Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-14-2018, 06:38 | #1 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | j7 max g615f/ds feb 2018 security frp remove done j7 max g615f/ds feb 2018 security frp remove done connect to wifi enable talk back by 3 time pressing on home button Now draw L on screen now disable talk back type on search bar (Voice)and download quick shortuct maker install.quick shortcut maker. apps and open it search for calculator and click on it now click on try arrow text and calculator open nowtype this code on calculator,..,,. (+30012012732+ default calculator app now opened now enter code *#0808# select ap and on usb setting select dm+modem+adb and click on reboot reboot phone and insert usb cable into pc now you can see ..allow usb debuging ..option on your phone menu click on always allow usb debug now your phone ADB interface is enabled use any adb frp bypass tool OR software box to frp reset Code: UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Reset FRP Selected model: SM-G615F Software version: 29.9 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-G615F Android version: 7.0 Product code: SM-G615FZKDPAK Phone version: G615FXXU2ARA3 PDA version: G615FXXU2ARA4 CSC version: G615FODD2ARA4 CSC country code: PAKISTAN CSC sales code: PAK HW version: MP 0.200 Phone SN: R28K13QQK4K Chip name: MT6757 Modem board: MT6757 Security patch: 2018-01-01 RF cal date: 20180125 IMEI: 358514081453696 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.9 |
The Following 2 Users Say Thank You to taimur-ahmad For This Useful Post: |
