i have issue i have download several files still stuck not flashing j600f b-1 k:2 s:2 and the file am flashing is b3 my question now is why is -1 instead of 1 and i cant flash any firmware i need help |
These are the exact steps I did to remove frp from J600FN with z3x. Some steps maybe are not required. 1. Flash COMBINATION_FAC_FA80_J600FNXU3ARH5 and enable OEM UNLOCK, hard reset. 2. Flash J600FNXXU3BSD2_OXM3BSD2. Now phone will bootloop. 3. In z3x select pit J6LTE_CIS_SER.pit, check repartition and FLASH (do not select any FLASH file). Now phone will go in crazy bootloop mode. Will go only recovery mode. 4. In z3x select J600FNXXU3BSD2_OXM3BSD2 flash file, check repartition (do not select any pit file) and press FLASH. 5. Now phone will boot normally in Android 9.0. If you have reset with sim card then hard reset again. |
Hallo, i followed your steps and now phone really goes crazy. No recovery, no download mode, it is not recognized by computer. Any hint ? |
I need combination file for J600FN U4 version. Thk. |
Need Combination for BIT4 latest security, please share it if you have Unable to reset FRP at Bit4 until now Phone has installed J600FNXXU4BSF8_J600FNOBE4BSF8_J600FXXU4BSF3_J600FN XXU4BSF8_EVR |
remove the spaces when you copy the link because the forum does not copy the link https:// halabtech . com / j600fn-u4-reset-frp-ازالة-حساب-جوجل-j600fn-u4/ Video remove frp j600fn u4 by Halabtech https://www.youtube.com/watch?v=oX4ZZsAsU5Q Or use this new method All SAMSUNG JULY 2019 FRP/Google Lock Bypass Android 9 Pie WITHOUT PC - NEW METHOD !!! https://www.youtube.com/watch?time_c...&v=FlNogYzGDu8 |
does not work with me. samsung j600fn U4. not work hush sms too. |
Tested solution for binary U4: http://forum.gsmhosting.com/vbb/f777...-help-2638712/ Quote:
Samsung J600G Binary U4 Combonation Frp Solution |
I had the same issue ,and was worse for me the phone kept rebooting,so i used a uart cable 300k tp put the phone in download mode (i my situation i couldn't even put the phone on download mode ) 1)flash combination file ,and tick oem unlock 2)flash only pit file and tick repartion 3)flash stock firmware ,tick repartion+pit file Thats what i did Στάλθηκε από το SM-N960F μου χρησιμοποιώντας Tapatalk |
I thing combination is the best method to remove FRP lock download J600f combination file to remove FRP lock Download Samsung Galaxy J6 2018 J600F Combination file FRP file |
