Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-12-2013, 06:56 | #76 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: quantum mss
Member: 638396 Status: Offline Sonork: 100.1615405 Thanks Meter: 170 | Quote:
if using default file from software ( OMAPFlash_1229_2ndlastt ), phone flashing working only with Chinese firmware, but after flash not completely boot up, it ask for " Confirm Passowrd " then i found this post, i extraxt I9100GXXLSR firmware ( single file ) and copy param, sbl & MLO to OMAPFlash_1229_2ndlastt\Targets\Projects\espresso folder.., do repair again, flash with I9100GXXLS.., and now working..., Before change sbl, MLO and param After change sbl, mlo and param | |
12-03-2013, 13:57 | #77 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 601134 Status: Offline Thanks Meter: 39 | r eMMC CID MDT = 0xAE // Manufacturing date eMMC CID CRC = 0x5A // CRC7 checksum eMMC CSD CSD_STRUCTURE = 0x03 // CSD structure eMMC CSD SPEC_VERS = 0x04 // System specification version eMMC CSD TAAC = 0x27 // Data read access-tim e 1 eMMC CSD NSAC = 0x01 // Data read access-tim e 2 in CLK cycles (NSAC*100) eMMC CSD TRAN_SPEED = 0x32 // Max. bus clock frequ ency eMMC CSD CCC = 0x00F5 // Card command classes eMMC CSD READ_BL_LEN = 0x09 // Max. read data block length eMMC CSD READ_BL_PARTIAL = 0x00 // Partial blocks for r ead allowed eMMC CSD WRITE_BLK_MISALIGN = 0x00 // Write block misalign ment eMMC CSD READ_BLK_MISALIGN = 0x00 // Read block misalignm ent eMMC CSD DSR_IMP = 0x00 // DSR implemented eMMC CSD C_SIZE = 0x00FF // Device size eMMC CSD VDD_R_CURR_MIN = 0x06 // Max. read current @ VDD min eMMC CSD VDD_R_CURR_MAX = 0x06 // Max. read current @ VDD max eMMC CSD VDD_W_CURR_MIN = 0x06 // Max. write current @ VDD min eMMC CSD VDD_W_CURR_MAX = 0x06 // Max. write current @ VDD max eMMC CSD C_SIZE_MULT = 0x01 // Device size multipli er eMMC CSD ERASE_GRP_SIZE = 0x1F // Erase group size eMMC CSD ERASE_GRP_MULT = 0x1F // Erase group size mul tiplier eMMC CSD WP_GRP_SIZE = 0x0F // Write protect group size eMMC CSD WP_GRP_ENABLE = 0x01 // Write protect group enable eMMC CSD DEFAULT_ECC = 0x00 // Manufacturer default ECC eMMC CSD R2W_FACTOR = 0x02 // Write speed factor eMMC CSD WRITE_BL_LEN = 0x09 // Max. write data bloc k length eMMC CSD WRITE_BL_PARTIAL = 0x00 // Partial blocks for w rite allowed eMMC CSD CONTENT_PROT_APP = 0x00 // Content protection a pplication eMMC CSD FILE_FORMAT_GRP = 0x00 // File format group eMMC CSD COPY = 0x01 // Copy flag (OTP) eMMC CSD PERM_WRITE_PROTECT = 0x00 // Permanent write prot ection eMMC CSD TMP_WRITE_PROTECT = 0x00 // Temporary write prot ection eMMC CSD FILE_FORMAT = 0x00 // File format eMMC CSD ECC = 0x00 // ECC code eMMC CSD CRC = 0x33 // CRC eMMC EXT_CSD S_CMD_SET = 0x00 // Supported Command Se ts eMMC EXT_CSD BOOT_INFO = 0x15 // Boot information eMMC EXT_CSD BOOT_SIZE_MULTI = 0x0A // Boot partition size eMMC EXT_CSD ACC_SIZE = 0x07 // Access size eMMC EXT_CSD HC_ERASE_GRP_SIZE = 0x00 // High-capacity erase unit size eMMC EXT_CSD ERASE_TIMEOUT_MULT = 0x04 // High-capacity erase timeout eMMC