Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
06-23-2013, 12:42 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | [ Informations ] [Galaxy s4 GT-I9505X ] Demo Phone Becoz I9505 & i9505x Both not Same and After Flash you will be lost The Phone Wifi |
The Following 6 Users Say Thank You to Faheem Anjum For This Useful Post: |
06-23-2013, 13:05 | #2 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Here Is the Method How to Repair Wifi After Flash with offical Firmware of I9505 Here is the method to repair Such Problems After Flash with official Firmware of I9505 Need To Download Some Tools and files Download GT-I9505_AdamKernel.V1.4.CWM.zip Download openrecovery-twrp-2.5.0.2-jfltexx.tar Download any Eur Firmware From Sam mobile.com and Flash demo phone Fst using odia ( in modam.bin software will give you Error Failed ) don,t Worry Its Normal , disconnect cable and do factory Rest From recovery (Phone Will be Power On Normally But Wifi Will Not Work ) Don,t Worry Will be Repair Inshallah Connect phone in download mode to odia and flash the phone (openrecovery-twrp-2.5.0.2-jfltexx.tar) in PDA tab 2nd step Copy (GT-I9505_AdamKernel.V1.4.CWM.zip) To Phone memory Boot the Phone in Recovery Mode once again and flash (GT-I9505_AdamKernel.V1.4.CWM.zip) using twrp custom recovery Done Restart Phone And Enjoy Wifi Will start Work Once Aagain , Thanks goes to Mr.novidadesandroid From Porto Alegre Brasil |
The Following 22 Users Say Thank You to Faheem Anjum For This Useful Post: |
08-28-2013, 19:34 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | If you will flash normal firmware on I9505x, odin will stop at flashing modem... Demo units don't have modem hardware, so you need firmware without modem, or just download a pre rooted firmware, rename it by removing .md5 extension, so you'll have i9505XXXX.tar, open it with 7-zip, delete NON-HLOS.bin and modem.bin and flash it... Or download a 3/4 part firmware and flash it without modem file. |
08-30-2013, 13:42 | #6 (permalink) |
Insane Poster Join Date: Jul 2010 Location: Iran
Member: 1344017 Status: Offline Thanks Meter: 17 | Hi do we can change i9505x to i9505 ? this mean : I like to change language and i9505x not support my language ,now i flash it with i9505 frimware ..after this i will write "T-I9505_AdamKernel.V1.4.CWM.zip"... now if my phone is i9505 and I wirte "GT-I9505_AdamKernel.V1.4.CWM.zip" , wifi problem will be solve or not ? |
08-31-2013, 08:05 | #7 (permalink) | |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
when odin failed mdm flashing simple do wipe data from recovery phone will be power on i think no need any other firmware | |
08-31-2013, 08:08 | #8 (permalink) | |
The Following 4 Users Say Thank You to Faheem Anjum For This Useful Post: |
10-09-2013, 14:22 | #9 (permalink) |
Freak Poster Join Date: Dec 2011
Member: 1699784 Status: Offline Thanks Meter: 20 | Welcome to Octoplus/Octopus Box Samsung software version 1.3.6 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options->About Device. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM19 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM19 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM19 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW Version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW Version: Old IMEI: Unknown New IMEI: 358454-04-118693-0 Repairing NVM for GT-I9505 phone... Writing NVM failed NVM repair completed successfully Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW Version: Old IMEI: Unknown New IMEI: 358454-04-118693-0 Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: GT-I9505 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM19 Selected model: GT-I9505 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW Version: Old IMEI: Unknown New IMEI: 358454-04-118693-0 Write IMEI failed PHONE IS OK BUT CNT REPAIR IMEI PLZ HELP ME |
10-14-2013, 21:21 | #11 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Pakistan Age: 45
Member: 16520 Status: Offline Sonork: 1580837 Thanks Meter: 90 | for samsung galaxy s 4 mini model 9195x you need to flash only this firmware I9195XXUAMH1_I9195TENAMH2_I9195XXUAMH1_HOME.tar no need to edit or delete anything it will work |
10-26-2013, 12:45 | #12 (permalink) | |
just refresh the phone using this firmware :I9505XXUAMDC_I9505H3GAMD6_H3G will be okay everything tested | |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
10-28-2013, 06:37 | #13 (permalink) | |
Banned Join Date: Oct 2001 Location: JMB Age: 49
Member: 6919 Status: Offline Thanks Meter: 12 | Quote:
obviously it gives modem error at the end. but after recovery written the phone reboots but again stuck on the samsung logo. And now i cant boot normally even after wiping data. Br | |
11-02-2013, 10:43 | #14 (permalink) | |
11-02-2013, 19:36 | #15 (permalink) |
No Life Poster Join Date: Mar 2008 Location: PAKISTAN TO PORTUGAL
Member: 720201 Status: Offline Sonork: 100.0000000 Thanks Meter: 643 | dear FAHEEM ANJUM after flashing with original i9505 can we use sim in i9505x i have i9505x but it dont have imei when i start mobile just samsung films run continously any solution for using sim plzz |
