Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
04-21-2015, 19:26 | #16 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | You can remove it either by hacking together a Wi-Fi workaround, OR you can properly hack it by using download mode and targeting the correct partition (hint hint). |
05-05-2015, 05:38 | #17 (permalink) |
Freak Poster Join Date: Sep 2009 Location: NEPAL
Member: 1128042 Status: Offline Sonork: 100.1666710 Thanks Meter: 155 | which tool/box supports samsung s5 lte sm-g900f reactivation lock solution..not support by octopus z3x bst..bst supports sm-900 reactivation lock but not g900f ???/ |
06-06-2015, 14:16 | #18 (permalink) |
Freak Poster Join Date: Mar 2015 Location: United Kingdom Age: 24
Member: 2368438 Status: Offline Sonork: 100.1660498 Thanks Meter: 5 | i fixed it with samsung account working 100%......### |
The Following User Says Thank You to norskgsm For This Useful Post: |
09-26-2015, 23:39 | #21 (permalink) | |
Junior Member Join Date: Jun 2012 Location: Indonesia Raya
Member: 1776148 Status: Offline Thanks Meter: 1 | Quote:
I hope can remove from cwm rooted adb command from computer | |
12-26-2015, 20:55 | #22 (permalink) | |
Junior Member Join Date: Dec 2015
Member: 2506532 Status: Offline Thanks Meter: 0 | Hello all! Right now I'm facing the same problem with Samsung Galaxy S5 SM-G900H: Quote:
Any workaround on this? Many thanks!!! | |
05-16-2016, 14:10 | #23 (permalink) |
Junior Member Join Date: Sep 2007
Member: 598532 Status: Offline Thanks Meter: 6 | 1.sidesync-browser-goto www.goo.gl/7uGVMn -download the apk. goto browser history -download history-open apk install it. 2.goto settings-application tab click on all tab and disable and clear Samsung account and then disable Samsung setup wizard.. 3.go back to setup screen and it wont ask u to put reactivation credentials.. note thaat its an temperory byepass..u can use the mobile fully except the reactivation lock tick will remain on.. |
08-23-2016, 17:51 | #25 (permalink) |
Junior Member Join Date: May 2012 Location: -ChD-
Member: 1754487 Status: Offline Thanks Meter: 0 | in S5 is possible.............first of all 1) RESET default EFS than ..... 2) apply Factory reset & wipe cache 3) create new SAMSUNG account online (on computer---https://account.samsung.com/membership/service/getServieInfoList.do) 4) final step activate S5 with this new account.... 10000% tested on kit-kat after reads of YOUR ALL ABOVE discussion & YOUTUBE video posted above also .....but i think, this is accidently..... |
09-20-2017, 05:40 | #26 (permalink) |
Banned Join Date: May 2015 Location: pakistan sialkot
Member: 2392825 Status: Offline Thanks Meter: 49 | SAMSUNG s5 6.0.1 samsung account 1000% Done by waqas mobile SAMSUNG s5 6.0.1 samsung account 1000% Done by waqas mobile with disabler apps 100000% teseted best regards waqas mobile |
09-20-2017, 05:47 | #27 (permalink) | |
Member: 2392825 Status: Offline Thanks Meter: 49 | SAMSUNG Account Bypass 100% SAMSUNG S7,S6,S5,S7 Edge,Note 4 Marshmallow ... Quote:
samsung s5 android 6.0.1 1000000% Working solution here http://forum.gsmhosting.com/vbb/f777...0-1-a-2263040/ | |
10-19-2019, 13:23 | #28 (permalink) |
Junior Member Join Date: Jan 2017 Location: Bujumbura, BURUNDI
Member: 2672138 Status: Offline Thanks Meter: 1 | Helloo everyone i just bypassed the S5(G900F) samsung account 6.0.1 so here are the steps: -you must have a working samsung account -power on your phone tap 3times to activate the talkback and go on to the browser -download quickshortcutmaker;install it and open it get into settings create password -go to backup and reset do a factory reset it will ask the password you created then log in with your own account -finally the phone will restart and format "reactivation off" enjoy 100% working tested by me |
The Following User Says Thank You to Laden2 For This Useful Post: |
