Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-26-2013, 15:35 | #16 (permalink) |
Freak Poster Join Date: Dec 2011 Location: india
Member: 1701545 Status: Offline Thanks Meter: 100 | first press power key suddenly press vol plus and home key (center key ) after on display release only power key not vol up and home key after that phone show whipe data factory reset use up down for volume key press power is for ok this is work 1000000000%%%%%%%%%% |
12-21-2013, 11:48 | #18 (permalink) |
Major Poster Join Date: Apr 2008
Member: 742687 Status: Offline Sonork: sunilbansal Thanks Meter: 21 | s7262 hard reset first press power key suddenly press vol plus and home key (center key ) after on display release only power key not vol up and home key after that phone show whipe data factory reset use up down for volume key press power is for ok |
01-13-2014, 16:37 | #20 (permalink) |
Freak Poster Join Date: Sep 2012 Location: saudi jeddah
Member: 1814409 Status: Offline Sonork: 100.1621741 Thanks Meter: 25 | Samsung SHW-M440S "Usim Personalization Please Enter your 4 digit password Welcome to Octoplus/Octopus Box Samsung software version 1.4.4 ----------------------------------------------------------------------------------- To connect SHW-M440S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. Selected firmware file: PIT_M440SKSJMH2_M440SSKTAMH2 _SKT_Android_4.1.2.oct Please switch your phone to the download mode and connect it to a PC. To put SHW-M440S phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PIT section... PIT section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SHW-M440S Searching for a phone. Please wait... Phone found. Firmware compiled date: Thu Aug 22 16:31:51 KST 2013 PDA version: M440SKSJMH2 CSC version: M440SSKTAMH2 SW version: M440SKSMH2 Phone IMEI: 352316053380204 Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SHW-M440S Detected phone model: SHW-M440S Firmware compiled date: Thu Aug 22 16:31:51 KST 2013 PDA version: M440SKSJMH2 CSC version: M440SSKTAMH2 SW version: M440SKSMH2 Phone IMEI: 352316053380204 Phone SN: R33C61DSDD Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SHW-M440S-Unknown13-01-2014_20-29-19-.asec file Cheking security type... Old security type is detected Unlocking phone. This can take some time. Please wait... Phone will restart now Phone is successfully unlocked |
01-21-2014, 10:38 | #21 (permalink) |
Freak Poster Join Date: Dec 2006 Location: India
Member: 407037 Status: Offline Thanks Meter: 15 | samsung 7262 hard reset first press power on button aftre 2seconds(do not swtch on mobile)press menu and volume+ after mobile on remove only power on button.after few seconds you will show wipe data mode. |
01-21-2014, 12:30 | #22 (permalink) |
Insane Poster Join Date: Sep 2011 Location: Shirdi.saibaba
Member: 1662575 Status: Offline Thanks Meter: 7 | s7262 hard reset first press power key suddenly press vol plus and home key (center key ) after on display release only power key not vol up and home key after that phone show whipe data factory reset use up down for volume key press power is for ok 1000000000%.ok |
01-25-2014, 11:22 | #24 (permalink) | |
Junior Member Join Date: Apr 2005 Location: india Age: 52
Member: 136516 Status: Offline Thanks Meter: 1 | Quote:
Thanks works 100%........................ | |
The Following User Says Thank You to tawsalkar For This Useful Post: |
02-04-2014, 14:32 | #25 (permalink) |
Junior Member Join Date: May 2009
Member: 1036150 Status: Offline Thanks Meter: 10 | Samsung s7262 hard reset done first press power key 2 second than press vol plus and home key after on display release only power key not vol up and home key show whipe data factory reset use up down for volume key press power key hard reset done |
02-08-2014, 15:26 | #28 (permalink) |
Insane Poster Join Date: Aug 2010 Location: INDIA-GUJARAT-BHAVNAGR-MAHUVA
Member: 1358451 Status: Offline Sonork: [email protected] Thanks Meter: 8 | yes its works for me 100% tested thanks to all.............. |
02-09-2014, 09:58 | #30 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | just boot it ,then when you see pattern lock connect usb cable to pc ,, open cmd , make sure you have adb install and write ,," adb reboot recovery" without quotes |
