Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 05-07-2012, 10:10   #1 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 231
Thumbs up [Guide] Samsung P1000 with a corrupt internal sdcard - Solution here
I recently fixed a P1000 with a corrupt internal sdcard - I thought I'd share my experience.
The Symptoms
When Booting the device got stuck at the Samsung Logo Screen
ODin/Heimdall fails on any rom which include an hidden.rfs and movinand.mst
ODin/Heimdall report success when flashing flashing roms without hidden.rfs and movinand.mst
Recovery Mode reports errors after flashing. The error is different depending on which rom was flashed but are all related to file system functions.
Internal MMC checksum verify failed.
E: failed to mount /system (invalid argument)
E: failed to mount /dbdata (Invalid argument)
E: /dev/block/mmcblk0p2 on /data failed: No such file or directory
E: copy_dbdata_media:Can't mount /dbdata
The Problem
The recovery errors alone are not enough to diagnose the problem as they can also occur if flashing has been carried out incorrectly.
The main pointer to an Internal SDCard Failure is the inability to flash hidden.rfs and movinand.mst
You should be able to confirm this to be the case by running dmesg on the device using adb from the command prompt
adb shell dmesg
My output contained the following line:
<3>[ 4.802004] mmc0: error -110 whilst initialising MMC card
The Solution
Normally you should be able to RMA this as it is an hardware failure.
However as warranties expire or you just can't be bothered to wait here is an alternative solution
1. Format the external sdcard with 3 parititions (you can probably get away with 2) I used a 32 GB card with the follwing
Partition 1: 28 GB Fat 32 (sdcard partition)
Partition 2: 4 GB ext4 (data partition)
Partition 3: 100MB Fat 32 (preload partition)
If you want more space for app, make the data partition larger
2. Flash Latest Rom. I used XWJQ8 but I also flashed XXJPZ Successfully and I don't think it makes alot of difference
I Used Heimdall for this and I flashed everything. Odin should do the Job as long you remove hidden.rfs and movinand.mst from the tar balls
heimdall flash --repartition --pit gt-p1000_mr.pit --primary-boot boot.bin \
--cache cache.rfs \
--factoryfs factoryfs.rfs \
--modem modem.bin \
--param param.lfs \
--secondary-boot Sbl.bin \
--kernel zImage --recovery zImage
3. Flash latest Overcome Kernel 4 which can be downloaded from the teamovercome download page
4. Boot To Recovery ( You should now see Clockwork Recovery Mod )
5. edit /system/etc/vold.fstab on the device to look like the following
# internal sdcard
ums_path = /sys/devices/platform/usb_mass_storage/lun0/file
asec = disable
discard = disable
format_option = -r 1558
dev_mount sdcard /mnt/sdcard 1 /devices/platform/s3c-sdhci.2/mmc_host/mmc1
# externel sdcard
asec = enable
dev_mount sdcard /mnt/sdcard/external_sd auto /devices/platform/s3c-sdhci.2/mmc_host/mmc2 /devices/platform/s3c-sdhci.2/mmc_host/mmc1
6. Reboot, System Should now functioning normally.
Note: First boot takes a while. if you are worried or think it is boot looping, you can watch the output using adb logcat
You should now have a working galaxy with the added bonus of a re-sizable data partition.
don't forget thanks button
The Following 6 Users Say Thank You to FEATURE GSM™ For This Useful Post:
Old 05-07-2012, 11:11   #2 (permalink)
jupizet's Avatar
Member: 154427
Thanks Meter: 61
about all operation we need sd card?
"Partition 1: 28 GB Fat 32 (sdcard partition)
Partition 3: 100MB Fat 32 (preload partition)"
do not understand about that
Old 05-07-2012, 13:53   #3 (permalink)
Member: 276151
Sonork: 100.1577032
Thanks Meter: 231
Old 05-09-2012, 13:10   #4 (permalink)
jupizet's Avatar
Member: 154427
Thanks Meter: 61
and solution is change hardware(internal sc card)??
Old 05-21-2012, 19:30   #5 (permalink)
Member: 1351184
Thanks Meter: 2
bro, forgive the boldness
could you upload a video, My eMMC is damaged
and do not really understand the tutorial,
sorry
Old 05-23-2012, 00:42   #6 (permalink)
Pulka's Avatar
Member: 936229
Sonork: 1606911
Thanks Meter: 114
Hi.
Has anyone successfully tested this solution?
