Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 10-03-2018, 08:56   #31 (permalink)
george gsm's Avatar
Member: 14200
Thanks Meter: 85
Hy!
Problem solved! Flash phone with Chimera tool >
use Enable PIT Flashing
Checking firmware presence...
Firmware version: J600FNXXU3ARH1/J600FNOVF3ARH1/J600FXXU3ARH1/J600FNXXU3ARH1
Firmware version friendly name: Oreo(Android 8.0.0)
Starting / Resuming firmware download.
Downloading firmware...
Selected model: SM-J600FN
Extracting firmware...
Unzipping firmware: BL_J600FNXXU3ARH1_CL13907417_QB19217820_REV00_user _low_ship.tar.md5.
Unzipping firmware: AP_J600FNXXU3ARH1_CL13907417_QB19217820_REV00_user _low_ship_meta.tar.md5.
Unzipping firmware: CP_J600FXXU3ARH1_CP10343104_CL14123308_QB19216166_ REV00_user_low_ship.tar.md5.
Unzipping firmware: HOME_CSC_OMC_OVF_J600FNOVF3ARH1_CL14125916_QB19219 329_REV00_user_low_ship.tar.md5.
Unzipping firmware: CSC_OMC_OVF_J600FNOVF3ARH1_CL14125916_QB19219329_R EV00_user_low_ship.tar.md5.
Processing firmware...
Flashing firmware...
Waiting for download mode.
Connecting.
SBL Info: Model: SM-J600F, Region: CIS, Provider: SER, PDA: J600FNXXU3ARH1
Checking PIT file: J6LTE_CIS_SER.pit
Writing PIT file to phone.
Reading PIT from phone.
PIT written to file "Backup/SM-J600FN/PIT/SM-J600FN_45188872.pit"
Flashing boot.img
Flashing recovery.img
Flashing system.img
Flashing vendor.img
Flashing userdata.img
Flashing sboot.bin
Flashing param.bin
Flashing cm.bin
Flashing modem.bin
Flashing modem_debug.bin
Flashing cache.img
Flashing omr.img
Flashing odm.img
Flashing hidden.img
Restarting phone.
Successfully finished.
Phone working now! BR!
The Following 4 Users Say Thank You to george gsm For This Useful Post:
Old 10-05-2018, 14:16   #32 (permalink)
Member: 195717
Thanks Meter: 54
chimera need license or 3 day start license. i flash it with odin without PIT. may be i m lucky?
Old 11-24-2018, 06:20   #33 (permalink)
sahip's Avatar
Member: 2063130
Thanks Meter: 120
restart problem witout any box SOLVED..need export pit file from csc. after open odin select full firmware(wipe),after select pit file with pit tab and flash.
The Following 2 Users Say Thank You to sahip For This Useful Post:
Old 11-27-2018, 07:30   #34 (permalink)
Member: 1968997
Sonork: 12
Thanks Meter: 2
Hi guys !
I am in trouble with a J600FN sec.3: I just flashed the combination security 3 and then, when I'm trying to flash the stock from, everything is flashing okay but I end up with a boot loop 🤔.
OEM/frp lock are off
Firmwares are downloaded from a previous post J600FN security 3 both of them.
Anyone have any idea?
Thank you, cheers !
Old 11-27-2018, 09:43   #35 (permalink)
Member: 1968997
Sonork: 12
Thanks Meter: 2
Edit: with the sboot from security 3 combination, the stock security 3 firmware has just booted up. Now on the first screen of bootloader I can see the green text up in the right corner.
Why the sboot from combination 3 can boot up a stock security 3 firmware...and with the sboot from the stock firmware I can not boot up the phone?
I am trying to solve that because it is annoying the green text on bootloader form the sboot combination.
Thank you, maybe someone have a good sboot from stock sec.3
Old 12-02-2018, 14:05   #36 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 109
Ya bro same problem here to writing stock sboot and boot put the phone in bootloop but writing from combo the phone will boot in setup wizard but after 5 sec.. It will reboot automatically. Anyone have solution for this?
Old 12-04-2018, 09:48   #37 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 326
Same problem as above - bootloop after flash with stock BIN 3. Any solution, mates?
Old 12-04-2018, 12:38   #38 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 326
Found the solution. After flashing with COMBI BIN 3, flash this stock firmware https://shell.boxwares.com/Download.aspx?L=10616
The Following User Says Thank You to DundyTM For This Useful Post:
Old 12-04-2018, 13:12   #39 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 326
By the way, what's the exact solution for removing FRP of this set, mates? I dont see any box, which support this set for FRP erase. And when I flash combination file, the set is FRP/OEM off, but then, when I flash stock rom, it's asking me for google account. So?
Old 12-04-2018, 14:03   #40 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 326
Ok, Im sorry for multiposting. I found that too. I managed to pass the FRP. By the way, in the "GSM Flasher FRP Reactivation Lock Remover Pro" mentioned before, there's no J600F/FN model.
Old 12-05-2018, 14:21   #41 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 326
And about the bootloop problem, which occur after flashing with stock rom, you have to find PIT file, click Repartion and flash. After that the phone might restart again, even more agressively. And at this point you have to hold vol - and vol + and insert cable in the right moment, between the restarts, so you can put the phone into download mode. After that you have to flash the same rom but without pit file. Voila.
The Following 2 Users Say Thank You to DundyTM For This Useful Post:
Old 12-06-2018, 14:36   #42 (permalink)
george gsm's Avatar
Member: 14200
Thanks Meter: 85
Hello!
If u can't remove FRP with combination; try this way.
https://www.youtube.com/watch?v=3Zdh...ture=*********
Maybe help you. for me work on other model.
Old 12-10-2018, 16:25   #43 (permalink)
Member: 2820992
j600 restart
after flash with combination file then oem lock off then reflash with chimera.
it works for me
Old 12-24-2018, 12:15   #44 (permalink)
jab
Member: 12386
Thanks Meter: 17
j600 frp reset
hi all im having same problem after flash keeps restarting will not go back in flash mode--
ive tried volume down and power button still restarts
any hepl i have z3xbox
Old 12-26-2018, 05:59   #45 (permalink)
Member: 2764645
Thanks Meter: 60
SM-J600FN FRP Remove Done with tested File
Process
1- Download File
2-Flash with Odin
3-use Z3X or any samsung Tool
4- HIT FRP and done
Note: Download link also have flashing and unlock instructions
The Following User Says Thank You to Ubaidkhaliq For This Useful Post:
Page generated in 0.37024 seconds with 8 queries
