Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 11-19-2018, 06:20   #1 (permalink)
Member: 2849208
Thanks Meter: 6
How To Use Samsung Odin 3.13.1 Latest Version
Samsung Odin is a utility tool for Smasung smartphone users. Odin is the flashing utility software available for smasung smartphones and the tablet devices. On the other hand, Samsung Odin is now stable with Android 8.0 oreo supported smartphones and the tablet devices. So you are a user looking for more details about flash tool suggest you check this post carefully.
Samsung Odin 3.13.1 Changelog
Samsung Odin 3.13.1 is the latest Odin version available for now. This version is compatible with Samsung Galaxy devices such as S9+, S9, S8+, S8.
Odin Download Requirements
Here are the basic requirements that you should accomplish before making use of this flashing tool.
You are supposed to have a PC which runs under Windows operating system.
Download Latest USB drivers into your windows PC.
USB a proper USb cable to connect your mobile and the PC
Download ADB and Fastboot into your device.
Consider About These Things
Remember to take a complete backup of your valuable data which included in your handset before executing the flashing procedure
Suggest you download the latest Odin version and also latest Samsung USB drivers.
Download a compatible custom ROM for your mobile. But remember that due to the huge variety of Samsung devices procedure of flashing and rooting may also differ from one to another.
Odin Use Step Guide
Step 1: Backup all your existing data.
Step 2: Download Odin into your PC and right click on it and run it as the administrator.
Step 3: Boot your smasung in to download mode.
Note: power off your mobile and press and hold the power button, volume down button and the home button altogether for several seconds. Yellow color triangular warning mark should appear and then press the volume up key in order to switch to the download mode. This will shift to another window saying "Downloading" and "Do not turn off target!!".
Step 4: Now connect your mobile to the PC using a proper USB cable.
Step 5: if your mobile is detected by the Odin tool a message will display as "Added" in the left lower right area of the Odin window.
Step 6: Now Click on AP or PDA buttons. but this depends.
Step 7: Once you click on the above button a window will show up to load the firmware file.
Step 8: Select the firmware you need to flash and click on the start button.
Step 9: After the completion of the flashing procedure a green color button will display as reset or pass but this depends on your application version.
Page generated in 0.11856 seconds with 8 queries
