Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-04-2017, 14:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | j700f baseband unknow after flash any body have idea about that? i flashed j700f and after flash no imei and baseband is unknow |
The Following User Says Thank You to .:D:. For This Useful Post: |
03-04-2017, 16:38 | #2 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,109 | Fast flash with this firmware Code: Model SM-J700F Model name Galaxy J7 Country India Version Android 6.0.1 Changelist 10198822 Build date Mon, 16 Jan 2017 06:25:20 +0000 Security Patch Level 2017-01-01 Product code INS PDA J700FXXU3BQA2 CSC J700FODD3BPJ2 J700FXXU3BQA2_J700FODD3BPJ2_INS If you not done, re-flash with this firmware, Code: Model SM-J700F Model name Galaxy J7 Country Turkey Version Android 6.0.1 Changelist 9226746 Build date Wed, 07 Dec 2016 04:37:07 +0000 Security Patch Level 2016-12-01 Product code TUR PDA J700FXXS3BPL2 CSC J700FOJV3BPJ2 J700FXXS3BPL2_J700FOJV3BPJ2_TUR
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 5 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
03-06-2017, 05:56 | #3 (permalink) | |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | Quote:
03-06-2017, 09:02 | #7 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,109 | Don't worry. Do you have BST dongle, put your set with download mode & write Default Efs. Hopefully your problem wilbe solved. After post result.
The Following 2 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
03-06-2017, 10:05 | #8 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | ok tried with bst but still same, after flash you file, base band is come but after restart set again gone |
03-06-2017, 11:40 | #9 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | downlod this J700FXXS3BPL2_J700FOJV3BPJ1_KSA and flash now flash twrp-3.0.2-0-j7elte.img then install BETA-SuperSU-v2.74-2-20160519174328 reset Efs and msl via box tool you have then check baseband if ok then write cert or write imei then patch certificate note : is still same no baseband after reset efs then write fresh Efs and cert (ping if you need )
__________________ To get Instant help use "search" & follow "sticky thread"..!!! By respecting/following forum rules,You will be respected .! Best Wishes : [IMG]****************************/convkey/0fa4/qq0zcyol0fmauiu6g.jpg[/IMG] .:::Roy:::. |
The Following User Says Thank You to gsm mithun roy For This Useful Post: |
03-06-2017, 13:01 | #11 (permalink) | |
03-06-2017, 13:12 | #12 (permalink) |
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | did you try efs and cert
