i9000 back button + Home button Not wroking hi Guys Can Any 1 hv the SOlution Ov This Prob ?? :mad: |
my friend use modified cable. and put ur phone in download mode. and flash it. |
you can clip for this if your phone ok but if your phone dead repair boot |
Menu and Back key not working - SOLVED Turn off the mobile phone ..., remove the battery, insert the memory card, insert battery, turn on the mobile, then go into Settings --- >>> ---- >>> SD card and phone storage--- >>> ----->>>> Unmount SD card..., then Mount SD card and it's done .... The problem will be solved Menu and Back key now working :cool: |
I did this with n7100 Problime solved but Ofter Few Secands Same Problim Again is back Some one heve Other Solution ?? |
