Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-04-2013, 08:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: United Arab Emirates ( DUBAI )
Member: 1294044 Status: Offline Thanks Meter: 1,269 | Hard Reset Samsung Galaxy s mini i8190 Guide simply download this i8190wipe.zip from the link below http://www.gsmcoder.net/downloads/WIPE_I8190.tar.rar open odin and select it in pda enter download mode as usual with volume down +home and power connect to pc and make start. all should be done. Note: all data will be lost. thanks to ..::KASHIF::.. i tast 100% |
The Following 7 Users Say Thank You to ..::KASHIF::.. For This Useful Post: |
07-03-2013, 17:20 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Calicut Kerala India Age: 46
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | <ID:0/194> Added!! <ID:0/194> Removed!! <ID:0/162> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> WIPE_I8190.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/162> Odin v.3 engine (ID:162).. <ID:0/162> File analysis.. <ID:0/162> SetupConnection.. <ID:0/162> Initialzation.. <ID:0/162> Get PIT for mapping.. <ID:0/162> Firmware update start.. <ID:0/162> cache.img <ID:0/162> NAND Write Start!! <ID:0/162> RQT_CLOSE !! <ID:0/162> RES OK !! <ID:0/162> Completed.. <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/162> Removed!! thanka lot |
09-03-2013, 11:00 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Working to me 100% tested <ID:0/340> Added!! <ID:0/340> Odin v.3 engine (ID:340).. <ID:0/340> File analysis.. <ID:0/340> Enter CS for MD5.. <ID:0/340> Check MD5.. Do not unplug the cable.. <ID:0/340> Please wait.. <ID:0/340> Checking MD5 finished Sucessfully.. <ID:0/340> Leave CS.. <ID:0/340> SetupConnection.. <ID:0/340> Initialzation.. <ID:0/340> Get PIT for mapping.. <ID:0/340> Firmware update start.. <ID:0/340> cache.img <ID:0/340> Removed!! <ID:0/340> Completed.. <OSM> All threads completed. (succeed 1 / failed 0) BR |
The Following User Says Thank You to gsmcrazy1 For This Useful Post: |
09-09-2013, 18:55 | #5 (permalink) |
Insane Poster Join Date: Aug 2008 Location: the same about Facundo Cabral
Member: 839359 Status: Offline Thanks Meter: 13 | Worki to me 100% too tested <ID:0/193> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> WIPE_I8190.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/193> Odin v.3 engine (ID:193).. <ID:0/193> File analysis.. <ID:0/193> SetupConnection.. <ID:0/193> Initialzation.. <ID:0/193> Get PIT for mapping.. <ID:0/193> Firmware update start.. <ID:0/193> cache.img <ID:0/193> NAND Write Start!! <ID:0/193> RQT_CLOSE !! <ID:0/193> RES OK !! <ID:0/193> Completed.. <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/193> Removed!! BR |
03-04-2014, 12:15 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Z <> A Age: 49
Member: 413160 Status: Offline Sonork: 100.1657278 Thanks Meter: 96 | Quote:
need this working link ???? plz upload ............................. | |
04-23-2014, 15:11 | #8 (permalink) | |
Member: 1294044 Status: Offline Thanks Meter: 1,269 | Quote:
The Following User Says Thank You to ..::KASHIF::.. For This Useful Post: |
04-23-2014, 15:14 | #9 (permalink) |
No Life Poster Join Date: Oct 2011 Location: MOROCCO
Member: 1679440 Status: Offline Thanks Meter: 79 | Samsung Galaxy S III mini hard reset force reset Reset the device (press and hold POWER button for 8-10 seconds) Unlock Galaxy S3 mini using hard reset sgs3 mini hard reset or reset Galaxy S3 mini: PRESS AND HOLD VOLUME UP + Home Button + Power Turn the phone off. Press and hold VOLUME UP and Home(center) button Press Power until the phone vibrate Wait until you see the Android logo then release all the buttons. Select Wipe data/Factory reset with VOLUME DOWN, press Power (right hand-side) Select YES -- delete all user data with VOLUME DOWN and then press Power After format, press Power again to reboot phone. (select reboot system now) |
09-07-2015, 14:53 | #12 (permalink) |
No Life Poster Join Date: May 2009 Age: 49
Member: 1027729 Status: Offline Thanks Meter: 97 | Wait for the BOOT signal ... PDA SW: I8190XXAMG4 CSC SW: I8190OJVAMH1 Phone SW: I8190XXAMG4 S/N: RF1xxxxxxx IMEI: ˆP2%+›‘g(:I€ Please Wait Remove Pattern Lock ... Remove Pattern Lock Success. You Can Draw Any For Open. Total Time: 43.79 s spt box via usb cable with out data lost enjoy |
11-28-2017, 12:53 | #14 (permalink) |
Freak Poster Join Date: Feb 2017 Location: india Age: 27
Member: 2683243 Status: Offline Sonork: not using Thanks Meter: 43 | Samsung Galaxy S III mini hard reset Learn how to remove password unlock pattern on Galaxy S3 mini or force Reset the device if it hangs or frozen (press and hold POWER button for 8-10 seconds) Unlock Galaxy S3 mini using i8200 hard reset / Galaxy S3 mini VE Value Edition sgs3 mini hard reset or reset Galaxy S3 mini: PRESS AND HOLD VOLUME UP + Home Button + Power Turn the phone off. (Remove battery and reinsert it.) Press and hold VOLUME UP and Home(center) button Press Power until the phone vibrate Wait until you see the Android logo then release all the buttons. Select Wipe data/Factory reset with VOLUME DOWN, press Power (right hand-side) Select YES -- delete all user data with VOLUME DOWN and then press Power After format, press Power again to reboot phone. (select reboot system now) |
