Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-15-2015, 12:30 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: Ireland, Uk
Member: 1944119 Status: Offline Sonork: 100.1666719 Thanks Meter: 38 | Help!! S6 edge G925f big problem DRK (device root key) and not shoving imei i get that problem after root aswell i lose imei 35000000000006 i fix that vs flashing (S6-UniBase_BOG8_v2) and loaded efs and cert from other fone now i have 2 problems fone working ok but not show imei when type *#06# and dm-verity verification failed... How to fix that? |
The Following User Says Thank You to trax records For This Useful Post: |
09-15-2015, 16:21 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Its because of custom kernel Flash right region firmware using this http://forum.gsmhosting.com/vbb/f777...datas-1986895/ |
The Following User Says Thank You to jamesjerss For This Useful Post: |
09-15-2015, 16:51 | #3 (permalink) | |
Member: 1944119 Status: Offline Sonork: 100.1666719 Thanks Meter: 38 | Quote:
09-16-2015, 10:45 | #5 (permalink) | |
Member: 1944119 Status: Offline Sonork: 100.1666719 Thanks Meter: 38 | Quote: | |
09-16-2015, 12:47 | #7 (permalink) |
Member: 1944119 Status: Offline Sonork: 100.1666719 Thanks Meter: 38 | [QUOTE=body619;11291972]Flash it with BTU firmware from octopus support and till me the result[/QUOTEhi i sorted imei idid reflash from octopus suport btu 5.1.1 then repair security then write cert imei shows now ok meiking cals ok but one problem left dm-verity verification failed... need to check DRK first how to flash back to official firmware? try allredy with smart switch and diferent firmwares fone stuck on samsung logo (to bypass only posible vs root) when try factory reset come that mesage dm-verity verification failed... need to check DRK first how to get that to official firmware ??? |
04-02-2016, 10:03 | #10 (permalink) | |
Freak Poster Join Date: Feb 2013 Location: Where YOu Cant Go Age: 25
Member: 1877938 Status: Offline Sonork: 100.1659358 Thanks Meter: 72 | [QUOTE=trax records;11292086] Quote:
write this kernel your problem will solve | |
04-10-2016, 21:18 | #11 (permalink) |
Insane Poster Join Date: Oct 2013 Location: sudan Age: 41
Member: 2042376 Status: Offline Sonork: 11111 Thanks Meter: 32 | This link can be useful to you. http://forum.gsmhosting.com/vbb/f684.../#post11749273 |
04-12-2016, 12:20 | #12 (permalink) |
Major Poster Join Date: Apr 2014 Location: Libya
Member: 2164581 Status: Offline Sonork: 100.1670571 Thanks Meter: 6 | Easy Steps!! 1- Flash Your Phone with odin3 download your firmware 6.0.1 from Samfirmware 2- intall kernal for 6.0 via odin3 3- root your device 4- write cert you are done.. if you dont have kernal you can text me on skype samsung.albadeel |
The Following User Says Thank You to z3x1 For This Useful Post: |
04-25-2016, 18:49 | #13 (permalink) | |
Major Poster Join Date: Aug 2011
Member: 1631844 Status: Offline Thanks Meter: 32 | Quote:
The Following User Says Thank You to shahin786 For This Useful Post: |
06-08-2016, 15:59 | #15 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1793892 Status: Offline Thanks Meter: 0 | galaxy s7 g935f hello friend, I have a galaxy s7 that was asking google account , I update and the machine caught on recovery and is asking drk first and not with solving mode, already tried to play but will not root because this FRP on g935f |
