Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 06-15-2013, 15:28   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 542
i9020 how to flash pls guide me
i have download done from tsar3000
i dont know how to run that soft?
Old 06-15-2013, 15:41   #2 (permalink)
Member: 1681183
Sonork: 100.1637594
Thanks Meter: 65
Thumbs down
download firmware from this link Hotfile.com: One click file hosting: I9020XXJK1.zip
open odin select 3 file
code = in pda
modam = in phone
csc = in csc
Put the phone into Download Mode: Press Middle of Volume Key and Connect USB cable.
now connect your phone and press start after finish successfully
enjoy .done
The Following User Says Thank You to sm_shahzada For This Useful Post:
Old 06-15-2013, 16:34   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 542
code = in pda
modam = in phone
csc = in csc
enjoy .done
when i press volume center it is show ( unlock bootloader )
it is unlock
when i press start it is failed
Old 06-15-2013, 16:58   #4 (permalink)
Member: 1681183
Sonork: 100.1637594
Thanks Meter: 65
Thumbs down
it is unlock
send me tv id or skype id
my skype id is happy_happy117
Old 06-17-2013, 14:58   #5 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 542
problem solved thanks to you
Old 06-17-2013, 15:36   #6 (permalink)
Member: 1164608
Sonork: 100.1650273
Thanks Meter: 79
bro just put only pda file also it helps.
Old 06-17-2013, 16:45   #7 (permalink)
Member: 1681183
Sonork: 100.1637594
Thanks Meter: 65
Talking
you welcome for every time
Old 06-18-2013, 13:59   #8 (permalink)
gerferomb's Avatar
Member: 840912
Sonork: 100.1596244
Thanks Meter: 88
please post how you did it. Because I also like that problem now
Old 06-18-2013, 16:12   #9 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 542
Originally Posted by gerferomb View Post
please post how you did it. Because i also like that problem now
select pda : Pda
phone : Bootloader
csc : Csc
try get success sure
after flash last end will failed but if you check manually
will done sure
i have done
Old 06-18-2013, 16:35   #10 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,374
Firmware Update Steps:
  1. Run Samsung
  2. I9003_P7100_Odin3 v1.82 - Download - 4shared
  3. Put the phone into Download Mode: Press Middle of Volume Key and Connect USB cable.
  4. You can see ( Downloading...) on the phone LCD.
  5. The program must read the Com number it takes.
  6. Click BOOT button and select:Bootloader_I9020xxxxx.tar.md5
  7. Click Phone button and select: MODEM_I9020xxxxx_REV_00_CL912571_SIGNED.tar.md5
  8. Click PDA button and select: PDA_SOJU_xxxx.....tar.md5
  9. Click CSC button and select: DGS_I9020_EUR.tar
  10. Click Start button and the update process will start.
  11. Do not touch or remove anything till the device rebooted and you can see PASS word on the program.
Old 06-18-2013, 16:40   #11 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,374
Download firmware i9020 from this link:
Samsung I9020 Firmwares:
Android 2.3.3:
Hotfile.com: One click file hosting: I9020XXJK1- GRH78.rar
Old 12-19-2013, 11:30   #12 (permalink)
Member: 1991356
this link is not working sir
Page generated in 0.34317 seconds with 7 queries