EXT_CSD REL_WR_SEC_C = 0x07 // Reliable write secto r count eMMC EXT_CSD HC_WP_GRP_SIZE = 0x01 // High-capacity write protect group size eMMC EXT_CSD S_C_VCC = 0x01 // Sleep current (VCC) eMMC EXT_CSD S_C_VCCQ = 0x01 // Sleep current (VCCQ) eMMC EXT_CSD S_A_TIMEOUT = 0x07 // Sleep/awake timeout eMMC EXT_CSD SEC_COUNT = 0x01D5A000 // Sector Count eMMC EXT_CSD MIN_PERF_W_8_52 = 0xA0 // Minimum Write Perfor mance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_52 = 0x00 // Minimum Read Perform ance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00 // Minimum Write Perfor mance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00 // Minimum Read Perform ance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_W_4_26 = 0x00 // Minimum Write Perfor mance for 4bit at 26MHz eMMC EXT_CSD MIN_PERF_R_4_26 = 0x00 // Minimum Read Perform ance for 4bit at 26MHz eMMC EXT_CSD PWR_CL_26_360 = 0x00 // Power class for 26MH z at 3.6V eMMC EXT_CSD PWR_CL_52_360 = 0x00 // Power class for 52MH z at 3.6V eMMC EXT_CSD PWR_CL_26_195 = 0x00 // Power class for 26MH z at 1.95V eMMC EXT_CSD PWR_CL_52_195 = 0x00 // Power class for 52MH z at 1.95V eMMC EXT_CSD CARD_TYPE = 0x01 // Card type eMMC EXT_CSD CSD_STRUCTURE = 0x00 // CSD structure versio n eMMC EXT_CSD EXT_CSD_REV = 0x00 // Extended CSD revisio n eMMC EXT_CSD CMD_SET = 0x02 // Command set eMMC EXT_CSD CMD_SET_REV = 0x05 // Command set revision eMMC EXT_CSD POWER_CLASS = 0x00 // Power class eMMC EXT_CSD HS_TIMING = 0x00 // High-speed interface timing eMMC EXT_CSD BUS_WIDTH = 0x00 // Bus width mode eMMC EXT_CSD ERASED_MEM_CONT = 0x00 // Erased memory conten t eMMC EXT_CSD BOOT_CONFIG = 0x00 // Boot configuration eMMC EXT_CSD BOOT_BUS_WIDTH = 0x00 // Boot bus width1 eMMC EXT_CSD ERASE_GROUP_DEF = 0x00 // High-density erase g roup definition EMMC eMMC DRIVER INIT COMPLETE » Downloading complete » Elapsed time: 0:01.844 (26200 bytes/s) » End loading driver » Downloading » Downloading 'Targets\Projects\espresso\MLO.hs' » Sending data (262144 bytes) :::::::::::::::::::: [262144] » Downloading complete » Elapsed time: 0:00.234 (1120273 bytes/s) » Looking for a driver for 'EMMC' » chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 1 width 4 delay 9 rpap i_base 0x00028400 » Downloading driver EMMC eMMC DRIVER DEINIT COMPLETE » Downloading 'Targets\Flash-Drivers\emmc_drv.bin' » Sending data (47160 bytes) :::::::::::::::::::: [47160] Interface 'OMAPFLASH DRIVER v6' Driver 'eMMC JESD84-A43' Driver configuration: sid = 0x00000001 Driver configuration: width = 0x00000004 Driver configuration: delay = 0x00000009 Driver configuration: rpapi_base = 0x00028400 MMC sid = 0x01 MMC mmc_volt = 0x01 MMC data_width = 0x04 MMC card_rca = 0x04 MMC card_type = 0x03 MMC data_width_support = 0x08 MMC transfer_clk_max = 0xBB80 MMC card_size = 0x1D5A000 eMMC CID MID = 0x15 // Manufacturer ID eMMC CID CBX = 0x01 // Card/BGA eMMC CID OID = 0x00 // OEM/Application ID eMMC CID PNM = 0xAADD0000AEB5 // Product name eMMC CID PRV = 0x19 // Product revision eMMC CID PSN = 0x0000AEB5 // Product serial numbe r eMMC CID MDT = 0xAE // Manufacturing date eMMC CID CRC = 0x5A // CRC7 checksum eMMC CSD CSD_STRUCTURE = 0x03 // CSD structure eMMC CSD SPEC_VERS = 0x04 // System specification version eMMC CSD TAAC = 0x27 // Data read access-tim e 1 eMMC CSD NSAC = 0x01 // Data read access-tim e 2 in CLK cycles (NSAC*100) eMMC CSD TRAN_SPEED = 0x32 // Max. bus clock frequ ency eMMC CSD CCC = 0x00F5 // Card command classes eMMC CSD READ_BL_LEN = 0x09 // Max. read data block length eMMC CSD READ_BL_PARTIAL = 0x00 // Partial blocks for r ead allowed eMMC CSD WRITE_BLK_MISALIGN = 0x00 // Write block misalign ment eMMC CSD READ_BLK_MISALIGN = 0x00 // Read block misalignm ent eMMC CSD DSR_IMP = 0x00 // DSR implemented eMMC CSD C_SIZE = 0x00FF // Device size eMMC CSD VDD_R_CURR_MIN = 0x06 // Max. read current @ VDD min eMMC CSD VDD_R_CURR_MAX = 0x06 // Max. read current @ VDD max eMMC CSD VDD_W_CURR_MIN = 0x06 // Max. write current @ VDD min eMMC CSD VDD_W_CURR_MAX = 0x06 // Max. write current @ VDD max eMMC CSD C_SIZE_MULT = 0x01 // Device size multipli er eMMC CSD ERASE_GRP_SIZE = 0x1F // Erase group size eMMC CSD ERASE_GRP_MULT = 0x1F // Erase group size mul tiplier eMMC CSD WP_GRP_SIZE = 0x0F // Write protect group size eMMC CSD WP_GRP_ENABLE = 0x01 // Write protect group enable eMMC CSD DEFAULT_ECC = 0x00 // Manufacturer default ECC eMMC CSD R2W_FACTOR = 0x02 // Write speed factor eMMC CSD WRITE_BL_LEN = 0x09 // Max. write data bloc k length eMMC CSD WRITE_BL_PARTIAL = 0x00 // Partial blocks for w rite allowed eMMC CSD CONTENT_PROT_APP = 0x00 // Content protection a pplication eMMC CSD FILE_FORMAT_GRP = 0x00 // File format group eMMC CSD COPY = 0x01 // Copy flag (OTP) eMMC CSD PERM_WRITE_PROTECT = 0x00 // Permanent write prot ection eMMC CSD TMP_WRITE_PROTECT = 0x00 // Temporary write prot ection eMMC CSD FILE_FORMAT = 0x00 // File format eMMC CSD ECC = 0x00 // ECC code eMMC CSD CRC = 0x33 // CRC eMMC EXT_CSD S_CMD_SET = 0x00 // Supported Command Se ts eMMC EXT_CSD BOOT_INFO = 0x15 // Boot information eMMC EXT_CSD BOOT_SIZE_MULTI = 0x0A // Boot partition size eMMC EXT_CSD ACC_SIZE = 0x07 // Access size eMMC EXT_CSD HC_ERASE_GRP_SIZE = 0x00 // High-capacity erase unit size eMMC EXT_CSD ERASE_TIMEOUT_MULT = 0x04 // High-capacity erase timeout eMMC EXT_CSD REL_WR_SEC_C = 0x07 // Reliable write secto r count eMMC EXT_CSD HC_WP_GRP_SIZE = 0x01 // High-capacity write protect group size eMMC EXT_CSD S_C_VCC = 0x01 // Sleep current (VCC) eMMC EXT_CSD S_C_VCCQ = 0x01 // Sleep current (VCCQ) eMMC EXT_CSD S_A_TIMEOUT = 0x07 // Sleep/awake timeout eMMC EXT_CSD SEC_COUNT = 0x01D5A000 // Sector Count eMMC EXT_CSD MIN_PERF_W_8_52 = 0xA0 // Minimum Write Perfor mance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_52 = 0x00 // Minimum Read Perform ance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00 // Minimum Write Perfor mance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00 // Minimum Read Perform ance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_W_4_26 = 0x00 // Minimum Write Perfor mance for 4bit at 26MHz eMMC EXT_CSD MIN_PERF_R_4_26 = 0x00 // Minimum Read