I9003 Stuck ON Samsung Logo 100% Tested Solution 1. Download and run odin. 2. Check Re-Partition, Auto Reboot and F. Reset Time. 3. Click PIT button and select this file: latona_20110114.pit 4. Put your phone into download mode: Press Volume down + Home + Power. 5. Connect USB cable and the program will detect the phone's Com number. 6. Click Start button to download the PIT file to phone. 7. After it is Done Click on Reset button, then un-select Re-Partition box. 8. Click PDA button and select this file: I9003xxxxx-xxx...-PDA-low-CL890053.tar.md5 9. Click PHONE button and select this file: MODEM_I9003xxxxx_REV_00_CL889972.tar.md5 10. Click CSC button and select this file: GT-I9003-CSC-xxxxxx.tar.md5 11. Remove the battery, then enter Device into Download Mode again. 12. Click Start button to flash these files to phone. 13. Do not touch anything till you see PASS on the program window. 14. Just do a factory reset after flashing using recovery Download This File I9003BHKP8_XEGKP6_v2.3.6_Repair_Firmware.rar [Credit Tsar300] I9003XXKB3.rar [Credit junin M.] I9003_Odin3_v1.82 |
Most case hardware problem, with software not solve. if make any photo or save something phone restart again and loop on Samsung logo! br! |
Hay I M Sol 3 headset TODAY SAM iSSUE And I m Not TOLK hardware Relation Problem Is Software related Issue If U Not Understand Chak Hire forum POST http://forum.gsmhosting.com/vbb/f777...-logo-1608596/ http://forum.gsmhosting.com/vbb/f777...-logo-1606603/ http://forum.gsmhosting.com/vbb/f777...-logo-1606602/ http://forum.gsmhosting.com/vbb/f777...-logo-1601456/ http://forum.gsmhosting.com/vbb/9423055-post88.html |
;)thanks i slove one with this solution but i need arabic |
Guide = given @ tsar3000 if it is software issue ( maybe then solved) if hardware not solved I am facing issue here ( flashed by odin z3x 3-4 files versions no success . http://forum.gsmhosting.com/vbb/f453...7/#post9277744 |
upp dsnt work..İnvalid md5 |
if some one wrong flash or update 2.2 to 2.3.6 then phone hang on samsung and restart then you flash with above solution its working well -- butt if phone have hardware problem its notwork or become unknown baseband |
find this file for that and follow above instruction |
request i tried to flash my i9003 many times but not success it showing md 5 hash invalid, how can i solve this problem please help me:eek: |
Thanks this solution working ;) i sold one phone its in my hand working welll :D :::::::::: Hussain :::::::D |
successfuly flashed but still on samsung logo Quote:
problem unsolved Quote:
Also this problem coming from hardware fault can't be solved by software Sent from my LT26i using Tapatalk |
