Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
12-06-2019, 09:46 | #1 (permalink) |
Freak Poster Join Date: Aug 2017 Location: IN THIS WORLD
Member: 2752048 Status: Offline Thanks Meter: 58 | J415f after flash 9008 port only . need usb boot repair solutions wihout jatag box, |
12-10-2019, 10:34 | #5 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1870226 Status: Offline Thanks Meter: 52 | I had same issue with this phone and on even j6+ remove battery and charge battery full with multi charger for these type of batteries. This trick worked for me you should also try that. |
12-19-2019, 16:42 | #7 (permalink) |
Freak Poster Join Date: Jan 2018
Member: 2796172 Status: Offline Thanks Meter: 42 | Try to completly discharge the battery. i.e. connect usb mouse through OTG or charge another phone. and then once it's flat, try to connect it in download mode. If it works, don't press volume up, because then the phone is not charging. Leave it at the first screen after you get into download mode. But at this first screen the charging is very slow, so leave if for couple of hours before you start flashing |