Best regards!
Old 01-11-2013, 01:19   #7 (permalink)
Member: 786520
Thanks Meter: 4
it works 100% tested
Old 01-13-2013, 03:43   #8 (permalink)
hanen's Avatar
Member: 70053
Thanks Meter: 85
I tested it work ok..............
Old 02-18-2013, 03:56   #9 (permalink)
hanen's Avatar
Member: 70053
Thanks Meter: 85
phone now is work but without sdcard1 is not mount
Old 02-18-2013, 20:06   #10 (permalink)
Member: 1886273
Help in step 5?
Hello everyone, I have an galaxy tab gt-p1000 with the symptoms you describe. I am convinced that the tablet have a hardware problem.
Googling i found this thread and see a light in the end of the tunnel.
I managed to make the steps 1,2,3,4.
Step 1:
I use yhe software minitool software Partition Home, that is free.
The card only have 8Gb but I sized the partitions:
Partition 1: 3,5GB GB Fat 32 (sdcard partition)
Step 2:
I flashed with odin the GB-Stock-Safe-v5, Removed the files hidden.rfs and movinand.mst from the .tar file and flashed sucessufuly.
Step 3 and 4 no problem.
Step 5:
Pressed Power button an volume up and enter de recovery mode of the overcome firmware.
And now ??? How do I Edit the file "vold.fstab".
How can I do this in the recovery mode ? How can access the file and manage to edit it like you describe.
Thanks in advanced
Carlos Guerreiro from Protugal!
The Following User Says Thank You to cvitalguerreiro For This Useful Post:
Old 02-22-2013, 00:51   #11 (permalink)
hanen's Avatar
Member: 70053
Thanks Meter: 85
Step 1:
Step 2:
Step 5:
Thanks in advanced
u can open flash file with unrar and post ...this is for cm 10 file only but not work for overwork flash tested
## Vold 2.0 Generic fstab
## - San Mehat ([email protected])
## Regular device mount
## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...>
## label - Label for the volume
## mount_point - Where the volume will be mounted
## part - Partition # (1 based), or 'auto' for first usable partition.
## <sysfs_path> - List of sysfs paths to source devices
# internal sdcard
dev_mount emmc /storage/sdcard1 1 /devices/platform/s3c-sdhci.2/mmc_host/mmc1
# external sdcard
dev_mount sdcard /storage/sdcard0 1 /devices/platform/s3c-sdhci.2/mmc_host/mmc2
#end line ## keep this line
The Following User Says Thank You to hanen For This Useful Post:
Old 02-26-2013, 09:55   #12 (permalink)
Member: 1886273
Thanks for the reply. Sory for my bad English.
The point 5 says: "5. edit /system/etc/vold.fstab on the device"
You say I can use winrar. How?
Conect the device to the computer and search for the file ?
If so something is wrong because the device its detected but when I try to explore de drive it says to format it.
Please help me, Samsung Service asks me for 250,00Euros to change the mainboard, they ara insane.
Old 02-26-2013, 12:09   #13 (permalink)
hanen's Avatar
Member: 70053
Thanks Meter: 85
this file in the flash file u can edit with win rar or u can edit after flash with adb
Old 02-26-2013, 21:45   #14 (permalink)
Member: 1886273
Ok thanks, I´m waiting for the device came from samsung service. When I have it i'l try and give you all feedback.
Old 03-10-2013, 00:54   #15 (permalink)
Member: 1886273
Thanks a lot, my tab it's working again.
I don't know the adb software. The process of changing the file it's quite simple whem you know it.
After I read this thread:
[GUIDE] ADB Workshop and Guide for everyone - xda-developers
In recovery mode, tab connected with usb, open comand prompt, use adb commands Pull the file, changet it with notepad++, and the then command push the file. Reboot the tab and it's back alive.
Fu*k Samsung Service, they try to charge it 250Euros.
Carlos From Portugal
Viva o maior Clube do Mundo Sport Lisboa e Benfica.
Obrigado
Internal Aerial for 7110 8310-GUY Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 13 02-17-2003 20:07
water damaged 5110 gsmxc Nokia Hardware & Hardware Repair 5 10-18-2001 16:15
3210 *water damaged* no reception pks Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 03-28-2001 11:09
nokia 6150 internal modem mottile Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 02-20-2001 23:14
How to open 3210 without damaging? Kane Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-06-2000 16:41
Page generated in 0.42271 seconds with 8 queries
