Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-28-2019, 16:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | how to change Carrier S10 VZW to TMB |
05-29-2019, 02:54 | #2 (permalink) | |
Insane Poster Join Date: Apr 2017 Location: Anaheim California
Member: 2710649 Status: Offline Thanks Meter: 47 | Quote:
Simple, flash U1 firmware input tmobile simcard reboot to set up tmobile settings, and after you can flash stock firmware doesn't matter if the regular firmware is from tmobile/sprint... as long as u change input the tmobile simcard at U1 ... | |
The Following User Says Thank You to Christina714 For This Useful Post: |
05-29-2019, 04:27 | #3 (permalink) |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | thanks info thank you sir for answer i already do that but firmware change but inside phone not change phone dont boot with logo verizon but carrier change anyway phone unlock without problem. this method change completely carrier this phone i see ********* coming with change carrier CSC/VZW cost 2 credits i want to if for other s10 ask code or what? |
06-01-2019, 06:38 | #4 (permalink) | |
Freak Poster Join Date: May 2017 Location: USA
Member: 2718897 Status: Offline Thanks Meter: 49 | Quote:
Sent from my SamPWND device! | |
06-25-2019, 01:00 | #9 (permalink) |
Member: 2710649 Status: Offline Thanks Meter: 47 | No need to flash special files, its the same flash U1 firmware "make sure you have inserted the simcard that u want the device to be", reset the device and flash stock firmware and you will have converted the device to whatever simncard you inserted ... |
06-26-2019, 00:22 | #12 (permalink) | |
Freak Poster Join Date: Jul 2016
Member: 2596108 Status: Offline Thanks Meter: 58 | Quote:
Do you have skype or Whatsapp I always see you on the forums but we never. PS tried to sent you a dm but says your inbox full | |
06-26-2019, 01:53 | #14 (permalink) | |
i know about that tool, Or you can do it the long way flashing U1 firmware with simcard in example Tmobile, reset it and it will ask to change carrier setting eccept, and after flash stock firmware and it will turn on original tmobile software i done all of them like that with no issue... | |
06-26-2019, 02:08 | #15 (permalink) | |
