Hy! Problem solved! Flash phone with Chimera tool > use Enable PIT Flashing Checking firmware presence... Firmware version: J600FNXXU3ARH1/J600FNOVF3ARH1/J600FXXU3ARH1/J600FNXXU3ARH1 Firmware version friendly name: Oreo(Android 8.0.0) Starting / Resuming firmware download. Downloading firmware... Selected model: SM-J600FN Extracting firmware... Unzipping firmware: BL_J600FNXXU3ARH1_CL13907417_QB19217820_REV00_user _low_ship.tar.md5. Unzipping firmware: AP_J600FNXXU3ARH1_CL13907417_QB19217820_REV00_user _low_ship_meta.tar.md5. Unzipping firmware: CP_J600FXXU3ARH1_CP10343104_CL14123308_QB19216166_ REV00_user_low_ship.tar.md5. Unzipping firmware: HOME_CSC_OMC_OVF_J600FNOVF3ARH1_CL14125916_QB19219 329_REV00_user_low_ship.tar.md5. Unzipping firmware: CSC_OMC_OVF_J600FNOVF3ARH1_CL14125916_QB19219329_R EV00_user_low_ship.tar.md5. Processing firmware... Flashing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-J600F, Region: CIS, Provider: SER, PDA: J600FNXXU3ARH1 Checking PIT file: J6LTE_CIS_SER.pit Writing PIT file to phone. Reading PIT from phone. PIT written to file "Backup/SM-J600FN/PIT/SM-J600FN_45188872.pit" Flashing boot.img Flashing recovery.img Flashing system.img Flashing vendor.img Flashing userdata.img Flashing sboot.bin Flashing param.bin Flashing cm.bin Flashing modem.bin Flashing modem_debug.bin Flashing cache.img Flashing omr.img Flashing odm.img Flashing hidden.img Restarting phone. Successfully finished. Phone working now! BR! |
chimera need license or 3 day start license. i flash it with odin without PIT. may be i m lucky? |
restart problem witout any box SOLVED..need export pit file from csc. after open odin select full firmware(wipe),after select pit file with pit tab and flash. |
Hi guys ! I am in trouble with a J600FN sec.3: I just flashed the combination security 3 and then, when I'm trying to flash the stock from, everything is flashing okay but I end up with a boot loop 🤔. OEM/frp lock are off Firmwares are downloaded from a previous post J600FN security 3 both of them. Anyone have any idea? Thank you, cheers ! |
Edit: with the sboot from security 3 combination, the stock security 3 firmware has just booted up. Now on the first screen of bootloader I can see the green text up in the right corner. Why the sboot from combination 3 can boot up a stock security 3 firmware...and with the sboot from the stock firmware I can not boot up the phone? I am trying to solve that because it is annoying the green text on bootloader form the sboot combination. Thank you, maybe someone have a good sboot from stock sec.3 |
Same problem as above - bootloop after flash with stock BIN 3. Any solution, mates? |
Found the solution. After flashing with COMBI BIN 3, flash this stock firmware https://shell.boxwares.com/Download.aspx?L=10616 |
By the way, what's the exact solution for removing FRP of this set, mates? I dont see any box, which support this set for FRP erase. And when I flash combination file, the set is FRP/OEM off, but then, when I flash stock rom, it's asking me for google account. So? |
Ok, Im sorry for multiposting. I found that too. I managed to pass the FRP. By the way, in the "GSM Flasher FRP Reactivation Lock Remover Pro" mentioned before, there's no J600F/FN model. |
And about the bootloop problem, which occur after flashing with stock rom, you have to find PIT file, click Repartion and flash. After that the phone might restart again, even more agressively. And at this point you have to hold vol - and vol + and insert cable in the right moment, between the restarts, so you can put the phone into download mode. After that you have to flash the same rom but without pit file. Voila. |
Hello! If u can't remove FRP with combination; try this way. https://www.youtube.com/watch?v=3Zdh...ture=********* Maybe help you. for me work on other model. |
j600 restart after flash with combination file then oem lock off then reflash with chimera. it works for me:cool::cool:;););) |
j600 frp reset hi all im having same problem after flash keeps restarting will not go back in flash mode-- ive tried volume down and power button still restarts any hepl i have z3xbox |
SM-J600FN FRP Remove Done with tested File Process 1- Download File 2-Flash with Odin 3-use Z3X or any samsung Tool 4- HIT FRP and done Note: Download link also have flashing and unlock instructions |
