Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
08-16-2014, 14:57 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Age: 41
Member: 449518 Status: Offline Thanks Meter: 585 | I9195 4.4.2 update problem <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> I9195XXUCNEA_I9195VFGCNE4_I9195XXUCNEA_HOME.tar.md 5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/015> Odin v.3 engine (ID:15).. <ID:0/015> File analysis.. <ID:0/015> SetupConnection.. <ID:0/015> Initialzation.. <ID:0/015> Get PIT for mapping.. <ID:0/015> Firmware update start.. <ID:0/015> SingleDownload. <ID:0/015> sbl1.mbn <ID:0/015> NAND Write Start!! <ID:0/015> sbl2.mbn <ID:0/015> sbl3.mbn <ID:0/015> aboot.mbn <ID:0/015> rpm.mbn <ID:0/015> tz.mbn <ID:0/015> boot.img <ID:0/015> recovery.img <ID:0/015> system.img.ext4 <ID:0/015> NON-HLOS.bin <ID:0/015> cache.img.ext4 <ID:0/015> hidden.img.ext4 <ID:0/015> FAIL! (Ext4) <ID:0/015> <ID:0/015> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/015> Removed!! <ID:0/015> Added!! <ID:0/015> Removed!! |
08-16-2014, 15:40 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Here I leave the solution to avoid problems: Needed Programs and Files: - Odin3 Flasher. Odin3 v3.09.3 - Download - 4shared - Samsung Galaxy S4 Mini LTE GT-I9195 USB Driver. Download USB Drivers exe - I9195XXUCNE6 / YPRCNE2 Firmware Update Package, Check if there is a suitable one for your Country and Carrier. Download I9195XXUCNEA VFGCNE4 VD2 Germany Vodafone Kit Kat zip Preparation Steps: 1- Download Odin3 flasher and extract it. 2- Extract the I9195XXUCNE6 / YPRCNE2 Firmware Update Package. 3- Download and install the Samsung USB driver. 4- Restart your Computer. 5- Backup any wanted data on your device. 6- Charge your device battery to be at 80% minimum. 7- It is better to make Factory Data Reset, That can keep you away from some errors later. 8- Enable USB debugging option. Installing XXUCNE6 Android 4.4.2 KitKat Update on your Galaxy S4 Mini LTE GT-I9195 1- Turn off your Galaxy S4 Mini LTE GT-I9195, And take out its SIM and Memory card. 2- Put your Galaxy S4 Mini LTE into Download Mode. 3- Connect it to your Computer using the USB cable. 4- Wait for a couple of seconds to let your PC recognize the device. 5- Run Odin3.exe as Administrator. 6- Make sure that Re-Partition option is not checked. 7- If Odin3 flasher detects your Galaxy S4 Mini LTE GT-I9195 correctly, You will see its COM port number 0:[COMxx] 8- Click on AP button and select: I9195XXUCNE6_I9195YPRCNE2_I9195XXUCNE6_HOME.tar.md 5 9- Click on Start button, Odin3 will begin to install the new firmware on your device. 10- After the installing is done, Your Galaxy S4 Mini LTE will be rebooted automatically. 11- When your device is on again, Disconnect it from your PC. 12- When it is completely on, Check the new installed firmware. 13- Done, And now you have the new XXUCNE6 Android 4.4.2 KitKat firmware installed on your Galaxy S4 Mini LTE GT-I9195. |
08-16-2014, 15:43 | #3 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | In my opinion, I always recommend using original Samsung firmwares that can download from the official website. So you can avoid corrupt firmware and flash to give your phone with the latest version. |
11-16-2014, 07:23 | #4 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: Pakistan
Member: 628369 Status: Offline Sonork: 100.1609794 Thanks Meter: 48 | Quote:
12-19-2014, 00:20 | #7 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 191183 Status: Offline Thanks Meter: 18 | I have same problem cant repair,flashed lot of diferent flashes but even some flashes past without this error:FAIL! (Ext4) Still it cant boot normaly.I tryed wipe&reset before and after flashing but same.Phone is brand new and customer brick it while upgrading 4.2.2 to 4.4.2. Any advice to repair this.... Thanks WBR |
12-29-2015, 21:11 | #8 (permalink) |
No Life Poster Join Date: Feb 2002 Location: germany Age: 49
Member: 9584 Status: Offline Thanks Meter: 31 | i have also the same problem. i used root file for 4.2.2 now the phone turns on bootloader mode. i cannot flash it. sometimes error with pit file sometimes it flashes 100% and at the end problem with ext4 file. please send us a solution for it if somebody has it. |
