Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 02-05-2013, 22:39   #1 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 407
I9003 Stuck ON Samsung Logo 100% Tested Solution
1. Download and run odin.
2. Check Re-Partition, Auto Reboot and F. Reset Time.
3. Click PIT button and select this file: latona_20110114.pit
4. Put your phone into download mode: Press Volume down + Home + Power.
5. Connect USB cable and the program will detect the phone's Com number.
6. Click Start button to download the PIT file to phone.
7. After it is Done Click on Reset button, then un-select Re-Partition box.
8. Click PDA button and select this file: I9003xxxxx-xxx...-PDA-low-CL890053.tar.md5
9. Click PHONE button and select this file: MODEM_I9003xxxxx_REV_00_CL889972.tar.md5
10. Click CSC button and select this file: GT-I9003-CSC-xxxxxx.tar.md5
11. Remove the battery, then enter Device into Download Mode again.
12. Click Start button to flash these files to phone.
13. Do not touch anything till you see PASS on the program window.
14. Just do a factory reset after flashing using recovery
Download This File
I9003BHKP8_XEGKP6_v2.3.6_Repair_Firmware.rar [Credit Tsar300]
I9003XXKB3.rar [Credit junin M.]
I9003_Odin3_v1.82
Last edited by ...:::::NP™:::::...; 07-26-2017 at 03:01. Reason: Firmware link has been update
The Following 2 Users Say Thank You to bux_harun For This Useful Post:
Old 02-05-2013, 22:54   #2 (permalink)
ebu mohammed-emin's Avatar
Member: 263993
Sonork: 100.1612432
Thanks Meter: 169
Most case hardware problem, with software not solve.
if make any photo or save something phone restart again and loop on Samsung logo!
br!
Old 02-05-2013, 23:22   #3 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 407
Arrow
Originally Posted by ebu mohammed-emin View Post
most case hardware problem, with software not solve.
if make any photo or save somthing phone restart again and loop on samsung logo!
br!
Wot U MEEN I M TIME PASS HIRE?
Hay I M Sol 3 headset TODAY SAM iSSUE
And I m Not TOLK hardware Relation Problem Is Software related Issue
If U Not Understand Chak Hire forum POST
I9003 stuck on SAMSUNG logo
i9003 stuck on logo !
i9003 stuck on samsung logo !
All Samsung Programs & Flashers here
Old 03-12-2013, 14:02   #4 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 199
thanks i slove one with this solution but i need arabic
Old 03-17-2013, 21:17   #5 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 328
Guide = given @ tsar3000
if it is software issue ( maybe then solved)
if hardware not solved
I am facing issue here ( flashed by odin z3x 3-4 files versions no success .
I9003 super lcd (i9003 sl) retsrat issue not fixced evenbyflash
Old 07-14-2013, 00:45   #6 (permalink)
Member: 1568803
Thanks Meter: 10
upp dsnt work..İnvalid md5
Old 07-14-2013, 01:07   #7 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 688
if some one wrong flash or update 2.2 to 2.3.6 then phone hang on samsung and restart
then you flash with above solution its working well
butt if phone have hardware problem its notwork or become unknown baseband
Old 07-14-2013, 01:08   #8 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 688
I9003JPKP5_OJPKP6_Android_2.3.4
find this file for that
and follow above instruction
Old 07-19-2013, 12:27   #9 (permalink)
Member: 218086
Sonork: 0111010001011101010111010
Thanks Meter: 73
Solution here Good solution to revive i9003
The Following User Says Thank You to tsm2318 For This Useful Post:
Old 09-04-2013, 10:52   #10 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 105
Originally Posted by tsm2318 View Post
please bro give me links to those files
Old 09-16-2013, 19:04   #11 (permalink)
Member: 2013800
request
i tried to flash my i9003 many times but not success it showing md 5 hash invalid, how can i solve this problem please help me
Old 11-12-2013, 09:39   #12 (permalink)
Hussain_Mobile's Avatar
Member: 681758
Sonork: 100.1676160
Thanks Meter: 336
7. After it is Done Click on Reset button, then unselect Re-Partition box.
Download This File
Hotfile.com: One click file hosting: I9003_XXKA7.rar
Hotfile.com: One click file hosting: I9003XXKB3.rar
Odin & Pit File
http://www.mediafire.com/?fixnulivqyn2xak
Thanks this solution working
i sold one phone its in my hand working welll
:::::::::: Hussain ::::::
Old 11-22-2013, 03:29   #13 (permalink)
Member: 229658
Thanks Meter: 58
successfuly flashed but still on samsung logo
I carefully followed the process one after the other, my phone was successfuly flashed and did factory setting after it yet the phone still hanging on samsung logo and keep rebooting itself. Any other solution?
Old 11-22-2013, 03:44   #14 (permalink)
Member: 229658
Thanks Meter: 58
problem unsolved
Download This File
Odin & Pit File
Old 11-22-2013, 04:22   #15 (permalink)
coolmfarshard's Avatar
Member: 1085379
Thanks Meter: 65
Also this problem coming from hardware fault can't be solved by software
Sent from my LT26i using Tapatalk
Page generated in 0.40567 seconds with 7 queries
