Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 12-01-2016, 05:10   #1 (permalink)
Member: 2072293
Thanks Meter: 7
How to secure root g610f ?
I would like to unlock Samsung j7 prime (g610f) but need first root, how this will secure root ?
I need root way.
Thanks.
Old 12-01-2016, 06:17   #2 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 256
brother install TWRP , and flash supersu2.74 ,......
Old 02-06-2017, 09:44   #3 (permalink)
Member: 2681537
ROOT the divice with CWM and now u can remove root by using kingo root
Old 02-06-2017, 11:12   #4 (permalink)
irfanbatti's Avatar
Member: 2631161
Thanks Meter: 746
Samsung G610F Complete Root Method
I need root way.
Thanks.
Samsung J7 Prime G610F Complete Root Method:
You can find the download page here:
Dev-Host - TWRP(G610F).tar - The Ultimate Free File Hosting / File Sharing Service
Use Odin to flash.
You can find a zip containing Odin as well as a link to Samsung's Mobile drivers page here:
https://idlekernel.com/flash-tools/
FULL STEPS TO INSTALL TWRP
In your ROM, go to Settings -> About device. Tap 7 times on Build number to enable Developer options.
Now go to Settings -> Developer options. (above About device)
You need to enable OEM unlock, otherwise you might end up with boot problems or be unable to flash later on.
Make sure your don't have Factory Reset Protection enabled in your Google account or you may never be able to boot again!
More information: https://support.google.com/nexus/answer/6172890?hl=en
Extract Odin_3.11.1.zip to your computer.
Install Samsung Mobile Phone Drivers for Odin to find your device.
Download the .tar image of TWRP for G610F.
Reboot your device into Download mode. To do this, select reboot from the power menu and hold the [Volume Down] + [Home] buttons while your device reboots.
Once you reach the Download mode warning screen, press [Volume Up] to continue.
Open Odin and place that TWRP tar file in the [AP] slot, under Options tab disable Auto Reboot, then press [Start].
Once the flash is complete (Odin should tell you in the log, and progress bar on phone should stop).
Now hold [Volume Down] + [Home] + [Power] buttons until the device turn off and at the very second leave the [Volume down] button and hold [Volume Up] button along with [Home] + [Power] buttons until you reach recovery mode.
If you end up in stock recovery, start again from download mode step.
Then connect the USB Mouse to the Device via OTG adapter.
At this point, you will reach the screen asking you if you want to allow system modifications.
You will want to swipe to allow, otherwise the OS will replace TWRP once you boot!
To root with SuperSU:
Download the latest SuperSU by Chainfire.
Without exiting TWRP, transfer the SuperSU zip to your device using ADB SIDELOAD to install the zip. (Incase Storage doesn't mount due to force encryption)
Go to [Reboot] -> [System].
CHANGES
v3.0.2-0 - Initial build
ENJOY!!!!
Don't Say Thanks, Just Hit THANKS Button
Page generated in 0.23871 seconds with 7 queries
