: 161167
this is not work for me
Old 06-09-2012, 13:24   #11 (permalink)
Member: 1752435
Tried the file with both tools no luck..
Old 06-09-2012, 13:57   #12 (permalink)
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
@ ...:::JamalMustafa:::...
Hey...!
Your link is Broken..
Plz Check link.
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 06-09-2012, 14:15   #13 (permalink)
amer_a_82's Avatar
Member: 610529
Sonork: 100.1612153
thx all i repair boot but phone not flash
what the of flashing ????
Old 06-09-2012, 14:32   #14 (permalink)
amer_a_82's Avatar
Member: 610529
Sonork: 100.1612153
this a problem
http://www.img.gem-flash.com/images/...1284233602.jpg
Old 06-09-2012, 15:02   #15 (permalink)
Member: 1210541
Sonork: 100.1583508
logo draw failed
Nokia "Contact Service" Repairer Dirk Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 10-04-2011 05:45
New!! Nokia Flash Checksum And Contact Service Repair HookerGsM Main Sales Section 0 01-02-2001 09:12
Well, i guess i'm the first one to post here... 3210-fan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 09-05-2000 23:18
Unlock all locks all phones *HERE* manfred GSM Mobile Links 0 02-19-2000 09:50
buy your GSM here midlandcellular Main Sales Section 0 09-04-1999 17:14
Page generated in 0.87560 seconds with 11 queries
