Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
08-25-2014, 15:51 | #1 (permalink) | |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | how to root samsung galaxy s6790N [ROOTED] download the TOOL ,, > here enable USB debug at the phone OPEN runme.bat PRESS or choose method "0" wait till be finished then rebooted after it, you can unlock it here is log with z3x Quote:
The Following User Says Thank You to BesfortShalaTec For This Useful Post: |
08-26-2014, 10:12 | #2 (permalink) | ||
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | youtube VIDEO rooting log Quote:
UNLOCKING VIA CHIMERA Quote:
09-29-2014, 11:31 | #3 (permalink) |
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Also have in hand ,again this phone and i will tell you that i rooted succsesfuly with vroot this version |
10-11-2014, 11:58 | #4 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Serbia Age: 46
Member: 303852 Status: Offline Thanks Meter: 32 | ================================================== ==================== = This script will root your Android phone with adb restore function = = Script by Bin4ry (thanks to Goroh_kun and tkymgr for the idea) = = Idea for Tablet S from Fi01_IS01 = = (14.12.2013) v33 = ================================================== ==================== Device type: 0) Xperia Root by cubeundcube 1) New Standard-Root (thx Ariel Berkman) 2) New Xperia Root by Goroh_kun (Xperia Z, Xperia V [JellyBean] ...) 3) Old 4) Old-Special (for example: Sony Tablet S, Medion Lifetab) G) Google Glass Mode (thx Saurik for the ab file) x) Unroot Make a choice: 0 Please connect your device with enabled USB-Debugging ... * daemon not running. starting it now on port 5037 * * daemon started successfully * Copy needed files ... 1110 KB/s (17768 bytes in 0.015s) 3268 KB/s (104576 bytes in 0.031s) 3343 KB/s (2139595 bytes in 0.625s) 3311 KB/s (1165484 bytes in 0.343s) 9 KB/s (148 bytes in 0.015s) 130 KB/s (2092 bytes in 0.015s) Running Exploit ro.build.product=nevisnvess ro.build.id=JZO54K setsockopt() failed: Bad address. this device is not supported. kallsyms_ad******* search failed. Rebooting now, after reboot all should be done! You can close all open command-prompts now! After reboot all is done! Have fun! Bin4ry Press any key to continue . . . |
11-02-2014, 18:04 | #5 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2285583 Status: Offline Thanks Meter: 0 | It doesn't work HI, i have tried to root the phone with your method but it does't work. After i have pressed 0 and enter it give the message of error: error protocol fault (status read) copy needed files ... error more than one device and emulator error more than one device and emulator error more than one device and emulator Help me please |
11-11-2014, 12:59 | #6 (permalink) | |
11-11-2014, 13:02 | #7 (permalink) | |
Is it was the same S6790N Android 4.1.2 ? | |
11-11-2014, 13:17 | #8 (permalink) | |
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Quote:
step 1 make sure to unistall Blue Stack , if not than unistall HiSuite ! Problem solved All the best Last edited by BesfortShalaTec; 11-11-2014 at 13:18. Reason: speelling | |
02-11-2015, 13:34 | #9 (permalink) |
Junior Member Join Date: Sep 2009 Location: Kosovo/Prizren
Member: 1116371 Status: Offline Sonork: Boom Thanks Meter: 0 | Selected model: S6790N Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-S6790N Android version: 4.1.2 Product code: Unknown Phone version: S6790NXXAMJ1 PDA version: S6790NXXAMK1 CSC version: S6790NORTAMJ2 IMEI: Phone S/N: Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done thanks |
03-11-2015, 08:39 | #11 (permalink) |
No Life Poster Join Date: Feb 2015 Location: PAKISTAN (OMAN) Age: 35
Member: 2340225 Status: Offline Sonork: 100.1662389 Thanks Meter: 367 | [QUOTE=mandy singh;10917450]hi i want to download odin software but not able to do pLZ bro search on Google sammobile and go inside sammobile site here a lot number of model only Odin files all samsung latest n old ... Best Regards ... Saif Ur Rahman |
The Following User Says Thank You to saifjaan009 For This Useful Post: |
07-23-2015, 22:40 | #14 (permalink) |
Freak Poster Join Date: Sep 2014 Location: Banjul The Gambia Age: 34
Member: 2257138 Status: Offline Thanks Meter: 11 | hello to gsm bet, sorry there is something that has been disturbing me yet no solution, THE question is if a Samsung phone couldn't go to menu , then how can you enable usb debugging on your phone? pls i need hellp. |