Perform ance for 4bit at 26MHz eMMC EXT_CSD PWR_CL_26_360 = 0x00 // Power class for 26MH z at 3.6V eMMC EXT_CSD PWR_CL_52_360 = 0x00 // Power class for 52MH z at 3.6V eMMC EXT_CSD PWR_CL_26_195 = 0x00 // Power class for 26MH z at 1.95V eMMC EXT_CSD PWR_CL_52_195 = 0x00 // Power class for 52MH z at 1.95V eMMC EXT_CSD CARD_TYPE = 0x01 // Card type eMMC EXT_CSD CSD_STRUCTURE = 0x00 // CSD structure versio n eMMC EXT_CSD EXT_CSD_REV = 0x00 // Extended CSD revisio n eMMC EXT_CSD CMD_SET = 0x02 // Command set eMMC EXT_CSD CMD_SET_REV = 0x05 // Command set revision eMMC EXT_CSD POWER_CLASS = 0x00 // Power class eMMC EXT_CSD HS_TIMING = 0x00 // High-speed interface timing eMMC EXT_CSD BUS_WIDTH = 0x00 // Bus width mode eMMC EXT_CSD ERASED_MEM_CONT = 0x00 // Erased memory conten t eMMC EXT_CSD BOOT_CONFIG = 0x00 // Boot configuration eMMC EXT_CSD BOOT_BUS_WIDTH = 0x00 // Boot bus width1 eMMC EXT_CSD ERASE_GROUP_DEF = 0x00 // High-density erase g roup definition EMMC eMMC DRIVER INIT COMPLETE » Downloading complete » Elapsed time: 0:01.782 (27740 bytes/s) » End loading driver » Downloading » Downloading 'Targets\Projects\espresso\Sbl.bin' » Sending data (1310720 bytes) :::::::::::::::::::: [1310720] » Downloading complete » Elapsed time: 0:00.891 (1471066 bytes/s) » cold_sw_reset » Elapsed time: 0:18.015 Press any key to continue . . . C:\Documents and Settings\Administrator\Desktop\OMAPFlash_1229_2ndl astt 1\OMAPF lash_1229_2ndlastt>GOTO __loop » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ. txt at li ne: 1 » -omap 4 » -t 36000 » -p OMAP4430_8G_HS » -2 » chip_download EMMC Targets\Projects\espresso\MLO.hs » chip_download EMMC Targets\Projects\espresso\Sbl.bin » command cold_sw_reset » Leaving parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ. txt » @Targets\Projects\espresso\omap4430hs_1200MHZ.txt » Looking for device (omap usb) » Please turn off device » Please turn on device » Waiting for device ( to all moderator i flash my i9100g until here i disconnet my i9100g and put the batt and put jig usb still no download mode ,why help me got 3 pc i9100g |
05-06-2015, 17:42 | #80 (permalink) |
Insane Poster Join Date: Jul 2005 Location: Germany Age: 46
Member: 159805 Status: Offline Thanks Meter: 1 | i got stuck here... » Downloading » Downloading 'Targets\Projects\espresso\MLO.hs' » Sending data (262144 bytes) :::::............... [65536] any idea? |
01-07-2018, 08:32 | #84 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Uzbekistan, Andizhan.
Member: 2013701 Status: Offline Thanks Meter: 24 | in folder changed SBL and MLO in my flash file 4.1.2 Ser and repaired dead boot yours file phone in download mode and i flashed with pit file 4 all after this work phone worked normally thanks bro !!!!! |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
New!! Nokia Flash Checksum And Contact Service Repair | HookerGsM | Main Sales Section | 0 | 01-02-2001 10:12 |
Unlock all locks all phones *HERE* | manfred | GSM Mobile Links | 0 | 02-19-2000 10:50 |
buy your GSM here | midlandcellular | Main Sales Section | 0 | 09-04-1999 17:14 |
