Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-20-2012, 18:28 | #2 (permalink) |
Crazy Poster Join Date: Feb 2012
Member: 1719364 Status: Offline Thanks Meter: 1 | Master Reset S7562 1-Hold volume - and + Home and Power when the appliance model appears on screen release the Power button longer stay tight, (- and +) is the Home until Roob, ai vai (wipe data / factory reset) |
The Following User Says Thank You to lig-cell For This Useful Post: |
04-17-2013, 21:50 | #3 (permalink) | |
Junior Member Join Date: Dec 2005
Member: 204514 Status: Offline Thanks Meter: 3 | Quote:
dear i trai last 2 day but today my worck is done sir | |
The Following 3 Users Say Thank You to kamlesh1980 For This Useful Post: |
04-21-2013, 16:48 | #4 (permalink) |
No Life Poster Join Date: May 2009 Location: android efs
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | samsung s7562 hard reset done vol+ vol- and home pwr on samsung s7562 hard reset done |
The Following 7 Users Say Thank You to rajakhank3 For This Useful Post: |
04-23-2013, 12:26 | #5 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1922719 Status: Offline Thanks Meter: 3 | If you want to hard reset your phone you may follow following steps, I read here, Android Forum - Samsung Android Phones But I would like to warn you that you must take a backup of your phone too: Within 10 seconds, need to hold down three buttons simultaneously: 1 - click on the "Inclusions" 2 - the main screen (or the menu button on the phone) 3 - volume knob (press the volume down rocker "down"). But note: all the settings of your phone will be reset to the factory, and all third-party programs will be removed permanently. |
The Following 3 Users Say Thank You to anna_mariya For This Useful Post: |
06-15-2013, 05:20 | #7 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: Bhilwara(Rajasthan)India
Member: 643992 Status: Offline Sonork: 100.1625367 Thanks Meter: 180 | Quote:
Thanks Brother it will working well i will do this job 100% working well.thanks | |
The Following User Says Thank You to jkniji For This Useful Post: |
08-11-2013, 12:10 | #9 (permalink) |
Insane Poster Join Date: Oct 2011 Location: india
Member: 1669353 Status: Offline Sonork: muralisanu Thanks Meter: 3 | Last edited by ..::Nokian CareŽ::..; 09-28-2013 at 12:28. Reason: image resized |
The Following User Says Thank You to muralisanu For This Useful Post: |
10-20-2013, 07:48 | #10 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Mumbai Age: 43
Member: 523792 Status: Offline Thanks Meter: 96 | Quote:
check this linksamsung Duos s7562 hardreset 0 - YouTube | |
11-12-2013, 09:22 | #11 (permalink) |
No Life Poster Join Date: May 2012 Location: Sherghati (gaya) Bihar Age: 31
Member: 1761355 Status: Offline Sonork: 0818211 Thanks Meter: 105 | samsung s7562 volume - home power button downloding mode |
The Following User Says Thank You to abishekkumar For This Useful Post: |
12-10-2013, 09:08 | #12 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Aurangabad,Murshidabad,W.B. Age: 36
Member: 911173 Status: Offline Sonork: 1648990 Thanks Meter: 20 | 100% done flash by Odin only BOOTSPL file when you flashing mark auto reboot. after flash set well restart and come to recovery menu then format and reboot thats it otherwise on options to hand reset |
The Following User Says Thank You to manaswb For This Useful Post: |
12-27-2013, 13:59 | #15 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | solution not work only show recovery mode Samsung S7562 Galaxy S Duos Hard Reset Steps: - Make sure that your Samsung S7562 Galaxy S Duos is Off, And has no SIM or Memory cards are inside. - Take out its battery for 10 seconds, Then put it in again. - Press and hold Volume Up + Volume Down + Home Keys, Then press Power. - Keep pressing the above keys until Samsung logo appears,Then release all keys. - Wait until you are into Factory reset / System Recovery menu. - Use Volume Down key to scroll down and select Wipe Data / Factory Reset option. - Use Power button to confirm the operation. - You need to use the Volume Down key again to select "Yes -- delete all user data" - Use Power button to confirm the operation one more time. - After performing the hard reset, Select Reboot System Now option, And confirm it using Power button. - Now the phone will reboots, Wait for it to be fully on and then you can start using it. Notice: The Hard Reset / Factory Reset operation will delete anything that are saved in your phone's internal memory, So make a backup of your data in case you can access them. |
