Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-25-2017, 12:56 | #1 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2669799 Status: Offline Thanks Meter: 0 | N8000 Help... Sorry for my english, I'm italian boy, one time technician (now I repair only for passion in my home...). My N8000 (stock) one day stop to work with bootloop logo: after read some thread and some test I realize that my eMMc stop to work.... Yes, I want try to change it: I order it just programmed and I success to change it! After I see that my IMEI is 00499010640000 and S/N 410707057078310f? I flash with success last ITV firmware, but the problem is always present.... I try some guide but nothing work, I read that this problem can solved with box. There's another solution without box that I do at home? I'm always stay in stock without make an EFS copy.... Thank you to all people can help me, greetings. |
03-01-2017, 19:12 | #3 (permalink) |
Member: 2669799 Status: Offline Thanks Meter: 0 | Solved HI, solved! I search more in forum and I see that Octopus Samsung Tool can repair IMEI with only standard USB cable without box: select different device (N5100, N7100 or P5200....) and I repair IMEI (my IMEI on the rear of battery) and network, after with the same method I repair SN but I must select I9300 device for enable SN Fix option. Thanks to all because I not receive help in my thread but I receive the help from other threads of this wonderful forum. Best regards. |
