Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-28-2014, 21:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Nowhere
Member: 739774 Status: Offline Thanks Meter: 89 | How to activate S5 without Samsung account? I've bought a 2nd hands Galaxy S5 from a customer. But I forgot to ask the google and samsung account and password. I have tried the following solutions, but without result: 1) Hard reset, with Power button+Home+volum Up and choosing factory reset. 2) Flashed the Phone with Odin V3.09 with this firmware (G900FXXU1ANE2_G900FOXX1AND3_XEF) The Phone ask me this: This phone is blocked because it was reset in an unusual manner. Sign in to the samsung account that you have already sgined into on this phone to confirm that it belongs to you. So guys, Please help me to solve this problem. otherwise I should use this phone only for parts. Thank you |
05-28-2014, 21:26 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | How to hard reset: Attention! After this reset, all personal data from phone will be lost, so make a backup before. 1.Power off your phone 2.Push together volume up+home key+power button 3.Select with volume keys "wipe data/factory reset" and press power to confirm 4.Select "yes" and press power to confirm 5.Wait until format ends 6.Press power key to confirm "reboot" 7.Wait until the phone restarts That's it! Here is video how to do: https://www.youtube.com/watch?v=fvqx...layer_embedded |
05-28-2014, 21:37 | #3 (permalink) | |
Member: 739774 Status: Offline Thanks Meter: 89 | Quote:
I can get in the phone, setting the time, Wifi etc... At last step phone ask me the account! So I can't go to the menu! | |
05-28-2014, 21:41 | #4 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | To flash it, follow these steps: This Guide will show you the right method you should follow to update the Software of any Samsung Galaxy S5 device, That means you can use it to update SM-G900F, SM-G900H, SM-G900T and other variants too, The most important thing is to use the right Firmware files package for each variant. In this Guide we will use Samsung Galaxy S5 SM-G900H full firmware files package as an example, But the steps are the same for all variants. Preparation Steps: 1- Check the current firmware of your mobile, You can check it from Setting > About Phone, Or you can use this easy code *#1234# 2- It is a good idea to write down your device current firmware version, It will be useful later, In case something goes wrong. 3- Charge your mobile's battery to be at least at 90% of charging level. 4- Updating your mobile's firmware will delete everything from your device internal memory. 5- In case you have an external memory card inserted into your mobile, Then remove it. 6- Download the Samsung USB Driver, And install it, Then restart your computer. 7- Download Odin3 program (Original Android Flasher), Extract to your computer's desktop. Odin3 v3.09.3 - Download - 4shared 8- Download The suitable Firmware package for your Galaxy S5 Variant, Select the version you want to install it into your mobile. Download G900FXXU1ANE2 PHN1AND3 Kit Kat zip 9- Extract the firmware package to a known location on your computer. Odin3 Settings: 1- Double click on Odin3.exe to run it. 2- These settings must be checked: Auto Reboot, F.Reset Time. 3- If you have the PIT file of your Samsung model, Then check: Re-Partition Installing the new Firmware into your Samsung Galaxy S5 Device: 1- After you put your mobile into Download Mode, Use the USB cable to connect it to your computer. 2- You have to wait until Windows detects the device and installs any needed drivers. 3- Look at Odin3 program's window, If the program detects your connected device correctly, You should see its COM Port number (0:[COMxx]). 4- You are ready to install the new firmware files into your Samsung mobile, Click Start button to begin. 5- After you click the Start button, Odin3 program will start to install the selected firmware files into the connected device. 6- Odin3 program will restart your Samsung mobile automatically after installing the firmware. 7- Wait until your mobile is restarted. 8- Look again at Odin3 program's window, If your see PASS! word in green, then the update was done successfully. 9- Disconnect your mobile. 10- When the mobile is fully on, Check the new installed firmware version. 11- Now you are ready to use the device, So reinsert the SIM and Memory cards, Restore your backup, And customize it. |
05-28-2014, 21:50 | #5 (permalink) | |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
You should get it into download mode and flash the latest version for THAT device only. Did you try to flash the firmware again, and then after that restore factory defaults? | |
05-28-2014, 21:57 | #6 (permalink) | |
I did all this steps, I have flashed with new firmware and after that reset. The phone still ask me google account. | |
10-29-2014, 16:49 | #11 (permalink) |
Freak Poster Join Date: Dec 2009 Location: UK. Worcester Age: 35
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | This solution works perfect.....Very easy. https://www.youtube.com/watch?v=E41tLyi59II |
01-05-2015, 23:57 | #12 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2323239 Status: Offline Thanks Meter: 0 | New solution I've searched over the net for methods, and the methods I found - none worked. Even other users posted they had no success. As of today I came up with my own method that works and has been tested on SM-G900V and I'll be testing on other devices as well. Video will be posted tomorrow on youtube with the tag #mattastechservice |
