Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-05-2018, 23:14 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | J710F FRP RB2 bypass files !! now once again after Samsung has colsed the DRParser Mode; the CALCULATOR method is no longer working !!! Now What ?? ok here's next I've created special file to enable ADB and bypass the FRP successfully .. use any of adb tools to bypas the wizard . here's command in case u want PHP Code: DOWNLOAD! it will cause a black screen after logo but it will enable Adb without authorization then use any smart tool to remove frp using adb or the command line at the top then u need to fix the dark screen using a stock boot so if u have latest build flash it or just the boot only or simply LOOK IN THE NEXT POST i hope u enjoyed guys press thanks button if the file works with u ------ B.r Devx Last edited by xx0o0xx1; 08-12-2018 at 20:33. |
The Following User Says Thank You to xx0o0xx1 For This Useful Post: |
