Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-25-2014, 07:54 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | I8530 Galaxy Beam Firmware need As i know it's uk firmware product code...and i need this firmware... i flashed my Galaxy Beam with other firmware for some days ago. after that it showed "sim network not register" i tried all things to solve it but noway... i am w8ing for someone help me.... |
09-25-2014, 08:15 | #2 (permalink) |
Freak Poster Join Date: May 2012 Location: Beirut Age: 39
Member: 1759307 Status: Offline Sonork: 100.1636995 Thanks Meter: 56 | if u have riff box or z3x easy jtag make resurrection to fix the boot then flash any firmware you like, usually when u flash the chinese firmware ur problem will be solved but most languages are not available the first solution is the ideal i do that all the time for this phone |
The Following User Says Thank You to red_eagle For This Useful Post: |
09-25-2014, 17:07 | #3 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | My problem solved... i flashed it by Home Product Firmware and problem solved log is here: <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> I8530XXLI2_I8530BTULI1_HOME.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/055> Added!! <ID:0/055> Odin v.3 engine (ID:55).. <ID:0/055> File analysis.. <ID:0/055> SetupConnection.. <ID:0/055> Initialzation.. <ID:0/055> Set PIT file.. <ID:0/055> DO NOT TURN OFF TARGET!! <ID:0/055> Get PIT for mapping.. <ID:0/055> Firmware update start.. <ID:0/055> SingleDownload. <ID:0/055> kernel.bin.md5 <ID:0/055> NAND Write Start!! <ID:0/055> modem.bin.md5 <ID:0/055> system.img.md5 <ID:0/055> power_management.bin.md5 <ID:0/055> cache.img.md5 <ID:0/055> hidden.img.md5 <ID:0/055> RQT_CLOSE !! <ID:0/055> RES OK !! <ID:0/055> Removed!! <ID:0/055> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) |
