Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 05-04-2019, 10:04   #1 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 263
samsung RPMB fuse problem
hello, i have problems on new samsung phone
1 is c7010
and t380
they only have frp
after i tried downgrading with combination file
it is now stuck in download mode with
RPMB fuse : -2
RPMB PROVISIONED
RP SWREV : s-2 t-2 r-2 a-2 p-2
and it will not accept any firmware anymore, latest and combination of any firmware
anyone knows where is the RPMB fuse located?
The Following User Says Thank You to eivelice For This Useful Post:
Old 05-12-2019, 23:56   #2 (permalink)
Member: 1899511
Thanks Meter: 23
Fuse -2 happened to my T380 Tab A tablet when I flashed wrong aboot and boot in the same TAR package.
So steps to fix it:
find the right combination firmware;
unzip it with 7zip archiver;
download TAR_MD5_PACKAGER;
open folder with unzipped comb_firmware and delete all files below from it:
-aboot,
-apdp,
-boot,
-devcfg,
-msadp,
-rpm,
-sbl1,
-tz.
copy all files what left to TAR_MD5_PACKAGER\parts;
start TAR_MD5_PACKAGER and press 1 to make tar file;
flash this file with Odin as AP;
now the fuse should switch to 1;
next flash the full combination file or stock firmware.
FUSE Number stands for software version,
samsung has protection against downgrading software,
So once you flashed firmware with number 2 in it, the device will change the fuse to 2 and after that
you will not able to flash anything less than with number 2 and so on.
The Following 3 Users Say Thank You to icealex19 For This Useful Post:
Old 05-12-2019, 23:56   #3 (permalink)
Member: 1899511
Thanks Meter: 23
I will make a video in couple of days.
Old 05-17-2019, 11:44   #4 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 263
So steps to fix it:
-aboot,
-apdp,
-boot,
-devcfg,
-msadp,
-rpm,
-sbl1,
-tz.
i tried any combi, it will not accept. error flashing because the tab thinks i am flashing lower bootloader
Old 05-23-2019, 03:40   #5 (permalink)
Member: 1899511
Thanks Meter: 23
Video solution fix for fused -2
Check the video - !! remove spaces in the link !!
https://www.youtube.com/watch?v=XqU-WUZYgbY&t=145s
Old 05-24-2019, 18:14   #6 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
t380 fix this fuse problem:
h_ttps://forum.xda-developers.com/galaxy-tab-a/help/help-tab-t380-oreo-flashing-t3857266
The Following 2 Users Say Thank You to mrfixit For This Useful Post:
Old 06-19-2019, 08:51   #7 (permalink)
Member: 2668110
Frp remove not success
Page generated in 0.13799 seconds with 8 queries
