Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-26-2014, 02:15 | #1 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2266701 Status: Offline Thanks Meter: 0 | i9505 can't connect to a network please help Selected model: I9505 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.18.0 Selected model: I9505 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.18.0 Selected model: I9505 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.18.0 |
11-26-2014, 08:23 | #3 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Heart
Member: 2144988 Status: Offline Sonork: 100.1655364(Offline) Thanks Meter: 217 | Post In Right Section Always What You Want? Post Here Full Detail First Root Phone After Root Update Su If Your Phone is Unlocked And Not Registerd on network Write Cert In Phone Wbr Hifzul Amin |
11-26-2014, 21:08 | #5 (permalink) | |
Freak Poster Join Date: Oct 2014
Member: 2284628 Status: Offline Thanks Meter: 47 | Quote:
root phone 1st open super user update binary and disable knox conect via the usb cable #0808# choose modem+adb wait for drivers to install select com port in z3x repair im ei or rite new qcn or cert file | |
The Following User Says Thank You to repairs.wales For This Useful Post: |
12-04-2014, 00:43 | #6 (permalink) |
Member: 2266701 Status: Offline Thanks Meter: 0 | Thanks guys I spent so long looking around the forum. So one more question how do I update binary and disable knox, I opened super user but can't see the options ? do I need to upgrade to pro? Thanks again |
12-04-2014, 11:22 | #7 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
- Root easy with this: CF-Auto-Root-jflte-jfltexx-gti9505 , (can find in google or here "root any device" thread, above button in dasboard forum), flash with Odin in AP/PDA fiel with phone in D.Mode. - at restart, (not touch nothingh first), go in app and click in SU icon, "disable Knox" press ok - Uptate you Z3X to 18.3 you are using obsolete version. - Set phone how "Help Button", *#0808# "DM+MODEM+ADB" for microusb cable - connect phone to usb 2 directly motherboard pc an open Z3X sw then select I9505 - If have 4.3 or more gigh fw version, ceck "New Security" and z3x usb port - Make operaction you want, if unlock, or with "Read codes", (if supported), or direct "Unlock - For Imei, NOT skipe "Nv Bkc Read/write", then press "Repair" insert you Imei and press ok - leave that sw work, phone reboot 1/2 time, then finish - Insert unaceptated sim or wich have issue, wait 3/4 min.s if not get signal, search manually network, (this only first time), select and enjoy P.d. not have write procedure with QCN or CERT becouse for this model isn't necessary, tested 100% use only Thanks button as forum rules BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
12-10-2014, 11:37 | #9 (permalink) | |
Post always in right secrtion, this isn't Z3X section. BR allumts | |
