Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 03-06-2015, 08:17   #1 (permalink)
amer_a_82's Avatar
Member: 610529
Sonork: 100.1612153
Thanks Meter: 18
i9060i camera failed
hello team ....
i have a problem with 10 pcs of samsung i9060i a problem camera failed
any one help me in solve or any one have full flash 4 files ????
Old 03-14-2015, 07:51   #2 (permalink)
amer_a_82's Avatar
Member: 610529
Sonork: 100.1612153
Thanks Meter: 18
I founded full flash for it but same problem it is a hardware probelm any help
Old 03-15-2015, 12:20   #3 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,628
upload his pcb board (rather large and obvious)
I will help
Old 03-24-2015, 18:07   #4 (permalink)
Member: 2368155
Sonork: 100.1654440
With respect
I Have 20 Pcs Samsung I9060i Problem Camera Failed
Some Model i Change Camera Ok Problem
Thank You For your's Help
Resemblance Model Camera G360H , G355H , I9060I
The Following User Says Thank You to Amir Abdolahi For This Useful Post:
Old 03-25-2015, 10:21   #5 (permalink)
Member: 2368155
Sonork: 100.1654440
please help
i have 20 pcs
Old 03-26-2015, 16:47   #6 (permalink)
Member: 2224721
Thanks Meter: 3
my dear i have shop and i had same problem... its from the camera its self try to resend them back or u will have to change the camera for each one of them and the camera of i9060 works on 9060i..
Old 04-09-2015, 00:09   #7 (permalink)
Member: 759172
Thanks Meter: 6
try this full flash
me tested work fine
****************************/folder/vms...8793yq3/shared
pass : www,dzgsm,com
Old 04-10-2015, 09:14   #8 (permalink)
Member: 2163928
Thanks Meter: 4
this may be a very good rom, but unfortunately did not solve the problem for me.
Old 04-11-2015, 07:35   #9 (permalink)
Member: 2048880
Thanks Meter: 63
pass : www.gem-flash.com
this pass is ok
Old 04-11-2015, 18:34   #10 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 186
Go to settings ---application manager---ALL---camera---clear data---force stop ---back to main menue---restart phone
Old 04-23-2015, 14:23   #11 (permalink)
Member: 2331939
i flash phone by 4 file but my problem not solve
go to setting . application . all ..................
my problem not solve .
can help me to solve camera failed
Old 04-27-2015, 08:34   #12 (permalink)
Member: 689698
Sonork: 123456
Thanks Meter: 2
9060i camera
https://drive.google.com/file/d/0B2I...ew?usp=sharing
Old 05-09-2015, 20:21   #13 (permalink)
sgreenphone's Avatar
Member: 1513870
Thanks Meter: 46
same problem i have new 9060i camera failed i flash with i9060iXXU0ANL5_OJV0ANL4 but not solved some prob eny solution
Old 05-19-2015, 16:10   #14 (permalink)
Member: 2163928
Thanks Meter: 4
do this at your own risk!
i strongly suggest swapping a new camera module.
but if you dont mind,
heating the back of camera (put it upside down) for:
60sec, d=2cm, medium nozzle, 300'C air 3/10 can solve the problem, but cant guarantee this as a permanent fix. you will more probably destroy the lens at first try, i had the chance testing multiple modules. some worked, some were fried, most were out of focus and some returned with same problem next day.
The Following User Says Thank You to idlirp For This Useful Post:
Old 05-21-2015, 08:03   #15 (permalink)
Member: 1002113
Sonork: leealbert
replaced camera that's only the solution 100% working
Page generated in 0.21057 seconds with 8 queries
