Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 06-08-2018, 15:31   #1 (permalink)
Ahmed Zitoon's Avatar
Member: 187853
Sonork: 100.1609563
Thanks Meter: 1,201
Mipi repair for free for samsung rooted devices
MIPI REPAIR FOR FREE FOR SAMSUNG ROOTED DEVICES
Click On Repair Mipi
Popup Will Show , And Go Setting , System , And Go To Rebuild Nvrm Then Reboot
http://download1651.mediafire.com/b5...pi+Repair+.rar
Br,
AhmedZitoon
The Following 29 Users Say Thank You to Ahmed Zitoon For This Useful Post:
Old 06-25-2018, 16:52   #2 (permalink)
Member: 187853
Sonork: 100.1609563
Thanks Meter: 1,201
wait next update , for tool soon
The Following 7 Users Say Thank You to Ahmed Zitoon For This Useful Post:
Old 07-10-2018, 00:05   #3 (permalink)
Member: 2689425
Thanks Meter: 8
itīs permanent solution?
or lose when perform data reset?
The Following User Says Thank You to elmunheco11 For This Useful Post:
Old 08-16-2018, 20:46   #4 (permalink)
..::KASHIF::..'s Avatar
Member: 1294044
Thanks Meter: 1,269
not show how ?>
Old 08-17-2018, 14:31   #5 (permalink)
Member: 1294044
Thanks Meter: 1,269
not show how ?>
My Fone Is DOne G930V must be Rooted mobile
( Ahmed Zitoon ) Thanks SO much
Root Link
EASY ROOT G930V / G935V - VERIZON GALAXY S7 / GALAXY S7 EDGE - NOUGAT SUPERSU ROOT KIT
https://www.youtube.com/watch?v=rgT2qWVWWJY
Old 09-11-2018, 11:48   #6 (permalink)
Member: 2555426
Thanks Meter: 5
thank u so much its work fine
Old 10-08-2018, 07:39   #7 (permalink)
Hafiz ArslanAli's Avatar
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
ADB not recognize......... all other tools are detecting but only your tool not detecting adb......
Old 10-08-2018, 10:37   #8 (permalink)
Member: 2698510
Thanks Meter: 2
Repair Mipi Tool By World1st Group
Developers Nurul Amin | AhmedZitoon
Phone must be rooted
Search Adb device....
>> Device Found!
Reading Info............
MANUFACTURER : SAMSUNG
HARDWARE : QCOM
MODEL : SM-N910F
BASEBAND : MDM2
BOARD : APQ8084
VERSION : 6.0.1
DEVICE TYPE :
COUNTRY CODE :
CONNECTION MODE : MTP,ADB
>> Device Found!
HARDWARE : QCOM
MODEL : SM-N910F
BASEBAND : MDM2
BOARD : APQ8084
VERSION : 6.0.1
DEVICE TYPE :
COUNTRY CODE :
Repair Mipi Success!!
Hints : Popup Will Show , Go Setting , System , And Go To Rebuild Nvrm Then Reboot
Popup not showing on SM-N910F what can i do Please help
Device is rooted with cf autoroot
Old 10-21-2018, 07:10   #9 (permalink)
Member: 2818059
Thanks Meter: 7
sir i have j 500f try with this tool but not show this method on my phone
Old 11-05-2018, 13:50   #10 (permalink)
Salman725626's Avatar
Member: 2488001
Sonork: 100.1669288
Thanks Meter: 295
>> Device Found!
HARDWARE : QCOM
MODEL : SM-J250F
BASEBAND : MSM
BOARD : MSM8937
VERSION : 7.1.1
DEVICE TYPE :
COUNTRY CODE :
CONNECTION MODE : DIAG,ACM,ADB
not show popup
Old 11-16-2018, 23:36   #11 (permalink)
Crazy Poster
Member: 2770461
Thanks Meter: 22
If the popup does not show, and the phone is rooted, simply install shortcut master lite.
Go to secret code explorer and open 27663368378.
You will be able to navigate from there to NVRAM Rebuild, though youll have to look it up for your device as the menu changes depending on the model and system.
Old 12-22-2018, 20:06   #12 (permalink)
Member: 2395171
Thanks Meter: 3
Dear sir
I have rooted samsung s7 g930t with superSU installed.
I am getting error 'ADB not recognise'
Please help. Need to repair mipi fail
Old 12-23-2018, 00:30   #13 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
Originally Posted by atin_garg View Post
Dear sir
full rooted mebay ur adb not detect try again it shoud work
Old 12-23-2018, 03:56   #14 (permalink)
Member: 2395171
Thanks Meter: 3
Yes. Actually my software was in other folder. It should be in same folder containing root files to work.
I got MIPI fixed. Network comes.
But i am still on root.
Now if i flash to stock, will it remain fixed or again will fail?
Pls advice
Old 12-23-2018, 04:38   #15 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
Pls advice
it temp fixed only keep use that dont flash any or wipe
The Following User Says Thank You to CHANDARAKK For This Useful Post:
Page generated in 0.22170 seconds with 9 queries
