Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 10-29-2014, 14:00   #31 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Originally Posted by AntonioMast View Post
Hi, I do the root to a Samsung Galaxy XCover 2 GT-S7710, help me.
Read carefully the procedure for Root:
Root the Samsung Galaxy Xcover 2 (GT-S7710)
allumts
Old 10-30-2014, 05:39   #32 (permalink)
Moderator
gsm mithun roy's Avatar
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,219
I9500_4.4.2_I9500XXUFNB4_Kitkat_Root & disable knox security here
Imp note : this root guide only for 9500XXUFNB4 running 4.4.2 firmware only...!!
downlod required file :
https://mega.co.nz/#!O4pWSJ4Q!RQaW6o...BTbY1uxcTLgOKc
  • Run the Odin3 v3.09.exe file as an administrator
  • Now connect your Galaxy S4 I9500 to your computer via USB cable (downlod mode )
  • Make sure that, only the “Auto Reboot” and “F. Reset Time” options are checked.
  • Now, click on the AP (PDA in older Odin) button and select the CF-Auto-Root-ja3g-ja3gxx-gti9500.tar.md5 file.
  • Finally, click on the Start button to begin the rooting process, wait few moments.
The Following 2 Users Say Thank You to gsm mithun roy For This Useful Post:
Old 10-30-2014, 05:55   #33 (permalink)
Member: 1734313
Sonork: 100.1620886
Thanks Meter: 70
bro...pls upload this file in 4shared or mediafire ...........thx in advance
Old 10-30-2014, 06:06   #34 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
[SM-N910*] Note 4 CF-Auto-Root
Source XDA Developers
Thanks Goes to " Chainfire "
Follow these instructions to the letter. Do not touch any buttons or checkboxes that are not listed below to touch!
- Download and unzip the CF-Auto-Root-....zip file (see posts below this one)
- If you end up with a recovery.img and cache.img file, you've extracted twice. You need to end up with a .tar.md5 file - don't extract that one
- (USB) Disconnect your phone from your computer
- Start Odin3-vX.X.exe
- Click the PDA button, and select CF-Auto-Root-....tar.md5
- Put your phone in download mode (turn off phone, then hold VolDown+Home+Power to boot - if it asks you to press a button to continue, press the listed button, or run adb reboot download command)
- (USB) Connect the phone to your computer
- Make sure Repartition is NOT checked
- Click the Start button
- Wait for Android to boot
- Done (if it took you more than 30 seconds, you need practise!)
NOTE: Sometimes the device does *not* boot into recovery mode and root your device. Just do the entire procedure again if this happens. If it still will not install root and such, make sure that in Odin "Auto Reboot" is not checked. Then after flashing, pull the battery, and boot with VolUp+Home+Power button to boot into recovery manually. This will start the install process.
New to Samsung? Unfamiliar with Odin? Think all the above is a hassle? Get used to it. It's very simple, and us Samsung folk use Odin (or Mobile ODIN ) for everything! It's so very very convenient once you get used to it. Notice the 30 second comment above? For experienced users, the entire process indeed takes only 30 seconds!
Download
SM-N910F (International, Qualcomm): CF-Auto-Root-trlte-trltexx-smn910f.zip
SM-N910G (Asia, Qualcomm): CF-Auto-Root-trlte-trltedt-smn910g.zip
SM-N910H (Asia, Exynos): CF-Auto-Root-tre3g-tre3gxx-smn910h.zip
SM-N910T (T-Mobile USA, Qualcomm): CF-Auto-Root-trltetmo-trltetmo-smn910t.zip
SM-N910P (Sprint, Qualcomm): CF-Auto-Root-trltespr-trltespr-smn910p.zip
SM-N910R4 (US Cellular, Qualcomm): CF-Auto-Root-trlteusc-trlteusc-smn910r4.zip
SM-N910W8 (Canadia, Qualcomm): CF-Auto-Root-trltecan-trltecan-smn910w8.zip
SM-N910C (Thailand, Exynos): CF-Auto-Root-trelte-treltexx-smn910c.zip
SM-N910U (Hong Kong, Exynos): CF-Auto-Root-trhplte-trhpltexx-smn910u.zip
SM-N910K (Korea, Exynos): CF-Auto-Root-treltektt-treltektt-smn910k.zip
SM-N910L (Korea, Exynos): CF-Auto-Root-treltelgt-treltelgt-smn910l.zip
SM-N910S (Korea, Exynos): CF-Auto-Root-trelteskt-trelteskt-smn910s.zip
SM-N9100 (China, Qualcomm): CF-Auto-Root-trltechn-trlteduoszc-smn9100.zip
SM-N9106W (China, Qualcomm): CF-Auto-Root-trltechn-trlteduoszn-smn9106w.zip
SM-N9108V (China, Qualcomm): CF-Auto-Root-trltechn-trltezm-smn9108v.zip
SM-N9109W (China, Qualcomm): CF-Auto-Root-trltechn-trlteduosctc-smn9109w.zip
Other models
CF-Auto-Root is not yet available for all models - one stock firmwares for these models become available CF Root also Available ,
Old 10-30-2014, 11:18   #35 (permalink)
Member: 1164437
Sonork: 100.1659986
Thanks Meter: 23
any body have root file for glaxy i9003.plz i need
Old 10-30-2014, 12:19   #36 (permalink)
allumts's Avatar
Member: 1564612
Hi, use this Root and guide from here: SuperOneClick
allumts
Old 10-30-2014, 13:19   #37 (permalink)
Member: 1734313
Sonork: 100.1620886
Thanks Meter: 70
Originally Posted by [SIZE=3
More G900f Kernel
here
[/SIZE]
bro...are all of these are root file for G900F having these firmware ver ????
Old 10-30-2014, 13:53   #38 (permalink)
allumts's Avatar
Member: 1564612
Hi, please not spam here, if want ROOT for S5 G900F ok make request.
No there's any Kernel or other trouble here, only Root for you device G900F if have need this.
allumts
Old 10-30-2014, 14:12   #39 (permalink)
Member: 1713335
root file for sm-G310HN pls
Old 10-30-2014, 14:53   #40 (permalink)
allumts's Avatar
Member: 1564612
Hi, try with this root, with me have worked:
Towelroot V3
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 11-01-2014, 07:49   #41 (permalink)
Member: 153875
Thanks Meter: 35
How to root samsung sm-g310h
Old 11-02-2014, 06:21   #42 (permalink)
Member: 1108126
Thanks Meter: 3
how to root samsung 6102,6802
Old 11-02-2014, 11:45   #43 (permalink)
allumts's Avatar
Member: 1564612
Please, for all, post always exact model like "GT-S6102" or "GT-6802".
Anyway here you Root for only these 2 models:
ROOT Galaxy Y Duos (GT-S6102) Galaxy ACE Duos (GT-S6802)
_______
allumts
Old 11-02-2014, 12:02   #44 (permalink)
allumts's Avatar
Member: 1564612
Here you Root for you device, loock carefully Fw version
G130HXXU0ANG6_ROOT.tar
There are Root in .zip for other Fw version for this model
allumts
Old 11-03-2014, 06:54   #45 (permalink)
Member: 1813831
Down load vroot for your windows xp/7/8/vista connect your phone with usb cable start usb debugging if your device is connected in vroot click the root phone few secounds latter displayed message your device is rooted succsefully
Page generated in 0.23298 seconds with 8 queries
